Skitarii Allies/Combined Arms with Cawl
Technically, RAW they would work simultaneously right now, as they are two separate rules that work in the same way as each other. Being separate rules they do not stop you from activating one of each per turn. However with battle congregation you can't re-use Cawl's canticles, as they are not explicitly stated as "Canticles of the Omnissiah".
However we might get FAQ soon, like the wrath of magnus did regarding horrors.
By RAW they do not work simultaneously. His rule state that his canticles works exactly like the normal... And the only way they can be "exactly" like the normal canticles, is if you can only activate one canticle per turn and not reuse it. The RAI might be different but i am not going to use both per turn until it FAQed.
