Race Bannon Posted February 3, 2017 Share Posted February 3, 2017 Concerning the Hunter tank turret, I think the hull mount is special to this turret, but could the weapon mount ... disk ... part fit onto a Razorback turret plate without the hull mount? If that makes sense. Link to comment https://bolterandchainsword.com/topic/330553-the-hunter-and-its-turret-size/ Share on other sites More sharing options...
Grotsmasha Posted February 3, 2017 Share Posted February 3, 2017 If I correctly understand what you're asking, I think it's a no.... If you look at the smaller circle, you can see it's the locating piece for the turret ring/hatch, showing the circle to much larger than the Razorback ring. I think you'd be better off trying to get Razorback weaponry onto the Hunter weapon mount rings. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/330553-the-hunter-and-its-turret-size/#findComment-4641825 Share on other sites More sharing options...
madscuzzy Posted February 3, 2017 Share Posted February 3, 2017 It uses the same diameter as the turret on the Ravenwing Darkshroud... in case you have any ideas... Link to comment https://bolterandchainsword.com/topic/330553-the-hunter-and-its-turret-size/#findComment-4641984 Share on other sites More sharing options...
Race Bannon Posted February 3, 2017 Author Share Posted February 3, 2017 @Grot - hmm and @Madscuzzy - I didn't think of that, and that's Thank you to both! Link to comment https://bolterandchainsword.com/topic/330553-the-hunter-and-its-turret-size/#findComment-4643167 Share on other sites More sharing options...
