JeffJedi Posted December 12, 2016 Share Posted December 12, 2016 A large number of the Imperial Agents units are from the Astra Militarium line originally but they make more sense as allies since the are not actually Imperial Guard. The three types of Psykers, Master of the Fleet and Tech-Priests to name a few. Is it possible that they may be removed from the codex and could the space be used for new unit types? Link to comment https://bolterandchainsword.com/topic/328707-will-imperial-agents-units-be-removed-from-the-ig-codex/ Share on other sites More sharing options...
WarriorFish Posted December 12, 2016 Share Posted December 12, 2016 No, I don't think so. The codex is basically a throwback to the old Witch Hunters days - the other bits are just there as some padding and filler. The fleet assets and Techpriests won't be going anywhere and thanks to GW's meddling I don't think the PBS Wyrdvanes get much use anyway... :P Link to comment https://bolterandchainsword.com/topic/328707-will-imperial-agents-units-be-removed-from-the-ig-codex/#findComment-4590914 Share on other sites More sharing options...
MoGuy Posted December 12, 2016 Share Posted December 12, 2016 From what the article on BOLS tells us, the Wyrdvane Psykers can be lead by an Astropath who will be the cheapest ML2 Psyker in the game. That's actually very good news for any imperial army that has no or little defence against psychic heavy armies. The Codex: Imperial Agents will make it easy for the Ad Mech to ally in a Culexus Assassin and a few Psykers/Astropaths - and suddenly we don't have to roll over once the Psychic Phase comes around. That's good news in my book! Link to comment https://bolterandchainsword.com/topic/328707-will-imperial-agents-units-be-removed-from-the-ig-codex/#findComment-4590921 Share on other sites More sharing options...
HackedDuck Posted December 12, 2016 Share Posted December 12, 2016 From what the article on BOLS tells us, the Wyrdvane Psykers can be lead by an Astropath who will be the cheapest ML2 Psyker in the game. The Astro path is ML2 in imperial agents?? In the AM codex they are ML1 I believe. Link to comment https://bolterandchainsword.com/topic/328707-will-imperial-agents-units-be-removed-from-the-ig-codex/#findComment-4590925 Share on other sites More sharing options...
MoGuy Posted December 12, 2016 Share Posted December 12, 2016 The Astro path is ML2 in imperial agents?? In the AM codex they are ML1 I believe. http://www.belloflostsouls.net/2016/12/goatboys-40k-10-imperial-agents-highlights.html In the article it says " The Astropath is the cheapest Level 2 psyker in the game right now so that is pretty neat with this detachment." Link to comment https://bolterandchainsword.com/topic/328707-will-imperial-agents-units-be-removed-from-the-ig-codex/#findComment-4590974 Share on other sites More sharing options...
WarriorFish Posted December 13, 2016 Share Posted December 13, 2016 You can upgrade him to ML2, but I'm not sure what the big deal is unless you're after him as a battery? Link to comment https://bolterandchainsword.com/topic/328707-will-imperial-agents-units-be-removed-from-the-ig-codex/#findComment-4591393 Share on other sites More sharing options...
slowclinic Posted December 13, 2016 Share Posted December 13, 2016 The Astro path is ML2 in imperial agents?? In the AM codex they are ML1 I believe. http://www.belloflostsouls.net/2016/12/goatboys-40k-10-imperial-agents-highlights.html In the article it says " The Astropath is the cheapest Level 2 psyker in the game right now so that is pretty neat with this detachment." Are there no other ML2 Psykers in the game that are 50pts or under? An Astropath is always a good way of getting Psychic Shriek into a list. Link to comment https://bolterandchainsword.com/topic/328707-will-imperial-agents-units-be-removed-from-the-ig-codex/#findComment-4591408 Share on other sites More sharing options...
MoGuy Posted December 13, 2016 Share Posted December 13, 2016 The Inquisitorial Psykers from the digital codex are also normal Psykers. In a previous version they too were just cheap ways to get Psychic Shriek into the list. I could imagine we will see the same with the Astropath. That he becomes a regular ML2 Psyker. Link to comment https://bolterandchainsword.com/topic/328707-will-imperial-agents-units-be-removed-from-the-ig-codex/#findComment-4591479 Share on other sites More sharing options...
duz_ Posted December 13, 2016 Share Posted December 13, 2016 Im actually more disappointed that it appears to be stealing what little flavour guard had. I hope we see these guys again in our next iteration. Hopefully with slightly more beefed rules or at least LD8. More concerned about the lack of Vendetta in the book. It would have been a good opportunity for GW to give us an upgrade sprue like the storm talon / interceptor. Link to comment https://bolterandchainsword.com/topic/328707-will-imperial-agents-units-be-removed-from-the-ig-codex/#findComment-4591517 Share on other sites More sharing options...
Phubar Posted December 17, 2016 Share Posted December 17, 2016 Imperial agents is made for giving Imerials (all not only IG) some small but effective (?) allies. Not all entries from original dexes are available and this dex does not overvrite the others. Ie: GK from IA cannot have Draigo, only small and secondary forces. Link to comment https://bolterandchainsword.com/topic/328707-will-imperial-agents-units-be-removed-from-the-ig-codex/#findComment-4595601 Share on other sites More sharing options...
