Mechanist Posted December 2, 2018 Share Posted December 2, 2018 Drop by and leave a post; It may be the impetus I need to resurrect this project...... I’ll use this comment of yours against moderati screaming ‘threadomancy’! EDIT: Turns out, I can't. The topic has been archived. So you need to contact a Moderati to un-archive and re-activate it. Then I will follow it and provide you with the digital kicks in the butt to finish the Lucius Reaver. Because that thing needs to be finished. As it is a thing of beauty. it it very cool and I'd love to see it back to life but if it was me I'd then drop the Imperator as I flutter over to the older project. Please finish this big beast first then stand the three (these two and your warlord side by side) having two finished will really help drive the Reaver. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5204379 Share on other sites More sharing options...
Blackadder Posted December 22, 2018 Author Share Posted December 22, 2018 I think I'll Have To Add Another Barrel: Not much going on with the model these days. I've got 3/4 of a year working on these two guns and am nowhere near finished. For example today I spent reducing the bore of the five o'clock position barrel which gratifyingly finally looks right (to me). https://i.imgur.com/FdGlpjo.jpg I did a quick setup of the hull to take these pictures and have something posted before Christmas. https://i.imgur.com/xGathUi.jpg I made the barrels extra long so I could adjust the length with a minimum of refabricating https://i.imgur.com/kko672F.jpg it seems I must adjust them by a ninth https://i.imgur.com/oHB0eGA.jpg To match the picture and the Sunfury Annihilator Turbo Laser. Have a Happy Holiday. Master Toddius, Eldrick Shadowblade, DuskRaider and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5221334 Share on other sites More sharing options...
Mostwanted Posted December 23, 2018 Share Posted December 23, 2018 Good to see an update. I keep checking for one on a regular basis. I agree, the bore size for the barrel looks good. Obviously looks a little out of place with the others still being larger, but think the new size would give better proportions. Happy Holidays/Christmas! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5221370 Share on other sites More sharing options...
Blackadder Posted December 31, 2018 Author Share Posted December 31, 2018 A Cog Disc The more I build this thing the more I think these are actually revolving barrels. But they are energy weapons so what is the point??? Anyway my production schedule has been compromised by the Holiday Festivities I made time today to make the Cogged backing chamber for the barrels https://i.imgur.com/10kf0vn.jpg You can see by the image below that it looks like the backing plate and the barrels rotate as a single piece https://i.imgur.com/C5XZ2u6.jpg Anyway the component is straight forward and simple to replicate thanks to the Waffle material; the Fluorescent Light Diffuser Panel. https://i.imgur.com/fpkT8hb.jpg Master Toddius, bluntblade, Radiation and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5225290 Share on other sites More sharing options...
Stormxlr Posted December 31, 2018 Share Posted December 31, 2018 In my humble opinion they are revolving for the same reason Gatling guns are revolving, cooling? They fire one at a time as they spin up? Ye no it doesnt make sense at that scale since they wouldnt be able to spin fast enough and yes they dont need to spin since its an energy weapon but... Gatling gun laser cannon sounds cool? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5225309 Share on other sites More sharing options...
Bryan Blaire Posted December 31, 2018 Share Posted December 31, 2018 I don't know, Black Adder, it looks like there is a flat hexagonal plate mounted behind the barrels, and then a gap between that plate and the cog/toothed wheel. IMO it isn't really a weapon configuration that makes sense at all, but what makes me think there is some kind of gap is the plate that is above the barrels that's "parallel" to the ground - it appears to come down in front of the cog wheel and the that cylindrical object projects forward and holds that weird plate that appears to have a slot/groove in it above the backing plate behind the barrels. But since it isn't a solid round firing weapon, the configuration makes no sense to me. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5225310 Share on other sites More sharing options...
