CaptainHelion Posted February 4, 2018 Share Posted February 4, 2018 (edited) Tactics for Units: Dominions Welcome back, after rather more of a break than intended, to Tactics for Units, a series of tactica articles focusing on Adeptas Sororitas units in 8th edition. Today, we’ll be looking at the most recent incarnation of one of the Sisters Militant’s most consistently bright stars; the Dominion squad. The Dominion is an Adepta Sororitas specialised in the use of a special weapon, and on the battlefield, they are often arranged into specialised units called, aptly, Dominion squads. Dominion squads have excellent maneuverability, which they leverage to bring their impressive firepower to bear at their opponent’s weakest points. Stats The Dominion squad has the same relatively average stats as the Battle Sister Squad. Of note, of course, is the BS3+, which helps them use their special weapons as needed. The 3+ save is good to help them stay alive, and their Leadership 7 (8 with the Superior) means the squad is unlikely to lose more models to Morale, should they take casualties. All things considered, an average but well rounded set of stats. Nothing special, by the standards of the Sororitas, but perfectly serviceable. Special Rules Dominions have three Special Rules; the army-wide Acts of Faith and Shield of Faith, and their unique rule Vanguard. Acts of Faith is one of the defining rules for Adeptas Sororitas, and the Dominion squad is no different. This rule allows, on the roll of a 2+, one unit in your army to make an out of sequence action that occurs before the Movement Phase. Of particular interest to the Dominion squad is Hand of the Emperor, which allows the unit to make a move as if it were the Movement Phase. With the necessity of good positioning to maximise their special weapon fire, this is a golden option for the ladies. Similarly, Divine Guidance is great, as you bring these ladies for their guns, and this doubles the return on your investment. Not much more to say beyond that! Spirit of the Martyr is a perennial favourite, as bringing back slain models is always good, especially in a squad with large numbers of model-by-model upgrades such as Dominions. The Passion is… Well, not quite worthless, but I would caution against it. Even if you give your Superior a chainsword or power weapon, the number and quality of attacks is just so poor as to make it a waste of time. These ladies do not want to be in assault, so try and keep them out. If they DO end up in combat, consider using Divine Guidance and have them shoot their bolt pistols. You will lose out on perhaps one Strength 3 hit, but in exchange get +1 to hit and +1S. Better if you gave the Superior a plasma pistol. Shield of Faith is a neat and fluffy little rule that grants a 6++ Invulnerable save. Now, with a 3+ armour save, it is unlikely that you will find yourself getting less than a 6+ save after AP is applied, but for those few times when it does? Golden. It also grants a modified Deny the Witch roll, which allows the unit to Deny using a single d6. It isn’t going to come up particularly often, given the average roll on 2d6 is 7, but it might deny the occasional low-rolled Smite, or some of the newer low Warp Charge powers in more recent Codexes. It’s a Nice To Have but nothing big, overall. Vanguard is the unique special rule of the Dominions, and it is, really, one of the two main reasons you’d run Dominions. This rule allows a unit with it to make a Move before the game begins, but after player turn order is decided. If a vehicle is transporting only models with this rule, it can make this move, instead of the unit inside, even though it does not possess the rule itself. This is a fantastic rule, and allows you do easy redeploy your Dominion squads in reaction to your opponent’s deployments, or to advance a squad up into no-mans-land, giving them a head start on hunting something down, or capping an early objective.This is well worth the additional Points per Model or the extra Power of the Dominions, compared to their Battle Sister Squad contemporaries. Equipment The Dominions have the standard Adeptas Sororitas equipment of Bolter, Bolt Pistol, and Grenades of the Krak and Frag varieties. The squad begins at Five models (Four Dominions and a Dominion Superior), and can be expanded to Ten models. Up to Four models may replace their bolter with a weapon from the Special Weapons list, and the Superior can swap her bolter for another Ranged Weapon or a Melee Weapon and her Pistol for a different Pistol. Bolters are standard. Nice strength and range, but nothing special. Bolt pistols are great to have, as you can fire them whilst engaged in combat. Grenades are always worth mentioning, as one model per unit can throw one in the Shooting Phase. If you’re within 6” and you have a spare bolter Dominion, a grenade is definitely worth considering. Which one depends on what you’re throwing at. Frag gives you d6 S3 shots, which is best against anything with single wounds that isn’t T6 or more. The Krak grenade is a single S6 shot, but it has AP-1 and d3 Damage. It’s good against multiple wound things with decent armour saves, so vehicles, monstrous creatures, and characters that aren’t T3. Also, possibly 2+ saves, though that can go either way. Given the expanded capacity for special weapons, you will almost certainly be wanting to take at least a couple. If you’re taking more than one (and you should be, really), take the same kind. There’s