micahwc Posted November 11, 2017 Author Share Posted November 11, 2017 Got all my little guys based, base coated, and dipped last night. Need to start drybrushing them all still. They are no longer a unpainted grey hoard, now they are a painted grey hoard. Pic was after basing but before any paint was added. http://i.imgur.com/1rODKsL.jpg Models were base coated in a two tone grey paint scheme and dipped in a black ink mix. I'm not sure if I like it or not as the ink darkened everything a lot, but I tried several other colors for shading and none of them looked right. As an aside, I think the cadian models look a lot better with back packs added. @Duz, I wish. I am starting to get comfortable with the slicing software aspect of 3d printing but I am very inexperienced when it comes to manipulating STL files. I'm getting them from thingiverse. My father-in-law is starting a business doing freelance CAD work and they wanted someone with experience in 3d printing, so I bought a monoprice select mini 2 just to play around with it and figure out the slicing software. He and his business partner do CAD for a living so the STL stuff is up to them. So far I've liked cura 3 the best out of multiple free slicing software titles I've tried. For manipulating STLs I've had the most success with meshmixer, but have been pretty limited to simple shapes or modifying someone else's file. I removed a turret off a Leman Russ to seperate it into a seperate print, but that's about the most I've done with STL files. walter h and Guardsman Bob 2 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4929737 Share on other sites More sharing options...
micahwc Posted November 12, 2017 Author Share Posted November 12, 2017 Been working on a shadowsword. I will buy an actual name blade kit someday, but for now this will do. http://i.imgur.com/LtDGphn.jpg Each of these five pieces took 5 hours of printing. The sixth is printing right now. Halfpint100 1 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4930116 Share on other sites More sharing options...
micahwc Posted November 12, 2017 Author Share Posted November 12, 2017 http://i.imgur.com/6PxjlpG.jpg About 200?more thin coats to go. Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4930348 Share on other sites More sharing options...
micahwc Posted November 14, 2017 Author Share Posted November 14, 2017 http://i.imgur.com/NM5qnqV.jpg http://i.imgur.com/bIpQ8HK.jpg Starting to look like a shadow sword. I've got some details left to print and glue on, and then some sanding and gap filing before it will be ready to paint. Halfpint100 and Azekai 2 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4931362 Share on other sites More sharing options...
micahwc Posted November 14, 2017 Author Share Posted November 14, 2017 Need to print the engine, sponsons, and heavy bolters still. I'm thinking about switching to plastic card for the armor detail, although I could print that easily enough I think it would a lot faster just to cut it out from card by hand. Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4931363 Share on other sites More sharing options...
micahwc Posted November 15, 2017 Author Share Posted November 15, 2017 Had a productive day today. I got the engine printed and glued to the shadowsword. I sanded it all over and filled some gaps and seams with bondo spot putty. Sanded the bondo down once it dried. While waiting for the engine to print I started painting my infantry. I discovered that I could paint pretty tiny detail using my Badger Krome and it's .2 nozzle, so I got all my guard infantry painted up. Still need to do the scions and Commisars. I've had a tough time getting the head lights for the shadowsword to print correctly. I've tried it twice and it's failed both times. Argh. Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4931912 Share on other sites More sharing options...
micahwc Posted November 15, 2017 Author Share Posted November 15, 2017 http://i.imgur.com/JbqM0wF.jpg http://i.imgur.com/FJooIGL.jpg http://i.imgur.com/EgjzpnJ.jpg http://i.imgur.com/Fg5bUpB.jpg http://i.imgur.com/tqmgMRC.jpg duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4931968 Share on other sites More sharing options...