CommodusXIII Posted December 31, 2018 Share Posted December 31, 2018 (edited) Just to be clear, the weapon in the artwork referenced above is a gatling blaster, which is a solid-round cannon. And the barrels are meant to revolve - as the name suggests, it's a ridiculously-scaled gatling gun. It's confusing because the version of the gatling blaster designed for the old Lucius-pattern Warlord appears similar to the hellstorm cannon on the Imperator. Even the 40K Wiki gets it wrong. But they are (in the old AT/EPIC rulesets and in lore) very different weapons. Now, the Imperator's hellstorm cannon looks like it revolves, too, so the discussion isn't irrelevent. I'm just saying that drawing conclusions from the Warlord Titan artwork isn't entirely accurate. Edited December 31, 2018 by CommodusXIII Bryan Blaire and Augustus b'Raass 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5225358 Share on other sites More sharing options...
Blackadder Posted January 21, 2019 Author Share Posted January 21, 2019 Eight into Five just don't go evenly; Cogs that is. Yeah I know but that's what the image calls for. It was either eight or nine and there wasn't space for nine cogs. I could have done six but the spacing would have been too great. No matter how you slice it the revolving chamber just doesn't work. But you know I just don't care anymore. I'm tired of playing with these guns :D https://i.imgur.com/M7Jc32J.jpg Last night was the first time in three weeks I actually had time to work on this thing since New Years. https://i.imgur.com/xMwHSlu.jpg I've decided that the 5 barrels remain stationary and the cylinder revolves. Don't ask me how or why but dimmit that's the way it's gotta be. https://i.imgur.com/qYlONTk.jpg Now I've gotta adjust the barrel length and the support carriage. https://i.imgur.com/mCUqsMZ.jpg And get this show back on the road. https://i.imgur.com/dOnd5s2.jpg Sgt. Blank, Knightsword, Focslain and 12 others 15 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5238953 Share on other sites More sharing options...
Blackadder Posted February 6, 2019 Author Share Posted February 6, 2019 Egad! I've forgotten how this thing goes together! It's been six or so months since this Emperor Titan took a header (fortunately without sustaining much damage) and it was, at the time, inexpedient to reassemble the completed components. So this past week I've been trying to figure out HOW I BUILT THE D@MNED THING! All the body components interlock together without glue to facilitate assembly and disassembly (So I can add the interior detail when I get to it) but there are 20 to 30 major components and the sequence of how they are assembled has been trial and error. HA! https://i.imgur.com/ErYsfTT.jpg Anyway here is what it looked like before it toppled and we can go from there. Grotsmasha, Marius Perdo, BeatTheBeat and 12 others 15 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5249953 Share on other sites More sharing options...
Bjorn Firewalker Posted February 6, 2019 Share Posted February 6, 2019 Looks majestic- and an absolute PAIN to put together in a way that ensures it stays in one piece. I wish you success in the Titan's completion. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5249982 Share on other sites More sharing options...
Blackadder Posted February 6, 2019 Author Share Posted February 6, 2019 Looks majestic- and an absolute PAIN to put together in a way that ensures it stays in one piece. I wish you success in the Titan's completion. An interesting aside; while I was assembling this thing on the gutted TV Console I use to fabricate the components over my computer work station the whole thing toppled over again yesterday It fell on my desk, my computer chair and ultimately five feet to the floor separating into a dozen component pieces..... Surprisingly no damage. I shoulda got a picture of that. Augustus b'Raass 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5249999 Share on other sites More sharing options...
Augustus b'Raass Posted February 7, 2019 Share Posted February 7, 2019 Build to last, apparently. I really don't buy that 'it toppled over' story. I think you're doing it on purpose. So if it doesn't break, perhaps kill it with fire? ;) Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5250599 Share on other sites More sharing options...
Blackadder Posted February 11, 2019 Author Share Posted February 11, 2019 A Crash Test Dummy: Is building this Titan. I wish I could blame this on the cat or something but instead I am making inroads into stupidity. I was going to show the interior with the positioning plugs I have been working on for the past few days but instead here we see a pile of rubble which was the inner levels of the interior. https://i.imgur.com/ZzEMFGN.jpg Fortunately its not all as bad as it seems in spite of falling the same 5 feet again in much the same trajectory as the previous fall a couple of days ago although the computer chair did not intervene to soften the mishap this time so a few items actually did break this time. As I type the glue is drying and most of the damage is repaired (I'm getting good at it by now) Anyway, with hope, I'll be able to photograph the aligning plugs later today. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5254245 Share on other sites More sharing options...
