Adeptus Posted July 11, 2017 Share Posted July 11, 2017 So I'm looking at starting a small Deathwatch force, and I've noticed that theVanguard, Terminators and Bikers are just the generic SM kits with a DW upgrade frame thrown in, but the models in Kill Team Cassius seem more individual. I've already got the 'Start Collecting' box and was wondering if the Cassius box would be a good next purchase? I do plan on eventually getting a squad each of the Terminators, Vanguard vets and Bikers, so I'm not sure if the extra models in Cassius would be worthwhile, since I would wind up with an odd number of models and I'm not sure if the ones from Cassius would blend in with the 'generic' ones from the SM range? I suppose I could just use them as Sergeants of their respective squads. Thoughts? Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/ Share on other sites More sharing options...
hmk17 Posted July 11, 2017 Share Posted July 11, 2017 Kill Team Cassius is the repack from Overkill of DW characters from the board game. At the end of 7th, most of the characters had individual stats and there were several specialized kill teams you could make using some if not all the characters. Alas, that is no more.Right now, you effectively get the following:Chaplain (Bolt Pistol)Librarian (Force Sword, Bolt Pistol)Frag CannonTerminator (with a hugely expensive upgrade and Heavy Flamer)Biker (Power Sword)2x Vanguard Vets (Hand Flamer, Lightning claws)Vet w/ Plasma PistolVet w/ Combi meltaVet w/ BolterVet w/ Bolt PistolEveryone is nicely detailed, so they are awesome to look at. So its a toss up on value if you need certain types of models vs. load outs since this box is like $5 less than 2x Kill Team Boxes. Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815349 Share on other sites More sharing options...
Macabre Slanneshi Prince Posted July 11, 2017 Share Posted July 11, 2017 I think it's worth getting as the models are all really good, though it'd be better if you found a genestealer player to split Deathwatch Overkill with. It's definitely not very flexible, and the models will stick out if you're going all Mk8. Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815441 Share on other sites More sharing options...
Adeptus Posted July 11, 2017 Author Share Posted July 11, 2017 I think it's worth getting as the models are all really good, though it'd be better if you found a genestealer player to split Deathwatch Overkill with. It's definitely not very flexible, and the models will stick out if you're going all Mk8. Will they stick out compared to the models in the "start collecting" box? Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815516 Share on other sites More sharing options...
Closet Skeleton Posted July 11, 2017 Share Posted July 11, 2017 I think it's worth getting as the models are all really good, though it'd be better if you found a genestealer player to split Deathwatch Overkill with. It's definitely not very flexible, and the models will stick out if you're going all Mk8. Will they stick out compared to the models in the "start collecting" box? Yes, they're all a bit short in comparison. Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815526 Share on other sites More sharing options...
Adeptus Posted July 11, 2017 Author Share Posted July 11, 2017 Hmm, that makes me a bit sad. Might stick to converted 'normal' marines then. Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815543 Share on other sites More sharing options...
Silas7 Posted July 11, 2017 Share Posted July 11, 2017 The height isn't that bad, they look like normal people. I have a few from KT cassius and some Mk8s and i think they blend in just fine. shandwen 1 Back to top Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815624 Share on other sites More sharing options...
Adeptus Posted July 11, 2017 Author Share Posted July 11, 2017 The height isn't that bad, they look like normal people. I have a few from KT cassius and some Mk8s and i think they blend in just fine. So it's not like Primaris vs Old marines? Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815670 Share on other sites More sharing options...
Robbienw Posted July 11, 2017 Share Posted July 11, 2017 No, deathwatch aren't much taller. You will notice it, but it is not as stark a difference as the primaris to normal marine. They also have the same build as normal marines, they are not wider and thicker legged like the primaris. Also, the kill team cassius models are absoloutely superb looking, nicely detailed. Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815733 Share on other sites More sharing options...