micahwc Posted November 16, 2017 Author Share Posted November 16, 2017 Almost done with my shadowsword. I've got all the weapons installed. I put bondo over everything to help smooth it out. I have a lot of sanding yet to do. I'm running quad sponsons with a twist; there are only two sponsons of heavy bolters, each lascannon turret has 2 lascannons instead of 1, and a third turret with 4 heavy bolters was mounted on top (theoretically for anti air). All the turrets and sponsons can move. http://i.imgur.com/pnWfLDL.jpg http://i.imgur.com/kYA8A1U.jpg http://i.imgur.com/gpUbBEd.jpg http://i.imgur.com/EZyfFFc.jpg http://i.imgur.com/cTiIUsO.jpg http://i.imgur.com/KJv5Dc9.jpg This will be part of the Valhallan First Heavy Tank regiment. Fluff says they have at least one shadowsword. It will be my armies centerpiece, my Magnus/Mortarion/Gman. It will have a name. I'm leaning towards "Glory of Valhalla", but have considered some others. duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4933031 Share on other sites More sharing options...
WarriorFish Posted November 16, 2017 Share Posted November 16, 2017 You're making very fast progress! :tu: Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4933053 Share on other sites More sharing options...
micahwc Posted November 17, 2017 Author Share Posted November 17, 2017 http://i.imgur.com/AOlSYlJ.jpg http://i.imgur.com/IJ4c6Vw.jpg Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4933584 Share on other sites More sharing options...
micahwc Posted November 17, 2017 Author Share Posted November 17, 2017 Attacked it with the bitz box and primed it. http://i.imgur.com/aGkbJAD.jpg http://i.imgur.com/1lUhgys.jpg http://i.imgur.com/HSTHxxi.jpg http://i.imgur.com/ilQriW3.jpg http://i.imgur.com/cRPag1F.jpg http://i.imgur.com/hcJz6LB.jpg http://i.imgur.com/Y5Xtrp0.jpg http://i.imgur.com/UScliOb.jpg I'm pretty happy with it. our_baz 1 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4933628 Share on other sites More sharing options...
Silas7 Posted November 17, 2017 Share Posted November 17, 2017 I say, sanding it down and smoothing it over with wall filler was a good call. The over-all quality of the model is much improved, nice work. micahwc and duz_ 2 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4934390 Share on other sites More sharing options...
micahwc Posted November 20, 2017 Author Share Posted November 20, 2017 I managed to drop a box with all my infantry models in it, good news is I've identified which models didn't have the best bonds and will get to correct that issue. Erg. I've painted the shadowsword in like 3 different schemes and haven't been satisfied with it yet. Right now it's just a solid dark blue grey color that I've used on everything else in my army. Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4936492 Share on other sites More sharing options...
Tyr13 Posted November 21, 2017 Share Posted November 21, 2017 Hm... Id probably try to add some more detail to the shadowsword, the front looks a bit too smooth atm... maybe add some rivets, plasticard armour plates, that kind of stuff? I mean, its fine as is, but some rivets would probably be a good way to get it from "fine" to "awesome". :) Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4937204 Share on other sites More sharing options...
micahwc Posted November 21, 2017 Author Share Posted November 21, 2017 Good point. I'll see what I can do. Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4937267 Share on other sites More sharing options...
Tyr13 Posted November 21, 2017 Share Posted November 21, 2017 Itd also make painting easier, since youd be adding some texture to highlight, drybrush, wash or otherwise mess with. :) Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4937346 Share on other sites More sharing options...
micahwc Posted November 22, 2017 Author Share Posted November 22, 2017 http://i.imgur.com/F2E0t5Y.jpg http://i.imgur.com/oholyEm.jpg http://i.imgur.com/Utvx5di.jpg http://i.imgur.com/covhD4r.jpg http://i.imgur.com/d6mgh4T.jpg Did some basecoating and got something in happy with after a few tries. our_baz, duz_ and WarriorFish 3 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4937657 Share on other sites More sharing options...
duz_ Posted November 22, 2017 Share Posted November 22, 2017 Like the scheme looks good! Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4938050 Share on other sites More sharing options...
iceman2160 Posted November 22, 2017 Share Posted November 22, 2017 I wish that I could do a camo scheme that looked as good as that. Any time I try one it ends up looking like my 9 year old dumped some paint pots on it. micahwc 1 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4938058 Share on other sites More sharing options...
