Charlo Posted June 6, 2016 Share Posted June 6, 2016 Well it's more that sure, they aren't bad - but they sit on a vehicle... That can be immobilized, stunned so it can't shoot or have them plainly shot off! Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4413111 Share on other sites More sharing options...
OPTIMVSCHRISTVS Posted June 6, 2016 Share Posted June 6, 2016 I frequently have games where the bolter sponsons do more damage than the assault cannon...never leave home without them. Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4413140 Share on other sites More sharing options...
NTaW Posted June 6, 2016 Share Posted June 6, 2016 I frequently have games where the bolter sponsons do more damage than the assault cannon...never leave home without them. Same. They also offer a considerably better firing arc than the standard Predator kit. EDIT: Not the hugest difference I suppose but least you'll get both bolters on more things. Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4413150 Share on other sites More sharing options...
appiah4 Posted June 7, 2016 Share Posted June 7, 2016 I frequently have games where the bolter sponsons do more damage than the assault cannon...never leave home without them. Same. They also offer a considerably better firing arc than the standard Predator kit. EDIT: Not the hugest difference I suppose but least you'll get both bolters on more things. Wow, I had never noticed this - do they have different sponson mount bits?? Or is it just because the Heavy Bolter barrels are shorter, so you mean it's got better arcs than lascannon sponsons? Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4413621 Share on other sites More sharing options...
appiah4 Posted June 7, 2016 Share Posted June 7, 2016 EDIT:Double Post Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4413625 Share on other sites More sharing options...
evildrcheese Posted June 7, 2016 Share Posted June 7, 2016 As some who's built a couple if Baals and has just recently built a standard pred i can conform the sponson mounts are indeed different. I didn't realise the difference in arc though... I if running the flame storm I personally wouldn't bother with sponsons. Most of the time you'll be moving 12", and if you're not shooting the flame storm you're probably best flat outing to get into cover/better positioning. A storm bolter might not be a bad shout...or a HK missile to ping off a S8 shot early on... I've got a team game this week, only 1k per player, so I might try the cheap flamestorm Baal. EDC Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4413684 Share on other sites More sharing options...
Dont-Be-Haten Posted June 7, 2016 Share Posted June 7, 2016 As some who's built a couple if Baals and has just recently built a standard pred i can conform the sponson mounts are indeed different. I didn't realise the difference in arc though... I if running the flame storm I personally wouldn't bother with sponsons. Most of the time you'll be moving 12", and if you're not shooting the flame storm you're probably best flat outing to get into cover/better positioning. A storm bolter might not be a bad shout...or a HK missile to ping off a S8 shot early on... I've got a team game this week, only 1k per player, so I might try the cheap flamestorm Baal. EDC Eager to see your results! Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4413746 Share on other sites More sharing options...
Bukimimaru Posted June 7, 2016 Share Posted June 7, 2016 I really like my Flamestorm Pred. He doesn't get as much play time as he used to, but if you ever want a marine player to wet their knickers, pop a Flamestorm Pred down and hug cover like your life depends on it. Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4413864 Share on other sites More sharing options...
NTaW Posted June 7, 2016 Share Posted June 7, 2016 As was pointed out, they are differently crafted sponsons between the Predator kits. The evil part of me wanted to magnetize lascannons onto Baal sponsons and use that tank as the standard Predator but that most certainly would be modeling for advantage. How would I sleep at night knowing my sponsons might both get used?? Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4414101 Share on other sites More sharing options...
Chaplain Gunzhard Posted June 7, 2016 Share Posted June 7, 2016 Isn't the firing arc of sponsons defined explicitly in the rule book, despite how they're modeled? Am I thinking of a previous edition? Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4414120 Share on other sites More sharing options...
Dont-Be-Haten Posted June 7, 2016 Share Posted June 7, 2016 I thought it was 45 degrees as well! Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4414263 Share on other sites More sharing options...
