Wolfbiter Posted December 28, 2015 Share Posted December 28, 2015 Ok, so I've been seeing a lot of discussion in the Night Lords threads arguing that Sevatar can't join Terror Squads during deployment because Infiltrators deploy last, even if the squad doesn't infiltrate. But what if the squad starts in a drop pod? Wouldn't he be able to start in the pod with them normally? Provided there are less than 10 in the squad of course. Link to comment https://bolterandchainsword.com/topic/317601-sevatar-terror-squad-and-drop-pod-question/ Share on other sites More sharing options...
SkimaskMohawk Posted December 28, 2015 Share Posted December 28, 2015 Models with Infiltrate always have to do so unless held in reserve, which is the only time you can join characters to units before deployment. So yes, in pods or normal reserve Sevetar can be joined to them Link to comment https://bolterandchainsword.com/topic/317601-sevatar-terror-squad-and-drop-pod-question/#findComment-4262988 Share on other sites More sharing options...
Hesh Kadesh Posted December 29, 2015 Share Posted December 29, 2015 http://www.blacklibrary.com/Downloads/Product/PDF/Warhammer-40k/7th-faq/40K_The_Rules_v1.1_Dec15.pdf Page 166 - Independent Character, Independent Characters and Infiltrate Change this sentence to read: ‘An Independent Character without the Infiltrate special rule cannot join a unit of Infiltrators during deployment, and vice versa.’ Combined Reserve UnitsDuring deployment, when deciding which units are kept as Reserves, you must specify if any of the Independent Characters in Reserve are joining a unit, in which case they must arrive together. No, Sevatar cannot join a unit of Terror Squad at any point. Link to comment https://bolterandchainsword.com/topic/317601-sevatar-terror-squad-and-drop-pod-question/#findComment-4263201 Share on other sites More sharing options...
SkimaskMohawk Posted December 29, 2015 Share Posted December 29, 2015 Good catch hesh Link to comment https://bolterandchainsword.com/topic/317601-sevatar-terror-squad-and-drop-pod-question/#findComment-4263213 Share on other sites More sharing options...
Hesh Kadesh Posted December 29, 2015 Share Posted December 29, 2015 I've not got a problem in Sev's damage output for his cost. He's a bit of a glass cannon while a similarly priced Praetor is a bit more tanky. But that said, his utility is none existent. Giving Acute Senses to drop pod units while Terminators are being asked to DS close to him from T2 onwards when he should be in CC. Link to comment https://bolterandchainsword.com/topic/317601-sevatar-terror-squad-and-drop-pod-question/#findComment-4263325 Share on other sites More sharing options...
Wolfbiter Posted December 29, 2015 Author Share Posted December 29, 2015 Wow, that really sucks. So much for my Terror Assault list, then. Wait, though...I thought there was also a specific listing stating that Apothecaries can join Terror Squads. If they don't have Infiltrate, by the same logic that wouldn't be possible either, correct? Link to comment https://bolterandchainsword.com/topic/317601-sevatar-terror-squad-and-drop-pod-question/#findComment-4263648 Share on other sites More sharing options...
Hesh Kadesh Posted December 29, 2015 Share Posted December 29, 2015 They aren't independent characters, and the process is different. A unit only needs to have one model to have infiltrate to be able to do it. One of my problems is that they have this long complicated rule structure to let infiltrate trigger with nested exceptions and contraallowances, when all it needed was to require all models in the unit to have it. Potatoes. Link to comment https://bolterandchainsword.com/topic/317601-sevatar-terror-squad-and-drop-pod-question/#findComment-4263673 Share on other sites More sharing options...