micahwc Posted November 22, 2017 Author Share Posted November 22, 2017 I cheated. I used my 3d printer to print out an airbrush stencil. Then I airbrushed it all a solid base color, and started stenciling in the other two colors (one at a time) until it looked good to me. I found the best results from sections of the stencil where there where lots of holes in kind of a row, I would spray paint, move the stencil slightly, spray it again, move it maybe an 1/8 inch and spray again. If I didn't like how a section looked I just kept going over it until it looked better. The closer you can get the stencil to the tank, the sharper the lines will be, the farther the stencil the more blurry the lines will be. I wanted relatively sharp lines so I tried to get the stencil touching as much as possible. If you don't have an airbrush you could probably replicate it with spray cans pretty easily with a larger stencil to contain the over spray. The Ergonomic Enginseer, iceman2160, Halfpint100 and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4938141 Share on other sites More sharing options...
WarriorFish Posted November 22, 2017 Share Posted November 22, 2017 I made myself more efficient. Fixed the first sentence for you I've seen some stencil stuff online that seemed ok, but for what is mostly a glorified series of holes always felt a little pricey. Main issue was that you'd have to find what you needed, so micahwc's creation of his own stencil is a much better idea I think :) Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4938271 Share on other sites More sharing options...
micahwc Posted November 22, 2017 Author Share Posted November 22, 2017 https://www.thingiverse.com/thing:2222870 I stole someone else's stencil and printed it. Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4938276 Share on other sites More sharing options...
micahwc Posted November 24, 2017 Author Share Posted November 24, 2017 2000 point game tonight. Don't know who against yet, the player has a lot of excellently painted Death Guard and Blood Angels. Same guy I played last time. This time I will be incorporating my missile teams into my infantry squads to keep them firing longer. I will be bringing the Shadow Sword because it's a freakin Shadow Sword. I'm debating about Yarrick, I haven't really liked him so far but re-rolling 1s on the Volcano Cannon would be nice. I am also thinking about maybe bringing conscripts for the first time ever, just a single large blob of 30 or so. I'm playing Valhallan, so I can bring the pistol relic and get a pseudo-commissar effect. My scion battalion will show up as they have been my best far objective grabbers / assassins so far. I'll probably run the tank commander punishers with sponsons, maybe bring plasma sponsons instead of heavy bolter sponsons since I'll most likely be facing marines of some variety. Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4940037 Share on other sites More sharing options...
micahwc Posted November 24, 2017 Author Share Posted November 24, 2017 (edited) My list for tonight is 4 detachments, 12 command points. Battalion 1 2 Tank Commander Executioners with plasma sponsons and storm bolter 3 Infantry Squads with missile launcher, plasma gun 2 Banewolves, chem cannon and heavy bolter Battalion 2 2 Tempestor Primes with plasma pistol and power mauls 6x scions, 2 melta 5x scions, 2 plasma 5x scions, 2 plasma Battalion 3 Company Commander with bolt pistol, chain sword (Pietrov's 45?) Company Commander with plasma pistol, power maul 3x infantry squads with missile launcher, plasma gun Superheavy Auxiliary Detachment Shadowsword, 10x Heavy Bolters, 4x Lascannons, Volcano Cannon Edit: As an aside, I wish they would let us form platoons for purposes of deployment, kind of like how vehicle squadrons can deploy together. Say a platoon consists of 1 platoon commander, 2 infantry squads, and can take a heavy/special weapon squad as an option, and then all deploy as one deployment, but act independently in the course of the game. That would help a lot with the number of placements we have to make. Edited November 24, 2017 by micahwc Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4940058 Share on other sites More sharing options...
micahwc Posted November 25, 2017 Author Share Posted November 25, 2017 (edited) I lost but it was a good game and we both had fun. Highlights include my shadowsword taking 13 wounds off a wraithknight in one shot, bane wolves killing a bunch of wraith guard, said banewold exploding and killing off his warlocks and wraith guard, and my shadowsword exploding which killed off just about everything friend and foe within 8" Edited November 25, 2017 by micahwc duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/339931-officially-starting-guard-finally/page/5/#findComment-4940484 Share on other sites More sharing options...
