Finkmilkana Posted January 9, 2018 Share Posted January 9, 2018 But a strategem cannot target said Bloat Drone because it's not technically part of the Daemon army. It's all in the keywords and descriptions of powers and abilities. Stratagems should also work, as long as you have a separate detachment that allows the use of the stratagem. Commissar K. 1 Back to top Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978403 Share on other sites More sharing options...
Commissar K. Posted January 9, 2018 Share Posted January 9, 2018 Well no, their faction isn't Daemons and that's where the problem lies. However, you can take them in a separate detachment and they will still gain any bonuses or buffs from Daemons that aren't strategem related. So for example, any aura or AoEs will work on, say, a Bloat Drone. But a strategem cannot target said Bloat Drone because it's not technically part of the Daemon army. It's all in the keywords and descriptions of powers and abilities. I do not believe this has to be the case, as Marks of Chaos are amongst the Faction Keywords and this way I do believe you can still use all the Stratagems for the particular Faction where all are part of. In the case of the Bloat Drone the Faction can be Nurgle, this way I do believe you can use the Death Guard stratagems from codex Death Guard and the Daemon stratagems from codex Chaos Daemons. But I do understand your line of thought here. It could be that GW wants to have it work like you said but there is currently nothing that enforces or limits the use of these Stratagems as far as I know. Having said that I don't own the Codex Chaos Daemons yet. Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978413 Share on other sites More sharing options...
Mileposter Posted January 9, 2018 Share Posted January 9, 2018 Well no, their faction isn't Daemons and that's where the problem lies. However, you can take them in a separate detachment and they will still gain any bonuses or buffs from Daemons that aren't strategem related. So for example, any aura or AoEs will work on, say, a Bloat Drone. But a strategem cannot target said Bloat Drone because it's not technically part of the Daemon army. It's all in the keywords and descriptions of powers and abilities.I do not believe this has to be the case, as Marks of Chaos are amongst the Faction Keywords and this way I do believe you can still use all the Stratagems for the particular Faction where all are part of. In the case of the Bloat Drone the Faction can be Nurgle, this way I do believe you can use the Death Guard stratagems from codex Death Guard and the Daemon stratagems from codex Chaos Daemons. But I do understand your line of thought here. It could be that GW wants to have it work like you said but there is currently nothing that enforces or limits the use of these Stratagems as far as I know. Having said that I don't own the Codex Chaos Daemons yet. This isn't how it works. You must have a FULL detachment (excluding Auxiliary Support Detachment) of Death Guard to have access to Death Guard Stratagems. You must then also have a FULL detachment (excluding Auxiliary Support Detachment) of Daemons to have access to the Daemons Stratagems. However, once you have access to either set of Stratagems, you can target ANYONE in your entire army with any Stratagem so long as the Keywords are appropriate. Thus, to use the Foetid Bloat-Drone example, a Foetid Bloat-Drone can be targeted by any Stratagem that affects the Daemon/Chaos/Nurgle/Death Guard keywords, regardless of source (unless, of course, the Stratagem in question has extra restrictions). Panzer, Commissar K., The Traitor and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978433 Share on other sites More sharing options...
Panzer Posted January 9, 2018 Author Share Posted January 9, 2018 Well no, their faction isn't Daemons and that's where the problem lies. However, you can take them in a separate detachment and they will still gain any bonuses or buffs from Daemons that aren't strategem related. So for example, any aura or AoEs will work on, say, a Bloat Drone. But a strategem cannot target said Bloat Drone because it's not technically part of the Daemon army. It's all in the keywords and descriptions of powers and abilities. I do not believe this has to be the case, as Marks of Chaos are amongst the Faction Keywords and this way I do believe you can still use all the Stratagems for the particular Faction where all are part of. In the case of the Bloat Drone the Faction can be Nurgle, this way I do believe you can use the Death Guard stratagems from codex Death Guard and the Daemon stratagems from codex Chaos Daemons. But I do understand your line of thought here. It could be that GW wants to have it work like you said but there is currently nothing that enforces or limits the use of these Stratagems as far as I know. Having said that I don't own the Codex Chaos Daemons yet. The Nurgle faction keyword has literally nothing to do with being able to use the Death Guard Stratagems. You need a Death Guard detachment. Period. Same for Daemons. To be able to use Daemon Stratagems you need a Daemon detachment (note the difference between faction keyword Daemon and regular keyword Daemon when building lists!) Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978440 Share on other sites More sharing options...
Khornestar Posted January 9, 2018 Share Posted January 9, 2018 1 HQ and 1 TROOPS selection is all it takes for a detachment, so it's not so hard to pull that off (in case anyone didn't know). Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978518 Share on other sites More sharing options...
Skallagoose Posted January 9, 2018 Share Posted January 9, 2018 1 HQ and 1 TROOPS selection is all it takes for a detachment, so it's not so hard to pull that off (in case anyone didn't know). Aux detachments can literally be 1 unit of anything. It just costs 1 cp to field Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978662 Share on other sites More sharing options...