Jolemai Posted June 7, 2016 Share Posted June 7, 2016 Isn't the firing arc of sponsons defined explicitly in the rule book, despite how they're modeled? Am I thinking of a previous edition? Predator sponsons are in the BRB and are 180 degrees... Unless you have a second edition Predator in which case they have 90 degree arcs like a Leman Russ. Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4414294 Share on other sites More sharing options...
Dont-Be-Haten Posted June 8, 2016 Share Posted June 8, 2016 I forgot they could shoot behind themselves and perpendicular as well! Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4414329 Share on other sites More sharing options...
NTaW Posted June 8, 2016 Share Posted June 8, 2016 Isn't the firing arc of sponsons defined explicitly in the rule book, despite how they're modeled? Am I thinking of a previous edition? Predator sponsons are in the BRB and are 180 degrees... Unless you have a second edition Predator in which case they have 90 degree arcs like a Leman Russ. Predator sponsons are just wider than 180 degrees, likewise with the Leman Russ example being just more than 90. Check it out on pg. 74 :) Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4414358 Share on other sites More sharing options...
Khulu Posted June 8, 2016 Share Posted June 8, 2016 BRB does specifically say their arc is determined by drawing LoS in that example, so modeling them like that would actually make the unit marginally better. Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4414397 Share on other sites More sharing options...
Crimson Devil Posted June 10, 2016 Share Posted June 10, 2016 Has anyone tried Tank shocking into a unit with the Flame Baal and then setting them on fire? Seems like a great way to get a lot of guys under the 2 templates. Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4416209 Share on other sites More sharing options...
Bukimimaru Posted June 10, 2016 Share Posted June 10, 2016 I've got a game against a Genestealer cult with 'nid allies tonight. I cant think of a better time to use a flamerpread. >:D Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4416342 Share on other sites More sharing options...
NTaW Posted June 10, 2016 Share Posted June 10, 2016 I've got a game against a Genestealer cult with 'nid allies tonight. I cant think of a better time to use a flamerpread. >:D They're pretty effective against Orks, but then I usually go assault cannon/heavy flamers because the AP3 of the flamestorm seems a moot point againt the green tide. Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4416435 Share on other sites More sharing options...
Charlo Posted June 10, 2016 Share Posted June 10, 2016 I've got a game against a Genestealer cult with 'nid allies tonight. I cant think of a better time to use a flamerpread. > They're pretty effective against Orks, but then I usually go assault cannon/heavy flamers because the AP3 of the flamestorm seems a moot point againt the green tide. Ignore cover AP3 on Nob Bikers is a pretty big deal though! Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4416440 Share on other sites More sharing options...
NTaW Posted June 10, 2016 Share Posted June 10, 2016 The ignores cover matters more than the AP3 with the 4+ save of the Nobz but I see your point. Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4416466 Share on other sites More sharing options...
Riot Earp Posted June 10, 2016 Share Posted June 10, 2016 VS coverhugging GSC the Flamerbaal is better indeed. Damn i should have buyed me some flamerturrets on puppetswar. wow got double ninjad Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4416486 Share on other sites More sharing options...
evildrcheese Posted June 11, 2016 Share Posted June 11, 2016 My field tests of the Flamestorm Baal are not going well, in my first game using it I flat outted into terrain on T1 and Immobilised myself. The only contribution it made was firing its HK missile. EDC Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4417239 Share on other sites More sharing options...
Xenith Posted June 11, 2016 Share Posted June 11, 2016 Did you buy a dozer blade? Best piece of kit for the points on a tank that wants to be moving. Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4417244 Share on other sites More sharing options...
LutherMax Posted June 11, 2016 Share Posted June 11, 2016 What does the dozer do again? Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4417330 Share on other sites More sharing options...
NTaW Posted June 11, 2016 Share Posted June 11, 2016 Re-roll on terrain tests. Link to comment https://bolterandchainsword.com/topic/321755-baal-predator-tactics-and-which-version-works-best/page/6/#findComment-4417335 Share on other sites More sharing options...
