Thousand Sons "At The Burning" Army
WickedWeed
So here's the first christmass update of many, during the holidays I will be posting pictures of the entire finished army (hopefully before new years)
Today is two weeks after I recieved my order from FW, and the Venator hull is done, and so is the Javelin hull. Only crew and cannons to go, plus a special base for the javelin.
Next up: Terminators and the glorious Leviathan!
I also decided to do a 10 man plasma support squad in addition to everything :)
And the Venator and maybe the Javelin will get some black solid lines down the hull somewhere.
http://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20161221_113927%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20161221_113943%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20161221_113957%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20161221_114028%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20161221_114104%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20161221_114117%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20161221_114130%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20161221_114141%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20161221_114155%20Redigeret.jpg
  • 3 weeks later...
I haven't updated this for a while but here goes :D
Recently I went to larger scaled game in the warhammer store in Copenhagen, so my units had to be at least table ready!
I ended up sitting until 5 in the morning on the day the game went down, and here's what ended up being set on the table.
Also a big thank you to "Unwanted" who painted the active plasmarifles on my support squad and made my spell greenstuff!
http://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_200845%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_200906%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_200936%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_201009%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_201040%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_201058%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_201120%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_201558%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_201625%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_201634%20Redigeret.jpg
And the rest
http://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_202114%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_202125%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_202130%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_202409%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_202420%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_202431%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_202443%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_202450%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_202553%20Redigeret.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170109_202608%20Redigeret.jpg
Jeez! Those fellows with the white look SHARP! What method are you using to get such a crisp white?
It's actually quite easy, I started by basing everything black with a spray. Then technically leadbealcher all over and then some runefang steel on the top of the armour and so.
Then the actual white part begins, first 2 layers of administratum grey from GW and then 2 layers on the marines of very thin white scar from GW as well. Sometimes 3 layers is needed for the white to really shine for example on veichles.
The reason I mentioned the metallic colours are because I do it to all of it before I paint the red parts more specific. And I think the metal might take some of the black, but the grey SHOULD be enough I think
Hope that helps, any more questions, criticism or commentary is more than welcome!
  • 4 weeks later...
Finally there is an update on my army, and there well be more in the future!
But since I decided to join in on loyalty and treachery I've have something to keep me going.
Here's the veichle part of my order primed black and painted leadbelcher. all prepping for red, just need the runefang highlights!
http://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170201_142250.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170201_142140.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170201_142109.jpg
  • 1 month later...
Here is my latest update, which can also be found at the Loyalty and Treachery thread here on BaCS.
5 Tartaros Pattern Terminators with forceweapons and a heavy flamer and 2 chainfists
1 Centurion to be either a Librarian, Champion or Chaplain
1 Javelin Attack Speeder with lascannons and a heavy bolter
2 Rhinos
1 Spartan Assault Tank, still needs magnetizing but painted in every way
Next update early april!
http://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170320_184024.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170320_184156.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170320_184242.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170320_184316.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170320_184410.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170320_184520.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170320_184540.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170320_184726.jpg
  • 2 weeks later...
Now that my Loyalty and Treachery pledge is completed and I'm awaiting Inferno to be printed, I've decided to do 10 Seekers with some scouty-looks!
I've modelled the first 5 as shown below.
These Seekers are a part of something to occupy me while I wait for my comming order.
The other part is 3 'Imperial Quad Launchers "Thud Gun"' models that will be counting as regular quad launchers!
Here's the Seekers
http://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170330_200306.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170330_200335.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170330_200402.jpghttp://i424.photobucket.com/albums/pp322/sebastian_jensen/Horus%20Heresy%20TS/20170330_200440.jpg
oh yeah, also my first try with greenstuff ever :D
I've decided to use the Umbra pattern bolters for my seekers, to make their weapons look more special! What do you guys think ?
They are also blessed enough to get Mark IV shoulderpads with the TS marking.
I'm ordering some breachers as well, which will be customized with achean heads maybe but Mark IV shoulders for sure.
  • 2 weeks later...
It's been some time since I did a overview of what is done, WIP and incomming orders. So here is a list update of my force!
Done
- Praetor w. Sword
- Centurion Librarian w. Force stave
- Centurion Champion w. Sword
- 10 Tartaros/sekmet Terminators w. 2 Heavy flamers
- 20 Tactical Marines
- 10 Plasma Support Squad
- 2 Rhinos w. Twinlinked bolters
- 2 Javelins w. Twinlinked Lascannons
- 1 Leviathan w. Grav-flux, CC and Autocannon
- 1 Sicarian Venator w. Lascannon sponsons
- 1 Spartan Assault Tank
WIP
- 3 Thudd Gun Mortars, 1 painted, 2 still in progress
- 10 Seekers, waiting for rifles and TS shouldlers
Ordered, incomming
- 10 Breacher Siege
- 2 Apothecarys
- 2 Vindicator Laser Destroyer Tanks
Nice painting, but I have a problem with the posing.  Like around 90% of them need to be reposed so they are lying down, bleeding, and/or dead......:biggrin.: :biggrin.: :biggrin.:
It's pre engagement of the enemy ;) And if so, they would be lying on a pile of dog carcarsses :cool.:
Nice painting, but I have a problem with the posing. Like around 90% of them need to be reposed so they are lying down, bleeding, and/or dead......:biggrin.::biggrin.::biggrin.:
Comments like these are why even the mods mock us.......
People like you are why kittens and puppies are killed everyday. "Lighten up Francis" as even the OP recognized good natured joshing between gamers.