Mileposter Posted January 9, 2018 Share Posted January 9, 2018 1 HQ and 1 TROOPS selection is all it takes for a detachment, so it's not so hard to pull that off (in case anyone didn't know).Aux detachments can literally be 1 unit of anything. It just costs 1 cp to field Auxiliary Detachments do not qualify for Stratagems (noted in the Stratagems sections). Plaguecaster and Khornestar 2 Back to top Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978672 Share on other sites More sharing options...
Panzer Posted January 9, 2018 Author Share Posted January 9, 2018 1CP wouldn't hurt much in a Daemon army, but for CSM/DG 1CP is a lot. ^^ Also what Mileposter said. Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978677 Share on other sites More sharing options...
Khornestar Posted January 9, 2018 Share Posted January 9, 2018 Yes, a detachment that allows stratagem use is what I was implying. Nurglings and a cheap herald, should one so desire, are probably the cheapest. Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978733 Share on other sites More sharing options...
DominikB Posted January 9, 2018 Share Posted January 9, 2018 Well no, their faction isn't Daemons and that's where the problem lies. However, you can take them in a separate detachment and they will still gain any bonuses or buffs from Daemons that aren't strategem related. So for example, any aura or AoEs will work on, say, a Bloat Drone. But a strategem cannot target said Bloat Drone because it's not technically part of the Daemon army. It's all in the keywords and descriptions of powers and abilities. I was under the understanding that faction keywords are the same as other keywords once the game starts and hence no reason why you can’t. I can use a DG strategem on a CSM unit as long as the keywords match up (and I have the correct detachments) Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978843 Share on other sites More sharing options...
Khornestar Posted January 9, 2018 Share Posted January 9, 2018 (edited) That’s correct. Might even be quoted more than once in this thread, originally in the Death Guard FAQ. As long as the target of a stratagem is an appropriate target (e.g. can’t target something that stipulates daemon keyword when it doesn’t have the daemon keyword, like a cultist) it works. Edited January 9, 2018 by Juggernut Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978854 Share on other sites More sharing options...
Cheex Posted January 9, 2018 Share Posted January 9, 2018 (edited) Ignore, I've been on a roll with illiteracy lately. Edited January 9, 2018 by Cheex Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978857 Share on other sites More sharing options...
Panzer Posted January 9, 2018 Author Share Posted January 9, 2018 Well no, their faction isn't Daemons and that's where the problem lies. However, you can take them in a separate detachment and they will still gain any bonuses or buffs from Daemons that aren't strategem related. So for example, any aura or AoEs will work on, say, a Bloat Drone. But a strategem cannot target said Bloat Drone because it's not technically part of the Daemon army. It's all in the keywords and descriptions of powers and abilities. I was under the understanding that faction keywords are the same as other keywords once the game starts and hence no reason why you can’t. I can use a DG strategem on a CSM unit as long as the keywords match up (and I have the correct detachments) That's right, however CSM Daemon Engines don't have the Daemon faction keyword. They have it only as regular keyword. So if you'd put CSM Daemon engine units in the same detachment as Codex Daemon units it would be a mixed Chaos detachment and not a daemon detachment. You can use Codex Daemon stratagems on CSM Daemon Engine units just fine, but you can't put both in the same detachment without losing access to those Stratagems (unless you have another pure Codex Daemon detachment on top of that one in your army of course). DominikB 1 Back to top Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978881 Share on other sites More sharing options...
DominikB Posted January 9, 2018 Share Posted January 9, 2018 Well no, their faction isn't Daemons and that's where the problem lies. However, you can take them in a separate detachment and they will still gain any bonuses or buffs from Daemons that aren't strategem related. So for example, any aura or AoEs will work on, say, a Bloat Drone. But a strategem cannot target said Bloat Drone because it's not technically part of the Daemon army. It's all in the keywords and descriptions of powers and abilities.I was under the understanding that faction keywords are the same as other keywords once the game starts and hence no reason why you can’t. I can use a DG strategem on a CSM unit as long as the keywords match up (and I have the correct detachments) That's right, however CSM Daemon Engines don't have the Daemon faction keyword. They have it only as regular keyword. So if you'd put CSM Daemon engine units in the same detachment as Codex Daemon units it would be a mixed Chaos detachment and not a daemon detachment.You can use Codex Daemon stratagems on CSM Daemon Engine units just fine, but you can't put both in the same detachment without losing access to those Stratagems (unless you have another pure Codex Daemon detachment on top of that one in your army of course). Yes that’s how I’ve understood it too! :) Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978912 Share on other sites More sharing options...
Daionosis Posted January 9, 2018 Share Posted January 9, 2018 Okay, that cleared it up, thanks! Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4978969 Share on other sites More sharing options...
DuskRaider Posted January 10, 2018 Share Posted January 10, 2018 Interesting, I thought Strategems could only target units from that specific army regardless of Keyword sharing. The more you know, I suppose. Link to comment https://bolterandchainsword.com/topic/341028-codex-chaos-daemons-first-in-2018/page/17/#findComment-4979129 Share on other sites More sharing options...