no point trying to cover every base with one squad. Better to focus one one thing with each Dominion squad, and have redundancy and flexibility with the rest of your army. Meltaguns are the Big Game Hunter special weapon. High Strength, excellent AP, and d6 Damage make for a fairly scary Sister. However, the unreliability of d6 Damage, the point cost, the 12” range, and only one shot prevent this being an autotake in every situation. And to compound the short range, the special ability of the melta, roll 2d6 for damage and pick the highest, only occurs within half range. So your Dominions will be getting close to something in order to perform their best. Having four in a squad makes an expensive squad, but certainly helps prevent them doing nothing due to a couple of unlucky 1s. The prospect of up to 24 damage is pretty scary. Use to take down a big threat before it can give you trouble, and to hunt Characters. Be aware of Invulnerable saves, as AP-4 won’t matter if they deflect it with a storm shield. Flamers are a useful tool. They’re relatively cheap, they automatically hit their target, and they do d6 hits per flamer. Nothing special, and they only have 8” range, but being able to hit things automatically is great. It’s good when you’re up against things that have a -1 To Hit them, such as Raven Guard or Flyers. Stormbolters. We heard you like bolters. So we took two bolters and strapped them together. Now, you can bolter whilst you bolter. The Stormbolter is the last word in getting lots of S4 shots for not very much by way of point investment. Following Mathhammer, even factoring into account the Flamer’s Automatically Hitting ability, the Stormbolter still causes more unsaved wounds Per Point Spent. Note that that is Per Point, not in a vacuum. Stormbolters achieve this by being two bolters worth of fire for less than half the points of a Flamer. Compared weapon to weapon, the Flamer deals slightly more. The Superior can exchange their bolter for a Stormbolter, a Condemnor Boltgun or a Combi-weapon. The Stormbolter is a good idea if you are arming the rest of the squad with them, as it allows you to take 5 stormbolters, meaning the squad’s firepower at 5 models is the same as a barebones BSS at 10 models. Nice. The Condemnor Boltgun is a hard pass for me. Getting d3 Damage against psykers is nice, but functionally pointless against the majority of your opponent’s army even if they do bring psyker support. If you regularly face Thousand Sons or Grey Knights, then its utility goes up substantially, but that’s the only time. Combi weapons are great, as they allow you to take a 5th special weapon AND your bolter for only a little bit more than the cost of the two weapons. Obviously, pairing combimeltas and combiflamers with meltagun and flamer Dominions is a solid bet. Taking a different one to allow for some flexibility in terms of targets is an option, but I would caution against it, for the same reason as I caution against mixing special weapons. Dominions are specialised tools. Being able to take on any kind of threat is what Battle Sister Squads are for. The Combiplasma is interesting, as it is one of only two ways to get plasma into the Sisters army. For what you pay, you get a fair bit. A good strength and AP, and the option to boost the strength AND damage. It doesn’t pair with either melta or flamer in terms of targets, but makes a nice alternative to taking another Stormbolter in a Stormbolter filled squad. Just make sure never to overcharge and fire both guns at once. It doubles the likelyhood of an overheat as well as making you less likely to hit. The necessarily short ranges the Dominion squad will be operating at means that the special pistols have some interesting potential for your Superior. The Infernus pistol is very short range, and expensive, but boasts Melta stats and damage. The Plasma pistol is a great option, as it is relatively cheap and has the great plasma stats you see elsewhere. Remember these if you find your Dominions get charged after they arrive. As is always the case with pistols, the main draw is being able to shoot while engaged. Melee weapons are either the humble chainsword or the various kinds of Power Weapons. The Chainsword is a free swap for the bolter, and grants an extra attack in combat, bringing the Superior up to 3. Still at her mediocre WS4+ and S3, but it’s not bad, largely because you don’t pay any points for it. Power weapons range from the high AP Sword or the low AP but extra strength Maul, with the balance of the axe between the two. If you want a power weapon, the best bet is the maul, as the Strength boost is the most important buff you can give a Sister in close combat. The Axe isn’t a bad option if you’re unwilling to give up quite that much AP, but the sword, while really cool, just isn’t going to cause enough wounds to use the AP-3. Tactics Dominions have three main roles, which largely depend on which special weapon they take. However, all varieties benefit from fast, aggressive play. Maximise the special weapons you take, and get them moving as fast as they can towards their target. A transport is a solid investment, and in the case of Immolators provides valuable supporting fire. Meltagun Dominions are, as aforementioned, Big Game Hunters. They have powerful and deadly weapons, and can take out high threat targets relatively easily. Taking multiple meltaguns helps shore up their low firing rate, and their speed compensates for the short