Adeptus Posted July 11, 2017 Author Share Posted July 11, 2017 No, deathwatch aren't much taller. You will notice it, but it is not as stark a difference as the primaris to normal marine. They also have the same build as normal marines, they are not wider and thicker legged like the primaris. Also, the kill team cassius models are absoloutely superb looking, nicely detailed. Well, I know people that are barely 5' tall and some that are 7' tall, so I think a little variance in height is OK. I think you've sold me, Killteam Cassius is now on my shopping list! Robbienw 1 Back to top Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815773 Share on other sites More sharing options...
shandwen Posted July 11, 2017 Share Posted July 11, 2017 It is really easy to modify many of the equipment options as well. I changes the dark angel to puta a bolter in place of the plasma pistol and a pointing hand in place of the sword, and it's super easy to replace the hand flamers on the one vanguard guy, so some of their equipment can be fixed. Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815784 Share on other sites More sharing options...
Mobius0288 Posted July 11, 2017 Share Posted July 11, 2017 Kill Team Cassius is the repack from Overkill of DW characters from the board game. At the end of 7th, most of the characters had individual stats and there were several specialized kill teams you could make using some if not all the characters. Alas, that is no more. Right now, you effectively get the following: Chaplain (Bolt Pistol) Librarian (Force Sword, Bolt Pistol) Frag Cannon Terminator (with a hugely expensive upgrade and Heavy Flamer) Biker (Power Sword) 2x Vanguard Vets (Hand Flamer, Lightning claws) Vet w/ Plasma Pistol Vet w/ Combi melta Vet w/ Bolter Vet w/ Bolt Pistol Everyone is nicely detailed, so they are awesome to look at. So its a toss up on value if you need certain types of models vs. load outs since this box is like $5 less than 2x Kill Team Boxes. I find most of them usable to be honest. You have: - a fairly generic Chaplain and Librarian you can substitute in - an additional frag cannon (which only get one per kill team box anyway... the more the merrier :) ) - a generic biker - the vanguard with lightning claws makes a pretty good Sgt in a vanguard unit (3A + 1 for dual claws, and re-rolls) * I actually use combi-meltas in my list so the combi-melta guy worked out for me * Same for the generic bolter guy Just remember now that they've pretty much taken away our single unit stuff in the last Erreta, so my opinion is if you can fit most stuff in your current setup, you're good to go. Having some extras would just mean you can have flexibility in points/power level. Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815786 Share on other sites More sharing options...
Vel'Cona Posted July 11, 2017 Share Posted July 11, 2017 It's a box set with solid details, a nice mix of characters and the scaling is reasonable for the time in which it was produced. Since many of them are on "scenic" bases or in heroic poses (no static in that box), it would be easy to build them up a bit to increase their presence. Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815792 Share on other sites More sharing options...
Adeptus Posted July 11, 2017 Author Share Posted July 11, 2017 Just remember now that they've pretty much taken away our single unit stuff in the last Erreta, so my opinion is if you can fit most stuff in your current setup, you're good to go. Having some extras would just mean you can have flexibility in points/power level. What do you mean 'single unit stuff'? What was in the last errata? Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815824 Share on other sites More sharing options...
Mobius0288 Posted July 11, 2017 Share Posted July 11, 2017 It's a box set with solid details, a nice mix of characters and the scaling is reasonable for the time in which it was produced. Since many of them are on "scenic" bases or in heroic poses (no static in that box), it would be easy to build them up a bit to increase their presence. I'm so glad you said that! I just bought some fancy bases I can use with my kill team cassius! Just remember now that they've pretty much taken away our single unit stuff in the last Erreta, so my opinion is if you can fit most stuff in your current setup, you're good to go. Having some extras would just mean you can have flexibility in points/power level. What do you mean 'single unit stuff'? What was in the last errata? The FAQ/Erreta changed Vanguards and Termies from 1-5 to 5-10 Vel'Cona 1 Back to top Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4815828 Share on other sites More sharing options...
Vel'Cona Posted July 12, 2017 Share Posted July 12, 2017 The FAQ/Erreta changed Vanguards and Termies from 1-5 to 5-10 http://s2.quickmeme.com/img/cc/ccdb9c1bdc8c745ae389fd40950de56c0da8fd353a66724250f3e5b8e6ac9207.jpg Link to comment https://bolterandchainsword.com/topic/336474-killteam-cassius-worth-purchasing/#findComment-4816864 Share on other sites More sharing options...