Crizza Posted February 11, 2019 Share Posted February 11, 2019 Oh my, that killed my two scratchbuild warhounds.Bodies without arms and heads were done and then they fell off a drawer.I never even attempted to fix them... Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5254355 Share on other sites More sharing options...
CommodusXIII Posted February 11, 2019 Share Posted February 11, 2019 I still have flashbacks to when my Emperor's Champion kitbash fell off a table and shattered on a tile floor, and I guess I'm still holding a grudge, too. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5254370 Share on other sites More sharing options...
Studio Silvernale Posted February 12, 2019 Share Posted February 12, 2019 catastrophic reactor explosion Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5254597 Share on other sites More sharing options...
Cryptix Posted February 12, 2019 Share Posted February 12, 2019 At least when your's happened it was an expensive resin hierophant . I still need to figure out how I'm going to secure my models, since I have a kid on the way and baby + small parts = bad times for daddy and son. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5254608 Share on other sites More sharing options...
Lord Raven 19 Posted February 12, 2019 Share Posted February 12, 2019 That is just a very large, Complex jigsaw puzzle. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5255369 Share on other sites More sharing options...
Blackadder Posted February 22, 2019 Author Share Posted February 22, 2019 Quarter Galleries: For lack of a better term; this is the area I'll be working on https://i.imgur.com/gjLeebc.jpg The images are pretty much self explanatory; I'll be framing out the "Quarter Galleries" with cut Florescent light panel waffle diffusers purchased at Home Depot. https://i.imgur.com/rr4ohCP.jpg The panels are made of very hard and brittle styrene plastic but are plenty durable for framing and is cheap compared to hobby shop styrene. About 4 feet long and about 2 feet wide metric users can do the math....;) https://i.imgur.com/FrpJg0s.jpg Bryan Blaire, Master Toddius, Subtle Discord and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5262504 Share on other sites More sharing options...
Blackadder Posted February 24, 2019 Author Share Posted February 24, 2019 The Ground Floor: Actually about one hundred fifty feet above the ground but what the hey. The superstructure of this Titan is what makes it unique and I've been putting it off long enough trying to come up with something earthshaking. Try as I might I just cannot top Joazzz2's incredible architecture so I'll just copy that so first the gatehouse battlements sometimes called the barbican. https://i.imgur.com/WaYJaCe.jpg Subtle Discord and Sgt. Blank 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5263598 Share on other sites More sharing options...
Sgt. Blank Posted February 24, 2019 Share Posted February 24, 2019 You are a lot calmer than I'd be about the falls - glad the repairs weren't too awful and hope you don't need to make any more. It is really awesome to see it standing like that though. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5263637 Share on other sites More sharing options...
Blackadder Posted February 26, 2019 Author Share Posted February 26, 2019 Never Be Afraid: To take the plunge. If the wine is sour, don't throw it out; make vinegar. Something just didn't look right about these two barbicans but until they were sheathed I couldn't quite figure it out. https://i.imgur.com/f9QGDXh.jpg Ultimately I realized they were too tall. https://i.imgur.com/267X9Ne.jpg A couple of minutes with a razor saw and utility knife demonstrated I was right and through careful surgery I managed to save the upper section for the second stage of the construct. Sagentus, Augustus b'Raass, Grotsmasha and 9 others 12 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5264543 Share on other sites More sharing options...
Augustus b'Raass Posted February 27, 2019 Share Posted February 27, 2019 This projects amazes me every time I look at another update. It's really coming together and starting to look like something now! Lord Raven 19 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5265152 Share on other sites More sharing options...
Sagentus Posted February 27, 2019 Share Posted February 27, 2019 This is certainly going to be the most epic/ambitious project I have witnessed and it is always a delight to see these updates coming in regularly Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5265182 Share on other sites More sharing options...
Blackadder Posted March 1, 2019 Author Share Posted March 1, 2019 Exercise In Tedium: The problem with building so large a model is the tedious repetitious building of identical parts. https://i.imgur.com/OF077uL.jpg Even an assembly line approach does not sufficiently relieve the boredom. https://i.imgur.com/s9hNX7D.jpg Sagentus and Sgt. Blank 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/29/#findComment-5266662 Share on other sites More sharing options...
