Dracos Posted April 26, 2018 Share Posted April 26, 2018 I'm using BattleScribe and think it has a bug ... or I do :) I'm trying to build a Double Battalion ... because Brigade isn't worth the extra 2 CP in my opinion. Every time I try to put a second HQ in the second battalion ergo 4 HQs, it flips to Invalid Entry. It doesn't matter which HQ choice I use it pops up? If it's correct I'm okay with that. I'm not big on most the Marine HQs anyway. I just don't want to build a list and find out I need to swap equivilent of a unit out to get another HQ in to be legal. I tried search fu and looked back three pages and didn't see a similar thread so I apologize id this is old hat to others. Link to comment Share on other sites More sharing options...
Dam13n Posted April 26, 2018 Share Posted April 26, 2018 Officially you can have any number of detachments (regardless of type) outside of Organised Play, where the new "Rule of 3" limits the maximum number. As far as this topic is concerned: - Battlescribe is not an official GW product, as such any bug/glitch/error isn't an official rules issue but something that should be reported to the apps creators. Link to comment Share on other sites More sharing options...
Dracos Posted April 26, 2018 Author Share Posted April 26, 2018 . . . but, I am correct to run a Double Battalion one needs a total of 4 HQs correct? Link to comment Share on other sites More sharing options...
Dam13n Posted April 26, 2018 Share Posted April 26, 2018 Yes. 2 per Battalion. Link to comment Share on other sites More sharing options...
Dracos Posted April 27, 2018 Author Share Posted April 27, 2018 Thanks. Eventually I got it to work. Just need to figure out how I did that. ;) Link to comment Share on other sites More sharing options...
Quixus Posted April 28, 2018 Share Posted April 28, 2018 When you add the second battalion make sure the roster is highlighted and not the first batallion. Adding a new detachment when a previous one is selected is to create multiple factions within one detachment. You may have noticed that in this case you cannot select any other detachment type than the "parent" but you can select different factions. So yeah 4 HQs in one battalion is too much. Link to comment Share on other sites More sharing options...
Acebaur Posted April 30, 2018 Share Posted April 30, 2018 When you add the second battalion make sure the roster is highlighted and not the first batallion. Adding a new detachment when a previous one is selected is to create multiple factions within one detachment. You may have noticed that in this case you cannot select any other detachment type than the "parent" but you can select different factions. So yeah 4 HQs in one battalion is too much. This. If you are still having trouble, PM me as I'm on the development team for 40K Battlescribe files and can help you figure out what is going on. Link to comment Share on other sites More sharing options...
Basteala Posted May 11, 2018 Share Posted May 11, 2018 If I understand the rule of three correctly, you would be unable to have 4 of the same HQ. Is it possible your problem is as simple as that? I use Excel myself for my armies, so I don't know the quirks of Battlescribe. Link to comment Share on other sites More sharing options...
Quixus Posted May 11, 2018 Share Posted May 11, 2018 The rule of three is not implemented in battlescribe, moreover it is more of a guideline for tournament organizers really. Link to comment Share on other sites More sharing options...
Basteala Posted May 12, 2018 Share Posted May 12, 2018 The rule of three is not implemented in battlescribe, moreover it is more of a guideline for tournament organizers really. Fair enough. I stand corrected :) Link to comment Share on other sites More sharing options...