range. I take units with 3 meltaguns, but only because I have 6 meltaguns in my collection, and I like running two squads of meltagun dominions. Consider taking them with 4 meltaguns. Taking extra sisters is to taste, as it limits the transport they can take (As Immolators have a maximum capacity of 6 models), and they can’t carry meltaguns, so won’t be contributing heavily to the squad’s target, but do provide a cushion so the squad can take a few casualties without losing meltagun efficacy. Flamers are good for sweeping a unit off of a point or removing an annoying and hard to hit unit. They can put a lot of pain into a small space, and all that pain is hitting automatically. Things like Stealth Suits, are all good options. They’re also terrifying for an assault unit to try and charge. Extra sisters won’t auto hit, but provide a wound cushion, someone to throw a grenade, and extra bolter shots will still hurt the sort of thing flamers are good at hurting, though not as effectively. Stormbolters are fantastic at taking and holding objectives. They are relatively cheap, so can use their speed to get up close to an objective, and then use their enormous amount of bolterfire to kill anything on the objective, or anything trying to get close. Extra sisters are a solid idea, as this squad wants extra bodies to boost their survivability, and a stormbolter is still a kind of bolter. Beware of units with Objective Secured or similar rules, as Dominions will not be able to hold onto an objective against an ObSec unit. Overall, the Dominion squad is a fast, deadly squad that can be outfitted to suit a number of roles. They benefit from specialisation, but have the rules and options to support that. What are your opinions on Dominions? How do you use them? Do you have any disagreements with my take on things? Please go ahead and share! I look forward to hearing your thoughts. Edited February 5, 2018 by CaptainHelion dracpanzer and Atrus 2 Back to top Link to comment https://bolterandchainsword.com/topic/344072-tactics-for-units-dominion-squads/ Share on other sites More sharing options...
dracpanzer Posted February 4, 2018 Share Posted February 4, 2018 I don't find bringing extra bodies in a Dominion squad to be worth it. I would rather just use those points to field another squad of Dominons and their special weapons. The stormbolter Dominion is in my opinion the best of the three available. The cost of even one flamer is only one point less than equipping five girls with stormbolters. I would take take the guaranteed stormbolter shots any day over the flamers chance at getting a good overwatch off. I know a lot of players have a lot of flamers in their collection, I miss those templates too! I just don't see it as a viable return on your points in a competitive sense. Of course if you like lighting pyres if burning heretics (who doesn't) have at it. The meltagun is of course the heavy hitter and certainly you need to have them, but they are fickle, I cannot remember a game in 8ed where I didn't miss with at least one of the four meltaguns in a Dom squad EVERYTIME they fired in a game. Their AP is nice, but they aren't consistent enough to be the bulk of my Dominion force. A lot of what makes Dominions the Sisters "all star" unit is the transport they get to ride in. The Immolation Immolator is great, but the lack of fire points makes it less appealing for a Dom transport than a Repressor. That being said, the Immolation Immolator is a great spot to put a squad of five plain bolter Dominions you don't want to drop into a BSS just to get Vanguard for those lovely Immolation Flamers. Nothing says they HAVE to have special weapons right? The Repressor paired with Dominions who actually have special weapons really makes Dominions hit a lot harder than their point cost. I know most players don't have the models, but if you do, six squads of stormbolter Dominions in Repressors is an absolute buzzsaw and the best 1020 points you can put on the table. After bringing Celestine and the twins you have 730 points to further kit your army out and it is from these points that I purchase whatever number of Melta Doms I will be fielding. I always run them doubled up with one of my SB Dom squads so I grab one of those for the Superior and grab 4 meltaguns for the girls. They are expensive at 120 for the squad, but their SB Dom counterparts in that Repressor are there to take the wounds should the Repressor get knocked out. Generally the Melta Doms are there just to ride tag along unless there is a target worthy of their weapons. The mix allows me to put out 24 SB shots at 12" from the passengers, 28 with the Repressoes SB plus the heavy flamer. Or fire the four meltaguns at a hard target and still have have 8 SB shots from the passengers and 4 more from the Repressor to put into a softer target at the same time. This of course assumes you have the Repressor models (easy to convert) and that Forgeworld is allowed in your gaming space (not so easy if those spaces are convinced they are better at balance than GW and FW are). At any rate, I strongly believe that anything BSS can do, Doms do better at the 1 point additional cost of a Dominion to give you the Vanguard rule. Mounted or on foot, Sisters are better when they can close the distance to make our weapons work quicker. Link to comment https://bolterandchainsword.com/topic/344072-tactics-for-units-dominion-squads/#findComment-5002504 Share on other sites More sharing options...
