Rogue Posted December 28, 2017 Share Posted December 28, 2017 For the same points, I can mount four lascannon on a predator chassis or on a venerable dreadnought. There seems to be lot of love for the predator at the moment, but the venerable dreadnought gives me better accuracy (2+ vs 3+) and the option to utilise the Wisdom stratagem. The dreadnought has the same toughness, although fewer wounds, but does gain a 6+ FNP save. And it doesn’t degrade when damaged. So is it all about personal preference, or have I missed something important? Link to comment https://bolterandchainsword.com/topic/342777-four-lascannon-predator-vs-venerable-dreadnought/ Share on other sites More sharing options...
jerrys Posted December 28, 2017 Share Posted December 28, 2017 (edited) I haven't been keeping up on current events... but the last I knew you couldn't do a 2x twin lascannon on a dreadnought; you could do either 2x twin autocannon or 1x twin lascannon plus 1x double missile launcher. It could be that it changed recently? But I hadn't heard of that. If you can do that, the dreadnought is pretty tempting (hitting on 2+ is good). Another interesting option is 2x twin lascannon razorbacks, which between the two of them are a little more expensive than the predator but have a lot more wounds. Edited December 28, 2017 by jerrys Link to comment https://bolterandchainsword.com/topic/342777-four-lascannon-predator-vs-venerable-dreadnought/#findComment-4969412 Share on other sites More sharing options...
Syphid Posted December 29, 2017 Share Posted December 29, 2017 (edited) Not sure how you put four lascannons n a venerable dreadnought. You can put four on a mortis dreadnought, but not venerable afaik. Edited December 29, 2017 by Syphid Link to comment https://bolterandchainsword.com/topic/342777-four-lascannon-predator-vs-venerable-dreadnought/#findComment-4969841 Share on other sites More sharing options...
Rogue Posted December 29, 2017 Author Share Posted December 29, 2017 Oh. Bother. My fault for not reading the codex properly. I don’t have mine to hand right now, so I’m not sure what I read wrong. Probably just an assumption that I could do the lascannon equivalent of the quad auto-cannon thing having seen it on a mortis somewhere. Missile launchers next time, then. Link to comment https://bolterandchainsword.com/topic/342777-four-lascannon-predator-vs-venerable-dreadnought/#findComment-4969935 Share on other sites More sharing options...
Stickeh Posted December 31, 2017 Share Posted December 31, 2017 Mortis and and contemptor Mortis dreadnoughts can indeed mount two twin lascannons, however they’re a forge world unit only. Link to comment https://bolterandchainsword.com/topic/342777-four-lascannon-predator-vs-venerable-dreadnought/#findComment-4971426 Share on other sites More sharing options...
Kilofix Posted December 31, 2017 Share Posted December 31, 2017 On 12/31/2017 at 9:01 PM, Stickeh said: Mortis and and contemptor Mortis dreadnoughts can indeed mount two twin lascannons, however they’re a forge world unit only. Contemptor Morris with BS2 and 5++ is awesome. Link to comment https://bolterandchainsword.com/topic/342777-four-lascannon-predator-vs-venerable-dreadnought/#findComment-4971431 Share on other sites More sharing options...
Melete Posted January 3, 2018 Share Posted January 3, 2018 A 2x Twin Las Contemptor Mortis edges out a 4x Las Predator pretty comfortably (one extra wound shooting at Leman equivalents before auras), and does have that 5++. That's probably the choice to make, although price-wise it's quite a bit more expensive to buy the model. And you figure FW models are more likely to have wild point swings this edition if this past Chapter Approved is anything to go by. Link to comment https://bolterandchainsword.com/topic/342777-four-lascannon-predator-vs-venerable-dreadnought/#findComment-4972963 Share on other sites More sharing options...
Iron Father Ferrum Posted January 3, 2018 Share Posted January 3, 2018 Don't forget the ever present caveat emptor on FW models too. The Predator will be universally acceptable, but some clubs/TOs don't allow FW. Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/342777-four-lascannon-predator-vs-venerable-dreadnought/#findComment-4973123 Share on other sites More sharing options...
