Slave to Darkness Posted July 27, 2016 Share Posted July 27, 2016 Just a quick question chaps, anybody know of a quick easy way of doing German style peadot camo? Ive had a look at some on google and my brains just gone 'no way lad, looks stressfull'. Last time I tried a camo scheme I ended up throwing my toys out my pram in a fit of nerd rage and gave up. Link to comment https://bolterandchainsword.com/topic/324228-camo-help-needed/ Share on other sites More sharing options...
WarriorFish Posted July 27, 2016 Share Posted July 27, 2016 I'm assuming you mean the pattern rather than the colours? If so it's a matter of patience as much as anything. Develop the technique and process (usually colour order) to help make it easier but otherwise it's down to poking with a brush... Camo schemes are an extra that takes time no way around that I'm afraid! You'll want to assembly line it was with anything larger scale if possible further than that it's just a matter of breaking it down into smaller chunks to make it more manageable and less hassle. Link to comment https://bolterandchainsword.com/topic/324228-camo-help-needed/#findComment-4451761 Share on other sites More sharing options...
Teetengee Posted July 27, 2016 Share Posted July 27, 2016 http://www.flamesofwar.com/Default.aspx?tabid=110&art_id=866Perhaps this can help? Link to comment https://bolterandchainsword.com/topic/324228-camo-help-needed/#findComment-4451780 Share on other sites More sharing options...
UltraRich Posted July 27, 2016 Share Posted July 27, 2016 I think you also have to be careful with camo as it doesnt translate well to small minis. What looks good in real life or on a tank just looks a mess on a mini when applied to material with folds etc. My advice is keep it simple and stick to big shapes Link to comment https://bolterandchainsword.com/topic/324228-camo-help-needed/#findComment-4451935 Share on other sites More sharing options...
duz_ Posted July 27, 2016 Share Posted July 27, 2016 Maybe this pattern scheme might be easier? https://www.google.com/search?q=adf+dpcu&client=ms-android-verizon&prmd=sinv&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjt69aHnpTOAhVj5IMKHRTZAE4Q_AUICCgC&biw=360&bih=560 Link to comment https://bolterandchainsword.com/topic/324228-camo-help-needed/#findComment-4451943 Share on other sites More sharing options...
2gud2bbad Posted July 27, 2016 Share Posted July 27, 2016 Get the SS-Camo-Pack from Warlord Games and use a toothpick for stippling. Link to comment https://bolterandchainsword.com/topic/324228-camo-help-needed/#findComment-4451969 Share on other sites More sharing options...
steellegionnaire85 Posted July 28, 2016 Share Posted July 28, 2016 http://www.warlordgames.com/painting-waffen-ss-plane-tree-camouflage/ This link can help some I'm doing something similar with my steel legion. Link to comment https://bolterandchainsword.com/topic/324228-camo-help-needed/#findComment-4452290 Share on other sites More sharing options...
Ulrik_Ironfist Posted July 28, 2016 Share Posted July 28, 2016 You might also look through this topic. Elmo did a ton of troopers in the Gulf War era US 6 Color desert BDU camo, or Chocolate chip. It has a similar dotted pattern, and the way he did it might just give you some ideas on how to go about your project. I do camo on my troopers, but I go for an easier scheme, as I do a multicam style pattern, which has a a few shades of brown and green fading together, and splotches of both. It's easy to do with an airbrush which is why I do it. Link to comment https://bolterandchainsword.com/topic/324228-camo-help-needed/#findComment-4452325 Share on other sites More sharing options...