Beams Posted February 4, 2018 Share Posted February 4, 2018 I like bringing extra bodies, especially if they aren't in a Reprrssor. A squad of 5 stormbolters and 5 Bolters puts out 30 shots at close range, 60 I'd you act of faith it. It also makes it harder for an opponent to wipe out your melta girls if they have to chew through a few wounds first. If they are in a transport, it helps to bring at least 1-2 Bolter girls, so when it blows up, you don't lose your melta girls. At least in my opinion. Link to comment https://bolterandchainsword.com/topic/344072-tactics-for-units-dominion-squads/#findComment-5002513 Share on other sites More sharing options...
ERJAK Posted February 4, 2018 Share Posted February 4, 2018 (edited) Adding extra bodies onto dominion squads isn't usually worth it. It's more cost efficient to lose a meltagun to an explosion than it is to run a chaff sister the majority of the time, simply due to the GUARANTEED opportunity cost of the chaff sister vs the relatively low probability of losing sisters in explosions. I will concede, however, that if you run repressors rather than Immolators, the chaff sister is more likely to be valuable. In my opinion, stormbolter doms in general are HIGHLY overrated. Basic battle sisters do the exact same job for cheaper and unlock additional CP through battalions. On top of that, they can actually benefit from a Canoness's rerolls (you don't lose anything for sharing a transport) and have ObSec. Combine this with the fact that scout doesn't really do much for the second longest range personnel weapon in the SoB army, and you're mostly just chewing up points, especially considering that rushing stormbolters up the field isn't particularly necessary anyway. Their real damage output against anything tougher than cultists isn't anything to write home about. 1 unit of 5 SB doms is fine for chaff clearing but it's more efficient to take battle sisters if you were planning on 2-3 units with Stormbolters. See DracPanzer for a different take on this. He's clearly had a different experience with Stormbolters than I have. In the games I've played with Stormbolter spam, all the cultist die turn one and then you're left shooting 1000pts of stormbolters into rhinos or plague marines or what have you and pinging off a handful of wounds per turn while your girls die in droves to things like foetid bloat drones, or carnifexes, or centurions, or stormravens. Your meta will likely determine which is more likely to be your experience (Though I still think a battalion is worth it's weight in gold if you were taking lots of SB anyway.) With dominions, it's the same story as 7th edition: Melta is KING. With Heavy Flamers, Immolation flamers, SBs, and HBs, you'll be able to rinse away hordes plenty fast, but those weapons struggle against high toughness or good saves. In my experience 4 units of melta doms is the breakpoint. 4 units is where you have enough punch to take out his big threats before they can become an issue. Generally my setups go 4x5 melta 1x5 SB 3x5 BSS with triple SB. Repressors are generally the better option for this, but immolators are only a few percent less efficient due to their autonomy and superior weaponry allowing you to do things like clear scouts out of cover or tie up a plagueburst crawler while the dominions do damage on the opposite side of the board. They are also less vulnerable to Deepstriking assault units. Edit: Never EVER take flamers. They are horrendously overpriced. Point for point they only beat stormbolters in overwatch, even hitting on 5s stormbolters do more damage per point. Edited February 4, 2018 by ERJAK dracpanzer 1 Back to top Link to comment https://bolterandchainsword.com/topic/344072-tactics-for-units-dominion-squads/#findComment-5002568 Share on other sites More sharing options...
dracpanzer Posted February 4, 2018 Share Posted February 4, 2018 I don't disagree with you Erjak. The SB's aren't melta's. But they are better than BSS even if its just for Vanguard. Rushing forward when going first or bouncing away when going second, I find Vanguard extremely useful. To second your thoughts, four squads of melta Doms piggy back nicely with my SB Doms and still leave points for a couple squads of HB Rets and a Canoness to watch the backfield plus a bit of vehicle upgrades. Link to comment https://bolterandchainsword.com/topic/344072-tactics-for-units-dominion-squads/#findComment-5002987 Share on other sites More sharing options...
