ThePumpkinTribunal Posted September 10, 2017 Share Posted September 10, 2017 Hello!So I'm new to 40k and am starting to build some Deathwatch. I've got the new Index and am a little confused about chainswords. Am I allowed to equip a Veteran with both a boltgun and a chainsword? I see them on their equipment list, but I don't see them in any of the DW boxes I've purchased. Would I have to buy the bits separately? I'm looking to keep point costs down with my Vets by not giving some of them power swords. Any insight into this would be great. Thanks! Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/ Share on other sites More sharing options...
Deepstrike_Nick Posted September 10, 2017 Share Posted September 10, 2017 You are allowed to give them a bolter and chainsword. My advice would be to get a vanguard veteran box for a load of extra weapons, cool leg poses and other assorted bitz and then just mix and match. Vel'Cona, ThePumpkinTribunal and Aothaine 3 Back to top Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4882003 Share on other sites More sharing options...
bluntpencil Posted September 10, 2017 Share Posted September 10, 2017 You are allowed to give them a bolter and chainsword. My advice would be to get a vanguard veteran box for a load of extra weapons, cool leg poses and other assorted bitz and then just mix and match. I do not advise this! The Vanguard set's chainswords are largely right handed... ...just like your boltguns. Try to find lefty chainswords elsewhere. Lexicanum and ThePumpkinTribunal 2 Back to top Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4882386 Share on other sites More sharing options...
ThePumpkinTribunal Posted September 10, 2017 Author Share Posted September 10, 2017 Duly noted! I have a box of Vanguard Vets. I'll take a look to see what's inside later today, otherwise I'll buy some bitz online. Thanks for the replies! Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4882394 Share on other sites More sharing options...
Moostick Posted September 10, 2017 Share Posted September 10, 2017 Assault marines and Death Company have left-handed chainswords. If you cut the Vanguard Vets' chainswords and the DW power swords above the hand, it's not a hard conversion either. Deepstrike_Nick, Aothaine and ThePumpkinTribunal 3 Back to top Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4882443 Share on other sites More sharing options...
Deepstrike_Nick Posted September 10, 2017 Share Posted September 10, 2017 Assault marines and Death Company have left-handed chainswords. If you cut the Vanguard Vets' chainswords and the DW power swords above the hand, it's not a hard conversion either. That is what I tend to do. Easy enough. ThePumpkinTribunal 1 Back to top Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4882452 Share on other sites More sharing options...
ThePumpkinTribunal Posted September 11, 2017 Author Share Posted September 11, 2017 Assault marines and Death Company have left-handed chainswords. If you cut the Vanguard Vets' chainswords and the DW power swords above the hand, it's not a hard conversion either. That sounds like a good idea. Thanks! Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4882633 Share on other sites More sharing options...
ThePumpkinTribunal Posted September 11, 2017 Author Share Posted September 11, 2017 Also, for simplicity reasons, do any of you have links to just left handed chainsword bitz? I've been searching quite a bit but it seems like most sites are out of stock. Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4882663 Share on other sites More sharing options...
Stargate_wars Posted September 11, 2017 Share Posted September 11, 2017 For my veterans I used tactical marines with spare mark 3 marine chainswords. Vel'Cona 1 Back to top Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4883156 Share on other sites More sharing options...
ThePumpkinTribunal Posted September 11, 2017 Author Share Posted September 11, 2017 (edited) For my veterans I used tactical marines with spare mark 3 marine chainswords. Interesting! I was thinking of getting a drop pod. I could probably buy the drop pod/tactical marine box set and just use their bitz, right? Edited September 11, 2017 by ThePumpkinTribunal Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4883277 Share on other sites More sharing options...
Macabre Slanneshi Prince Posted September 11, 2017 Share Posted September 11, 2017 Yeah. That, a Deathwatch shoulder pad sprue and a dollars worth of mark iii chainswords from Ebay should set you on basic Bolter and Chainsword Vets. Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4883538 Share on other sites More sharing options...
bluntpencil Posted September 21, 2017 Share Posted September 21, 2017 I've used Mark III Chainswords too, they work perfectly. Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4891653 Share on other sites More sharing options...
Vel'Cona Posted September 21, 2017 Share Posted September 21, 2017 Going to pile in on the Mk 3 swords, they have a smaller "sabre" design that speaks of a secondary as opposed to primary armament, which makes sense given DW Veterans tend to pour on SIA firepower before drawing blades for close quarters. Well, the sensible ones anyway :P Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4892082 Share on other sites More sharing options...
Cap'm Heckus Posted September 21, 2017 Share Posted September 21, 2017 The Chaos marines kit has a fair number of lefties. If you shave off the arrows they look nice as a DW silver arm. Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4892201 Share on other sites More sharing options...
Aothaine Posted September 28, 2017 Share Posted September 28, 2017 Depending on how careful you are you can also just cut the weapons off the hands and switch the weapons. Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4898051 Share on other sites More sharing options...
Brother_Gneecapper Posted September 28, 2017 Share Posted September 28, 2017 Black Templar Upgrade sprues have alot of chainswords in both hands and come with a nifty chain around them. The bolters also come with the chains on it. The main downside I'd see is that they can be somewhat difficult to find available, most BT players buying them up as they come in stock. Vel'Cona 1 Back to top Link to comment https://bolterandchainsword.com/topic/339213-deathwatch-and-chainswords-in-8th-ed/#findComment-4898141 Share on other sites More sharing options...
