theJoeMan Posted March 8, 2018 Share Posted March 8, 2018 Battle Brothers, I've got a box of Hellblasters I've started putting together and I'm having a hard time deciding between the normal Plasma Incinerator and the Heavy. What are other people using? At first, I thought the Heavy was the obvious choice, however, I played a game last weekend and tested the normal PI and was very impressed. The range difference isn't much and the ability to move without penalty and potentially double shots seemed to make a pretty big difference. After that game, I imagined loading up 10 Hellblasters in a Repulsor then dropping them off in rapid fire range for some serious dakka. Thanks for any input. Cheers! Link to comment https://bolterandchainsword.com/topic/345100-hellblasters-plasma-incinerator-or-heavy-pi/ Share on other sites More sharing options...
ChaosCrusader Posted March 8, 2018 Share Posted March 8, 2018 Ive been using a unit equipped with the Rapid fire PI, they are savage!! Put them near a Captain (Over charge those bad boys- reroll 1s!, if it goes wrong a second time you can always command point it) and Lieutenant to re roll those 1s for wounds and your on to a winner! My last game they killed off a Leman Russ in the first turn, I think the rapid fire far out stretches the heavy variant, with a 30 inch range its not hard to get to 15 using the current deployment maps. Hope this helps! :) Link to comment https://bolterandchainsword.com/topic/345100-hellblasters-plasma-incinerator-or-heavy-pi/#findComment-5027985 Share on other sites More sharing options...
Kilamandaros Posted March 8, 2018 Share Posted March 8, 2018 Ive been using a unit equipped with the Rapid fire PI, they are savage!! Put them near a Captain (Over charge those bad boys- reroll 1s!, if it goes wrong a second time you can always command point it) and Lieutenant to re roll those 1s for wounds and your on to a winner! My last game they killed off a Leman Russ in the first turn, I think the rapid fire far out stretches the heavy variant, with a 30 inch range its not hard to get to 15 using the current deployment maps. Hope this helps! Unfortunately not, can never reroll a reroll. Firepower, ChaosCrusader and Helycon 3 Back to top Link to comment https://bolterandchainsword.com/topic/345100-hellblasters-plasma-incinerator-or-heavy-pi/#findComment-5028003 Share on other sites More sharing options...
Callan Posted March 8, 2018 Share Posted March 8, 2018 Still, going from a 1/6 chance of immolation to a 1/36 is enough of an improvement to be potentially worth the risk in the right kind of scenario. Link to comment https://bolterandchainsword.com/topic/345100-hellblasters-plasma-incinerator-or-heavy-pi/#findComment-5028020 Share on other sites More sharing options...
BluejayJunior Posted March 8, 2018 Share Posted March 8, 2018 Being Damage 1 (or 2 on the overcharge), I think you really need the extra shots to get the most out of them. I don't think the Heavy version is worth the extra points. I've used the normal plasma incinerators since I started and my Hellblasters have done a lot of work. Link to comment https://bolterandchainsword.com/topic/345100-hellblasters-plasma-incinerator-or-heavy-pi/#findComment-5028040 Share on other sites More sharing options...
theJoeMan Posted March 8, 2018 Author Share Posted March 8, 2018 Awesome, thanks for all the input. Confirmed what I was leaning towards, I'll let everyone know how my Repulsor plan works out. Link to comment https://bolterandchainsword.com/topic/345100-hellblasters-plasma-incinerator-or-heavy-pi/#findComment-5028046 Share on other sites More sharing options...
Ishagu Posted March 9, 2018 Share Posted March 9, 2018 (edited) The normal is overall the best, followed by the Assault Variant. (Assault might be more beneficial if you are running the Hellblasters on foot as you're getting a nice 30" range, 2 shots) The heavy is no good, imo. Too few shots. If you are running a Repulsor the standard Variant is easily the most useful. Edited March 9, 2018 by Ishagu Link to comment https://bolterandchainsword.com/topic/345100-hellblasters-plasma-incinerator-or-heavy-pi/#findComment-5028552 Share on other sites More sharing options...
Medjugorje Posted March 9, 2018 Share Posted March 9, 2018 In our tournament-community there are a many lists with normal hellblasters (from dark imperium) and they perform very good. Link to comment https://bolterandchainsword.com/topic/345100-hellblasters-plasma-incinerator-or-heavy-pi/#findComment-5028651 Share on other sites More sharing options...
Dracos Posted March 18, 2018 Share Posted March 18, 2018 Doesn't it kind of depend on what else you are running? Wouldn't the Heavy Plasma be better versus T8 targets if your army lacks lascannon goodness? Link to comment https://bolterandchainsword.com/topic/345100-hellblasters-plasma-incinerator-or-heavy-pi/#findComment-5034534 Share on other sites More sharing options...
