hushrong Posted October 3, 2017 Share Posted October 3, 2017 Sorry if this seems trivial but I need a little bit of help and do not have rulebook handy. I am simply curious as to what counts as being slain. I have noise marines with the Music of the Apocalypse rule that trigger once they are slain. My NM being shot at range or cut down in melee by the enemy surely counts. And once all the enemy's attacks are done and wounds are applied a NM could shoot his sonic blaster before being removed thanks to the special rule for example. I was curious though in a situation where my opponent targeted a rhino, destroys it, and it explodes which results in a nearby noise marine taking a mortal wound. Does that noise marine count as being slain even though he was not the direct target? Link to comment https://bolterandchainsword.com/topic/340061-slain-definition-help-please/ Share on other sites More sharing options...
Gentlemanloser Posted October 3, 2017 Share Posted October 3, 2017 A model is Slain when it loses it's last wound. Chmur and hushrong 2 Back to top Link to comment https://bolterandchainsword.com/topic/340061-slain-definition-help-please/#findComment-4901839 Share on other sites More sharing options...
WingCommander Posted October 3, 2017 Share Posted October 3, 2017 (edited) Rulebook, p.181: If a model's wounds are reduced to 0, it is either slain or destroyed and removed from play. Regarding MotA it doesn't matter how the model was slain. So, yes, you can make the shooting attack. Edited October 3, 2017 by WingCommander hushrong 1 Back to top Link to comment https://bolterandchainsword.com/topic/340061-slain-definition-help-please/#findComment-4901860 Share on other sites More sharing options...
hushrong Posted October 3, 2017 Author Share Posted October 3, 2017 Thank you gentlemen! This clears it up perfectly! Link to comment https://bolterandchainsword.com/topic/340061-slain-definition-help-please/#findComment-4901988 Share on other sites More sharing options...
