Alpha Legion 3000pts - Need some advice!
Hey guys,
I've been struggling to finalise a 3000pts list for a tournament coming up in a couple of months, just wondered if anyone can suggest any improvements or tips to get a list that works well together. The list is mainly built around models that i already have, but am happy to pick up some different units if needed!
Rite of War: Primarch's Chosen (figured to use this Rite to limit potential lost VP's)
HQ
- Alpharius (Warlord)
- Armillus Dynat
Troops
- 8 Vet Space Marines (6 combi's, nucio, vexilla) Serg w. AA, PF & Power Dagger - Rhino w. hunter killer, pintle MM, dozer B.
Ellites
- 3 x Quad Launchers w. Shatter Shells
-Contemptor Mortis w. 2 x Kheres assault cannons
Fast Attack
- Primaris Lightning fIghter w. 3x2 Kraken Pens, battle servitor control, ground tracking auguries
Heavy
- Leviathan Dread w. Cyclonic melta lance, siege claw, H flamers, ceramite, phosphex disharger. Dread Drop Pod
- 3 x Sky slayers w. MM
List comes in at 2943pts
Vets mostly armed with combi-plas, will choose their role on the enemy, Marksmen or Machine killers to work with Dynats rule.
Mutable Tactics, again depending on the enemy and getting best use out of Vets
Dynat in one Rhino
Alph in another, using One as Many, most likely unveiling in Turn 2, as to benefit more from his rules. Had hoped to run Alpharius unveiled from turn one to squeeze as much goodness out of his preferred enemy as poss, trickier to do than i thought though.
Contemptor to support quad mortars from assaulting units
Lightning...for the heavies obvs
Sky slayers to support Leviathan (meaning mostly Infiltrate mutable tactics will be used)
Little concerned about the lack of scoring units at 3000pts though?
Thanks for the read, comments and advice welcome!
Do the P-L really need triple Kraken? One load, maybe two. Three? Naw.
Also, ~25 dudes at 3k is not enough.
Split the Quad Mortars, if you can, so you can target more stuff.
I would scrap some stuff to find room for Apothecaries, given your squads are pretty small, the boost in durability would help. Though honestly, I just recommend getting more dudes overall. You can scrap the Nuncio, too - don't think those will help you at all. Wouldn't bother with the Ground Tracking either on the P-L.
Rhinos are not particularly durable, btw. Wouldn't hurt to have a blocker - like a Spartan - that they can ride behind until they are close enough to make a difference.
Also, not going Coils? Seems like Alphas really benefit in that RoW more than any other.
Just my $.02.
Like it has been said, there's too few models for a 3.000 pts. list.
You'll be crushed in no time by the right opponent.
Also, three scoring units in 3.000 pts. ? Really ?
Your Vet Tac squads are fine, if seriously expensive. I'd give them more focus or slim and trim them.
Alpharius and Dynat ?
I feel like Dynat is a waste of points in your current list configuration. Pick either him, or the Big A.
In regards to Alpharius ... what he does best is to buff your infantry units ... which you have precious little in your list.
I'd settle on one of them and then adjust the list accordingly.
Preferably Alpharius.
Get rid of Dynat.
Maybe get a cheap HQ so you can select Alpharius as your LoW and run CotH as your RoW.
If you stick with Dynat run either Orbital Assault or PotL and adjust accordingly.
2x2 Kraken Missiles is absolutely enough. It's a one-trick pony.
But most of all ... get more dudes.
Agree with most of what is posted above except about the lightning, stick with 3x2 Krakens.
You need at least 1 scoring per 750 points, preferably more like 1 per 5-600. Your model count is very low, but not very tough, or fast. Both Alpharius and Dynat do not help this list. Switch to Skorr and take chosen's duty RoW, should free up 500 points to take some more vets/terminators and grab some ranged anti-infantry (medusae, plasma preds are good options).
Coming back to the lightning. Going for 4 krakens means you will make 1 shot, and the lightning becomes a useless platform. With 6 you can fire the lascannon and 3 krakens twice. With this loadout you should be able to take down 2 heavy tanks rather than overkill 1. You will also find you need ~6-8 krakens to kill a legion SHV, with 4 you will halve its HP, and then possibly struggle to kill it making the entire endeavour pointless.
In my experience the Kraken will ... just die ... if it has any Kraken Missiles remaining after the initial turn 1 barrage.
No opponent will allow the thing to go at it for another turn if is still has payload left.
Thanks Xera, Im very new to 30k so still getting my head around things, although my rationale was that Dynat would boost the Levi's melta lance in enemy deployment, as well as the Sky Slayers (and any vets that made into en.deploy if i gave them machine killers). He would also boost the BS skill of a vet unit with the combi plas, mixing with Alphs preffered enemy getting rid of 1's etc. Alph would boost the 6 units i have with Legion Astartes rule, as well as utilising his cognis with another combi plas vet unit.