Beams Posted February 4, 2018 Share Posted February 4, 2018 (edited) My thoughts on SB Dominions is they are cheap, and provide good anti horde. They can vanguard-move to get 6-12+ inches turn one, and the hold the midfield objectives, preferably if they are in cover. They aren't amazing, but they are cheap and provide good all around firepower. Edited February 5, 2018 by Beams Link to comment https://bolterandchainsword.com/topic/344072-tactics-for-units-dominion-squads/#findComment-5003052 Share on other sites More sharing options...
CCE1981 Posted February 8, 2018 Share Posted February 8, 2018 (edited) I agree and disagree on flamers, one flamer is too finicky to be of real value. Four flamers and one combi-flamer helps to average the rolls out. And yes, I have rolled yahtzee 1s before, I have also rolled yahtzee 6’s as well, usually at the worst time for both. Edited February 8, 2018 by CCE1981 Link to comment https://bolterandchainsword.com/topic/344072-tactics-for-units-dominion-squads/#findComment-5006180 Share on other sites More sharing options...
Montford Posted February 8, 2018 Share Posted February 8, 2018 If you ever have 60 points and you want a Unit, take 5 Dominions, all with Stormbolters. Its not bad. Not game breaking by any means, but not bad, especially if you are looking for a Fast Attack to fill out a Brigade or Outrider detachment. Link to comment https://bolterandchainsword.com/topic/344072-tactics-for-units-dominion-squads/#findComment-5006286 Share on other sites More sharing options...
ERJAK Posted February 12, 2018 Share Posted February 12, 2018 I don't disagree with you Erjak. The SB's aren't melta's. But they are better than BSS even if its just for Vanguard. Rushing forward when going first or bouncing away when going second, I find Vanguard extremely useful. To second your thoughts, four squads of melta Doms piggy back nicely with my SB Doms and still leave points for a couple squads of HB Rets and a Canoness to watch the backfield plus a bit of vehicle upgrades. The SB doms are for sure better than BSS, but command points are so so valuable right now that 3 min BSS squads in a battalion are a great addition, especially considering that if you use a large number of SB Domis you can have the points for Battalion, Outrider, Outrider. Link to comment https://bolterandchainsword.com/topic/344072-tactics-for-units-dominion-squads/#findComment-5009348 Share on other sites More sharing options...
Purifying Tempest Posted February 18, 2018 Share Posted February 18, 2018 My Dominions have been very used very narrowly, so my opinion won't matter much here. I've been using the old 4 meltas with a superior in an immolator to pretty great affect. I usually only run two squads of them, I think they start to saturate themselves out of a strong role if too many are stacked. I know repressors are strong, but I do not have any, first off, and I think the "open-topped" style rule it has is pretty rude. But I've also found that the Immolation cannon is REALLY good. And with a host of Dominions inside with meltaguns, you can threaten to peel open any tank (or transport) that crosses them, while being fairly dangerous to screening units with the transport. I dislike the normal flamer very much. It is an upgrade, and nearly doubles the model cost. The yield of 4-5 flamers is good, but it does objectively worse at what either transport you shove them in can do (Repressors can bring 2 Heavy Flamers, and the Immolator has the Immolation Cannon, of course). Stormbolters are awkward in that... is it really worth 1) stacking them in a transport, 2) paying +1 point per model for the vanguard rule on them, and 3) getting them closer to enemy lines first thing? I think Flamers and Stormbolters are much better left to regular BSS squads, and the Meltas that need to cross the table quickly are better in the hands of the Dominions. All of that said, Dominions have a solid place in the army and are probably one of the better units. They can apply some serious pressure up the field that requires answers from your opponent. Keeping them in a transport (of any sort) also pressures that player into having to sink fire into a tank, which can draw fire away from other targets nicely. Their positioning can really muddle up the threat priority matrix for your opponent. Acts of Faith wise... I've really only had limited success with them. Usually an act to move/double move into position. Typically there isn't anything in range to double tap at the beginning of the turn, or no Dominions left to take advantage of that. Link to comment https://bolterandchainsword.com/topic/344072-tactics-for-units-dominion-squads/#findComment-5013761 Share on other sites More sharing options...
