H311fi5h Posted November 28, 2017 Share Posted November 28, 2017 I really would not recommend to rely on a single Shadowsword if you really want a Primarch dead in one turn. Sure, a Shadowsword does a lot of damage on average, but you don't always get average. For reliability you need to roll a larger number of dice. That means more guns with more shots. The Volcanon cannon can easily roll 5 shots, hit 2, wound 2, with both getting saved by Magnus' invuln. The chance of a shadowsword doing nothing against a Primarch is quite high. Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4944748 Share on other sites More sharing options...
Azarians Posted November 28, 2017 Share Posted November 28, 2017 Run a Supremcommand detachement. 1 Tempestor prime with some scions 1 primaris Psyker 1 Lord commissar Choose Vostroyan. Arm your Shadowdword. Use stratagem for +1 to hit. Now you hit Titanic on 2+ ! ;) Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4944756 Share on other sites More sharing options...
lash144 Posted November 28, 2017 Author Share Posted November 28, 2017 Hellhounds are sooo much fun, park in your opponents face and DARE him to destroy it, you can re-roll the exploads dice for fun If you have the points, add track guards. Nothing beats your opponents face when your 1 wound hellhound is still moving 12" and autohitting with its flamers, heavy flamer is a must! Do wonder if this has derailed the post though.............. However there is a use for them vs primarchs, if they are out in front, they may charge them and kill them in a turn = mortal wounds on the units within 6", or he ignores them and you roast something else with those lovely 3d6 (your taking the heavy flamer right?) autohits I don´t know if I´m the biggest fan of the HF on a Hellhound, since it´s not working well with the range of its main gun. And since I play Tallarn, I can still stick a Heavy Bolter on it and drive by ;) I really would not recommend to rely on a single Shadowsword if you really want a Primarch dead in one turn. Sure, a Shadowsword does a lot of damage on average, but you don't always get average. For reliability you need to roll a larger number of dice. That means more guns with more shots. The Volcanon cannon can easily roll 5 shots, hit 2, wound 2, with both getting saved by Magnus' invuln. The chance of a shadowsword doing nothing against a Primarch is quite high. Yeah thats also what I am worrying about. I just crunched some numbers and if you just look at the average and calculate a points for wounds value its pretty ridiculous how far ahead the Shadowsword is. I also don´t like the reliance on one model. Maybe I´m adding some AdMech Dunecrawlers with Icarus Arrays / Neutron Lasers in a Spearhead. Those look quite tasty and would make a good addition to my mechanised force. Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4944777 Share on other sites More sharing options...
CoffeeGrunt Posted November 28, 2017 Share Posted November 28, 2017 Run nothing but Ratlings. Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4944881 Share on other sites More sharing options...
noigrim Posted November 28, 2017 Share Posted November 28, 2017 (edited) Lascannon spam? Shadowsword? bubblewrap the previous two so they can't charge you with warp speed? Best way for dealing with those two is shooting that causes multiple wounds Edited November 28, 2017 by noigrim Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4944895 Share on other sites More sharing options...
librisrouge Posted November 29, 2017 Share Posted November 29, 2017 The answer, as we all clearly know, is the humble lasgun. 12 Infantry Squads or so, backed up with FRFSRF from their brave and brilliant officers, will clearly send any warp monstrosity running. If that should fail (hey, occasionally the enemy is lucky) then surely you are blessed by the Emperor with a fine opportunity to demonstrate your soldiers' proficiency with the mighty bayonet. We were already given the best weapon in the galaxy. You just need enough of them. :) FallenSoldiers, duz_, our_baz and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4945555 Share on other sites More sharing options...
FallenSoldiers Posted November 29, 2017 Share Posted November 29, 2017 The answer, as we all clearly know, is the humble lasgun. 12 Infantry Squads or so, backed up with FRFSRF from their brave and brilliant officers, will clearly send any warp monstrosity running. If that should fail (hey, occasionally the enemy is lucky) then surely you are blessed by the Emperor with a fine opportunity to demonstrate your soldiers' proficiency with the mighty bayonet. We were already given the best weapon in the galaxy. You just need enough of them. :) This man makes a fine officer!! Follow his lead, boys!!! BIG ROB OF DEATH, librisrouge, Are Verlo and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4945582 Share on other sites More sharing options...
lash144 Posted November 29, 2017 Author Share Posted November 29, 2017 The answer, as we all clearly know, is the humble lasgun. 12 Infantry Squads or so, backed up with FRFSRF from their brave and brilliant officers, will clearly send any warp monstrosity running. If that should fail (hey, occasionally the enemy is lucky) then surely you are blessed by the Emperor with a fine opportunity to demonstrate your soldiers' proficiency with the mighty bayonet. We were already given the best weapon in the galaxy. You just need enough of them. :) You aren't even wrong. In my game the Lasguns stripped of several wounds. Definitely more than my Lascanons. librisrouge 1 Back to top Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4945596 Share on other sites More sharing options...
Thorakitai Posted November 29, 2017 Share Posted November 29, 2017 The answer, as we all clearly know, is the humble lasgun. 12 Infantry Squads or so, backed up with FRFSRF from their brave and brilliant officers, will clearly send any warp monstrosity running. If that should fail (hey, occasionally the enemy is lucky) then surely you are blessed by the Emperor with a fine opportunity to demonstrate your soldiers' proficiency with the mighty bayonet. We were already given the best weapon in the galaxy. You just need enough of them. :) The one time I have faced Mortarion so far, I finished him off lasguns. It was a glorious moment. Of course, other stuff did most of the work. librisrouge 1 Back to top Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4945686 Share on other sites More sharing options...
FallenSoldiers Posted November 29, 2017 Share Posted November 29, 2017 My Lowly Conscripits (pre nerf) finished off Bobby G in one tournament. I definitely think weight if lasgun fire should never be underestimated! librisrouge 1 Back to top Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4945760 Share on other sites More sharing options...
Zectz Posted November 30, 2017 Share Posted November 30, 2017 Have you tried Old Grudges warlord trait? That thing is amazing vs these kind of problem units like Primarchs or Knights. I know you'd have to give up Grand Strategist for it but in these specific games it's so worth it. Halfpint100, librisrouge, H311fi5h and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4946536 Share on other sites More sharing options...
Halfpint100 Posted November 30, 2017 Share Posted November 30, 2017 Have you tried Old Grudges warlord trait? That thing is amazing vs these kind of problem units like Primarchs or Knights. I know you'd have to give up Grand Strategist for it but in these specific games it's so worth it. I had forgot that was a thing! that changes a lot! Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4946539 Share on other sites More sharing options...
bigmic66 Posted December 1, 2017 Share Posted December 1, 2017 Sorry, pask in Russ, tagging a wound on primarch to trigger cadian strategum overlapping fields of fire. Link to comment https://bolterandchainsword.com/topic/341779-dealing-with-primarchs/page/2/#findComment-4947383 Share on other sites More sharing options...