I appreciate now that perhaps the list is not making best use of his buffs with so few units/body count though.
Good to know about the ratio of scoring units to points, makes sense. Had always assumed Skorr was more suited to smaller games but can see it would still work at this level. Will have a rethink!
  • 2 weeks later...
Are combi-weapons on all the vets really needed? You could save yourself a few points and get some extra bodies. If you want to really make use of the preferred enemy you could invest in a plasma support squad, which will really help with TEQs.
  • 4 weeks later...
So after a little tinkering, i've rewritten the list and gone with Coils ROW.
HQ
- Forge Lord Consul - AA, Power fist, Rad grenades, Boarding shield, Cyber-fam, power dagger
Troops
- 10 Tac Space Marines (Vexilla) Serg w. AA, Combi Weapon, Melta bombs, Power Dagger - Rhino w. hunter killer, pintle MM, dozer B.
- 10 Tac Space Marines (Vexilla) Serg w. AA, Melta bombs - Rhino
Ellites
- 2 x Quad Launchers w. Shatter Shells
- 1 x Apothecary
- 6 Invictarus Suzerains. Land Raider Phobos (armoured C,)
- 8 Vet Tac Marines, 5 combi plas, Serg w. AA, PF, dagger - Rhino, dozer blade, pintle MM
Fast Attack
Heavy
- 3 x Sky slayers w. Plas Cannons
LOW
- Alpharius
List comes in at 2996pts
Generally taking Infiltrate, however i have option of taking Tank Hunter if needed against the right opponent.
I can trim down the fancy Rhinos in the tac squads to squeeze in another Quad launcher, and may even get rid of one of the Rhinos completely if i decide to ditch Tank Hunter for good. Figured the rhinos could help screen the phobos if critical.
Slayers are more of a back line plas cannon unit that can contest objectives late on if needed, went with Plas cannons to help with TEQ and higher toughness armies.
Vets probably taking combi plas, i see this as more versatile, if i do take tank hunter, with machine killers they can pose a good threat against some 13 av tanks etc.
One thing im not sure of, does Move through cover/cameleoline confer to dedicated transport?? Its pushing it a bit i know but would be pretty handy for the phobos.
Decided Forge Lord over a Chaplain as his buff to the Suzies str. 4 attacks is pretty good. They have WS5 and preferred enemy so should hopefully do ok on rolls to hit, its their strength that could let them down in a fight, so the RADs are pretty....ra..cool.
Comments and suggestions welcome!
I'd consider dropping one suzeraine to allow the FL to be upgraded to Tartaros armour and a chain fist - he'd add some much needed punch to the unit if you come across heavy tanks/ Levi's,knights, etc, especially if you split Alpharius away from the squad.
I'd also drop the hunter killer misfiled from the 2 rhinos to but dozer blades on the Phobos and third tac rhino.
I'd also exchange the tac squads sgts combi weapons for power fists to go with the power daggers.
Yea  thats a good point, I forgot to mention that Alpharius would be unveiled from the start, riding in the Phobos conferring scout to it. (Think thats legal..)
Was thinking about having him hide in one of the Tac rhinos, but then realised he wouldnt fit..so i can only infiltrate him inside a transport if he's with the Vets...but then its no surprise really..
That veteran squad looks like a waste of poiints imo. If you run Tank Hunter MT then you're using machine killers I assume? I'd just take a support squad totting plasmas, they're still scoring and with Alpharius making you re-roll all those annoying 1s they're a safe bet. One thing to keep in mind too, Seekers (and to a certain extent with big A, Headhunters) are a very solid choice. Special ammo makes them versatile and they're scoring to boot. Worth a thought
  • 3 weeks later...
Another take on the army i'm considering.
PotL ROW.
Infiltrate MB
HQ
- Armillus Dynat
Troops
- 10 Vet Space Marines (2 melta guns, melta bombs, nuncio, vexilla) Serg w. AA, PF & Power Dagger - Rhino w. pintle MM, dozer B.
- 7 Terminators (6 combi weapons, 2 PF, 1 Chain fist) Serg w. Chain fist, power dagger, combi-weapon and grenade hareness
Ellites
- 1 x Apothecary (AA, Augury Scanner)
Fast Attack
- Primaris Lightning fIghter w. 2x2 Kraken Pens, battle servitor control, ground tracking auguries
- 6 Seekers (6 combi plas) strike leader w. PF, PD, melta bombs. Proteus w. dozer blade, AC, pintle combi plas, explorator augury web.
Heavy
List comes in at 2999
Dynat rides with the seekers and apoth, infiltrating where necessary.
Plas sky slayers stay back field
MM Sky slayers support Levi up in enemy deployment
Levi..kinda ovbious
Termies deep strike where needed, using augury web and nuncios for improved accuracy and timing (even with dynats re-roll)
Vets armed most likely with combi-melta and either infiltrating close into enemy lines or outflanking
