Thanks gents, I would take Pask etc only I'll be using the
Siege of Vraks book, so he's not featured.
I can take any of the regular Russ variants.
Also featured are the Thunderer Siege Tank (basically
a Demolisher cannon on tracks!) or there's the
Annihilator Russ variant (twin linked Lascannon) which
I was considering putting Multimelta sponsons on.
Still haven't made my mind up yet!
Thanks for the patience!!
Multimelta sponsons aren't really a match with lascannons.  Both feature prominently in the arsenal of stuff that pens AV14, but that's about where the similarities end.  The big difference is range.  The multimelta has to get inside of 12" to be effective, while the beauty of the lascannon is that you can pen AV14 from 48" away (pretty close to table-wide on most 48"x72" tables, you have to be shooting diagonally corner to corner before 48" starts to be insufficient).  Why does that matter?  Survivability.  If not for the ordnance rule, multimelta sponsons would make sense on demolishers...as it is, you're relatively safe from return fire at 44" away from the target, why would you want to mix that with weapons that shine from inside of charge range?  You put lascannon sponsons on stock russes and on vanquishers.
If I were running an annihilator, I would give it a lascannon hull mount and no sponsons.  The only sponsons that make any sense at all for it are plasma cannons, at 36" range and AP2, they are an okay match, not a great one, but with "gets hot," not worth it.
Autocannon would be the Baneblade, I wish co-axial weapons were around more...
Oh 3rd edition VDR... you could build everything but paid a premium for it...
As for variety uses, one must think about where the rest of your army will be...
demolishers and eradicators etc, need to get up close and personal. They should be used with he'll hound varients, mech infantry, and infiltrating sentinels perhaps... target saturation.
If the rest of your army is gun line hiding in your deployment zone, your demolishers will probably get knocked off the table immediately.
How do coax weapons work in 40k?  Do you get to fire both, or is it one or the other?  Does it have to be at the same target if you shoot both?
Real-world, you're not likely firing the main gun and the coaxial machine gun within a reasonably narrow time window absent a very very target rich and diverse environment...if there are main gun targets yet alive, you simply ignore the light targets, or someone else shoots them (perhaps the commander with his .50 or the loader will expose himself to engage with the 7.62...but the coax is really only going to come into play when there are no targets worthy of the main gun....
It's to represent the WWII-era method of using co-ax weapons to line up the main cannon, by firing tracer rounds so they could spot the spark on impact against enemy armour before firing the main gun. In the 60s. laser targeting began to roll out on tanks like the Chieftain, and co-ax weapons became more of an anti-infantry suppression weapon, or were removed altogether.
  • 3 weeks later...
As WF said, you roll for hits on the Coax gun first, and then as long as it hits, you get re-rolls on misses with the main gun. Essentially it becomes a twin-linked gun at half range. Which makes BS3 Vanquishers useable.
As for the fluff reasons, well same as in WW2 as Coffee said. It's a ranging rifle, if you can hit it with the coax, you can hit it with the main gun. As I recall, in WW2 most coax guns were M2HB's which had about the same range as the main guns. Same idea here. While using the coax to mow down anything not worth shooting with the main gun isn't a new idea, the Coax's original role has been somewhat forgotten, especially with improvements in the way tanks sight their main guns (which would likely not be present in the IG's tanks, due to heresy or some such).
Yeah, British tanks from the 60s Chieftain onwards used a laser ranger rather than a Co-Ax, so the Co-Ax was removed from all subsequent tanks. I imagine other nations did the same around the same time.
US tanks kept the Coax, we just downgraded from the .50 to a 7.62. We really like redundancy, and MOAR GUNZ! I really like the coax guns from IA2, because as I said, BS3 troop vanquishers become useful. that's really all I have to hard counter my friend who just purchased a Warlord Titan.
