Guest CapHalberonStoneborn Posted April 7, 2018 Share Posted April 7, 2018 So i am creating a custom space marine army using the online space marine painter(from this site) Everything is good, but apart from one thing. I have seen on other forums that you can make your own insignia to fit on the shoulder pads of the marines (primarily the right). The options the online painter(5th version) gives you (as far as I've seen) : -allows you to paint most of the space marine's armour -then you click on "war gear" allowing you to customise it a bit more precisely(i.e add weapons 'n' stuff, insignia 'n' stuff -*issue* it only shows you the chapter insignia's of dark angels, imperial fists, raven guard, salamanders, and Ultramarine. So.... HOW can i make my own custom one? (just started getting back into 40k after 2 years, much help is appreciated guys :))) Link to comment https://bolterandchainsword.com/topic/346010-bolter-and-chainswordspace-marine-painter/ Share on other sites More sharing options...
Grotsmasha Posted April 8, 2018 Share Posted April 8, 2018 Photoshop (2 iirc) is now freeware, save the image and add your own insignia via Photoshop, it's how I get mine done :tu: Cheers, Jono Link to comment https://bolterandchainsword.com/topic/346010-bolter-and-chainswordspace-marine-painter/#findComment-5050352 Share on other sites More sharing options...
