Legio Cybernetica /w Atrapos 2000pts
**Legio Cybernetica** Version 3  [Most recent, Posted edited with changes suggested in thread]
HQ
1 Archmagos Dominus (180)
-Mech Protectiva, Cyber-familiar, Abeyant
-Mechinator Array, Augury Scanner
LOW
1 Atrapos w/ Optiks (445)
Heavy
1 Thanatar Class Siege-automata (300)
- enhanced targeting array; Paragon of Metal
Troops
2 Castellax Class Battle-automata (300)
-2× darkfire cannon; enhanced targeting array
-4x flamer
2 Castellax Class Battle-automata (240)
-2x mauler cannon; enhanced targeting array
3 Thallax Cohorts (165)
-1x Photon Thruster
-1x Heavy Chainblade
3 Thallax Cohorts (145)
-1x Phased-plasma fusil
20 Tech-Thrall (80)
-Rite of Pure Thoughts
2000 pts
Correct me if I'm wrong (I'm new to Mechanicum also), but can't you only take Paragon of Metal on a single unit in your army?
You are probably very right.
I just got my book today, and tossed together a rough army list to figure out which models to buy in my initial order.
I thought that any model running as a 1 model unit could take it, but I'll have to read through it more carefully and find out!
And looks like you are correct, and I will alter my list accordingly.
Thanks for your help, great catch on the rule!!
"a single battle-automata maniple consisting of a single model."
I would see if you can find a way to fit a mechinator array on your archmagos. Probably change out the photon thruster for it as you will want to be using Cybertheurgy or battlesmith instead of shooting.
Mechinator array and battlesmith is on page 112. Cybertheugy is on page 22.
Welcome to the legio Cybernetica!
Thanks a lot! I'll take a look and see what I can rejigger for it!
Appreciate the pages too!
Upgraded
HQ
LOW
Heavy
Troops
2 Castellax Class Battle-automata (280)
 -2x mauler bolt cannon; enhanced targeting array
6 Thallax Cohorts (315)
 -2x Photon-Thrusters; 2x Chainblades
2000 pts
Please critique, comment, and let me know how I can make a more effective Legio list!
Matter of factly, you have only one scoring unit.
Lots of firepower yes, but the lack of scoring units might prove desastrous.
HQ
LOW
Heavy
Troops
2000 pts
Add / drop / change suggestions?
I could split the thallax up into two units of 3 with no upgrades.
Drop a Castellax unit and add two more units of 3.
Gives me 4 scoring units of 3 thallax each, costs me a castellax and 2 photon-thrusters.
Worthwhile change?
I guess I'm still in the mindset that all units can take objectives in 40k. I forget that only troops can in 30k.
**Legio Cybernetica** Version 2 (Please see version 3 for the most up to date)
HQ
LOW
Heavy
Troops
-2x darkfire cannon; enhanced targeting array
3 Thallax Cohorts (175)
-1x Multi-Melta
- Destructor Augment
3 Thallax Cohorts (170)
-1x Photon Thruster
-2x Heavy Chainblade
-1x Photon Thruster
2000 pts
You have a lot of AT, but not much volume of fire. You might struggle if they bring more boys than toys.
You could consider:
One squad of darkfire castellax and the atrapos for heavy armour. Darkfire castellax also like to have flamers since they don't really want to be in bolter range and benefit from the flamers in overwatch.
One squad of castellax with mauler bolt cannons and two squads of thallax with phase plasma for s6 ap3 marine and light transport killing. You can add destructor if you have points to spare.
And a swing squad of thallax with your weapon of choice. Some people like deepstriking multi melta thallax to hunt rear and side armour.
Thanatar for basically any target not a flyer.
Consider how you are going to handle close combat. You don't really have anything that you can use for speed bumps or counter assualt. All of your bots want to be stomping forward guns a blazing instead of being trapped in combat. This will likely stay the case until we get models for Ursarax or the other unreleased cc bot. You could try a unit of Scyllax instead of a thallax squad but their reception was lukewarm.
You could consider:
Sorry, just to clarify on the advise you've provided:
So, taking your suggestions as far as the list stands, I should consider;
-adding flamers to the darkfire castellax
- dropping darkfire from one castellax unit and run them with mauler
- dropping the photon thrusters and chainblades from two groups of thallax and add phased plasma fusils to both groups
- (I already have a deep striking Multi-Melta thallax team gear to go in the list as per your last suggestion)
If that's it, should be simple enough, gear changes are pretty easy!
Thanks.
HQ
LOW
Heavy
Troops
-4x flamer
-1x Photon Thruster
20 Tech-Thrall (80)
2000 pts
______________________
Made those changes. Got two units of Thallax with marine killers, and another unit with terminator eliminators.
Added 20 Tech-Thrall to absorb any melee threat so I can reposition my robots away from them, and add another scoring unit or bullet sponge.
