Uprising Posted September 26, 2015 Share Posted September 26, 2015 Hello I was considering getting my first warhound, and wondering which loadout is the best. Thanks for reading. Link to comment https://bolterandchainsword.com/topic/314191-mars-pattern-warhound/ Share on other sites More sharing options...
Olis Posted September 26, 2015 Share Posted September 26, 2015 Maybe, for an all rounder, mega bolter + turbo lasers? Link to comment https://bolterandchainsword.com/topic/314191-mars-pattern-warhound/#findComment-4181803 Share on other sites More sharing options...
Dosjetka Posted September 26, 2015 Share Posted September 26, 2015 You might also want to consider getting your CAPS LOCK key checked out ;) But aye, as Olis suggested, the mega bolter + turbo laser combo is a solid start. Link to comment https://bolterandchainsword.com/topic/314191-mars-pattern-warhound/#findComment-4181808 Share on other sites More sharing options...
GogglesDown Posted September 26, 2015 Share Posted September 26, 2015 2x laser destroyers or 1x laser destroyer and 1x plasma blastgun. That's what I would get anyway. Link to comment https://bolterandchainsword.com/topic/314191-mars-pattern-warhound/#findComment-4181809 Share on other sites More sharing options...
Uprising Posted September 26, 2015 Author Share Posted September 26, 2015 You might also want to consider getting your CAPS LOCK key checked out I have to shout, how else will you guys hear me from up here? (Yes, it was a mistake...) what your thoughts on 2x plasma blastgun? Its going to be magnetize, but I think its a good start. Link to comment https://bolterandchainsword.com/topic/314191-mars-pattern-warhound/#findComment-4181825 Share on other sites More sharing options...
Olis Posted September 26, 2015 Share Posted September 26, 2015 It's not bad. Not terribly great at taking on armour but gets the job done if your dice don't decide to betray you. It'll splat MEQs and worse no problem, and fair pretty well against TEQs, too. Edit - Typo. Link to comment https://bolterandchainsword.com/topic/314191-mars-pattern-warhound/#findComment-4181835 Share on other sites More sharing options...
GogglesDown Posted September 26, 2015 Share Posted September 26, 2015 Plasma blastgun only comes in a right herdmount version. I have seen people use two but it looks off IMO. I wouldn't want to miss the opportunity to field at least one D weapon. If you face someone else with a titan how are you going to take it out? Link to comment https://bolterandchainsword.com/topic/314191-mars-pattern-warhound/#findComment-4181840 Share on other sites More sharing options...
Olis Posted September 26, 2015 Share Posted September 26, 2015 I agree with Goggles, a titan without a D weapon can be outclassed easily by other titans (or superheavies). That said, you did mention magnets... Link to comment https://bolterandchainsword.com/topic/314191-mars-pattern-warhound/#findComment-4181844 Share on other sites More sharing options...
Dark Bjoern Posted September 27, 2015 Share Posted September 27, 2015 Plasma Blastgun and Turbolaser are the best mix for me. I´m using this configuration myself. Link to comment https://bolterandchainsword.com/topic/314191-mars-pattern-warhound/#findComment-4182038 Share on other sites More sharing options...
Lucien Eilam Posted September 27, 2015 Share Posted September 27, 2015 Plasma blastgun and turbo-laser. It's not worth the points without at least one D weapon. The plasma blastgun is the official standard armament (the plasma is supposed to be vented directly from its reactor), and it's more flexible with a mix. Also less likely to result in stroppy opponents than 2x turbo-lasers. The Vulcan mega-bolter looks cool, but it's arguably outclassed by even the Knight-class gatling cannon now. In background terms its primary purpose is supposed to be overwhelming void shields, which it is pretty good at, but you won't be doing that very often. The rest of the time it's probably the most underwhelming super-heavy gun in the game. The Inferno gun is good at what it does, but I'd need to have a lot of problems with massed infantry in cover to consider taking it over plasma/turbo-laser. If you want the arms to be swappable, I think you should be thinking "bolts" rather than "magnets". It has been done with magnets, but that's a very expensive, very heavy thing to be trusting to the size of magnet you can fit in the shoulder mount. You also need to consider what you'll do with the power cables. Link to comment https://bolterandchainsword.com/topic/314191-mars-pattern-warhound/#findComment-4182098 Share on other sites More sharing options...
