Brother_Darius Posted January 2, 2018 Share Posted January 2, 2018 I am working on my LS Darkshroud and wanted to know how did they/do you, get that stained glass effect on canopy? Link to comment https://bolterandchainsword.com/topic/342944-painting-stained-glass-effect/ Share on other sites More sharing options...
Carlson793 Posted January 3, 2018 Share Posted January 3, 2018 You could try using Citadel's glazes, shades*, and 'gem' technical paints. (*either the gloss ones or, for more colors, shade + 'Ardcoat) Link to comment https://bolterandchainsword.com/topic/342944-painting-stained-glass-effect/#findComment-4972846 Share on other sites More sharing options...
Brother_Darius Posted January 3, 2018 Author Share Posted January 3, 2018 I was hopeful for maybe a tutorial. I'm a little worried about getting it right, as I think it wilk be hard to correct if done poorly. Link to comment https://bolterandchainsword.com/topic/342944-painting-stained-glass-effect/#findComment-4972929 Share on other sites More sharing options...
Imren Posted January 3, 2018 Share Posted January 3, 2018 I was hopeful for maybe a tutorial. I'm a little worried about getting it right, as I think it wilk be hard to correct if done poorly. This is what you're looking for: 1 Back to top Link to comment https://bolterandchainsword.com/topic/342944-painting-stained-glass-effect/#findComment-4973052 Share on other sites More sharing options...
Carlson793 Posted January 3, 2018 Share Posted January 3, 2018 An alternative would be create the images you want the stained glass to look like and print to clear decal paper. They will still be see through, so will give the stained glass effect when placed on a clear surface. Link to comment https://bolterandchainsword.com/topic/342944-painting-stained-glass-effect/#findComment-4973191 Share on other sites More sharing options...
Semper Fortis Posted January 4, 2018 Share Posted January 4, 2018 I used Pebeo Vitrail clear glass paint to do several dozen stained glass windows on a terrain piece I once built. The effect was stunning. I actually went on to use it for a "stained glass" window for my game room - an Aquila. The downside is that it's expensive, is solvent based, and you would have to do a small test patch on an edge of the piece to make sure it's compatible. Alternately, there are the clear acrylic paints Forge World make. I imagine that would be impressive with a led light in the cockpit back lighting the canopy. Link to comment https://bolterandchainsword.com/topic/342944-painting-stained-glass-effect/#findComment-4973690 Share on other sites More sharing options...
Bryan Blaire Posted January 4, 2018 Share Posted January 4, 2018 I am working on my LS Darkshroud and wanted to know how did they/do you, get that stained glass effect on canopy?Are you talking about the enclosed canopy on the left side of the vehicle midway back if you are looking at the Speeder's nose? The one made up of all the little arches and the inlaid DA symbol? If so, there's no clear canopy there, so no clear tints, etc., suggested above are going to work on their own, you'll just end up with a colored mess over grey, which won't look like stained glass. You are going to need to paint it with standard acrylic colors and the gloss coat them, or paint them with the gemstone paints, as suggested above, or you could paint them with a white shaded/tinted pale blue, and then use the tint paints over them, then gloss. Shade the edges of the windows with a gloss shade, to keep the glass appearance. As far as colors, that really depends on the effect you are trying to make. A little more information might allow someone to point you to a helpful tutorial. 1 Back to top Link to comment https://bolterandchainsword.com/topic/342944-painting-stained-glass-effect/#findComment-4973712 Share on other sites More sharing options...
Brother_Darius Posted January 5, 2018 Author Share Posted January 5, 2018 I am working on my LS Darkshroud and wanted to know how did they/do you, get that stained glass effect on canopy?Are you talking about the enclosed canopy on the left side of the vehicle midway back if you are looking at the Speeder's nose? The one made up of all the little arches and the inlaid DA symbol? If so, there's no clear canopy there, so no clear tints, etc., suggested above are going to work on their own, you'll just end up with a colored mess over grey, which won't look like stained glass. YES!!!! That is the portion I am trying to do. Link to comment https://bolterandchainsword.com/topic/342944-painting-stained-glass-effect/#findComment-4974387 Share on other sites More sharing options...
Bryan Blaire Posted January 5, 2018 Share Posted January 5, 2018 That is the portion I am trying to do.Alrighty, you may want to try something like this on each individual window: 1 Back to top Link to comment https://bolterandchainsword.com/topic/342944-painting-stained-glass-effect/#findComment-4974408 Share on other sites More sharing options...
Brother Lunkhead Posted January 5, 2018 Share Posted January 5, 2018 Thanks Brothers Imren and Bryan for the nice tutorial vids ..... I'm always learning from others. Link to comment https://bolterandchainsword.com/topic/342944-painting-stained-glass-effect/#findComment-4974414 Share on other sites More sharing options...
