Panzer Posted November 8, 2018 Share Posted November 8, 2018 Yeah I know the limitations of 18". I play T'au, basically anything that's not super long range or flamer is 18". It's definitely doable tho. ^^ Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5187907 Share on other sites More sharing options...
lash144 Posted November 8, 2018 Share Posted November 8, 2018 On 11/8/2018 at 2:00 PM, Karhedronuk said: If you know who you are facing the list tailoring is one option but that is no help if you are trying to build a TAC list. It is easier to build a specialised army and try to overwhelm your opponent on your own terms than it is to build a list designed to stand its ground against a mix of foes. Thanks for your feedback. I just finished my first tournament this weekend and I think that I was lacking some Infantry killing power. In 1 game I really had some problems delivering my CQC units because my opponents screening was just to good (Tau). So I'm brainstorming what I could take. @Panzer Yeah, but you are much more mobile with tau, so you aren't really that hindered by short range. So basically the 18" is to short for setting up a firebase with good coverage first turn and start to double tap second turn? Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5187935 Share on other sites More sharing options...
toaae Posted November 8, 2018 Share Posted November 8, 2018 On 11/8/2018 at 4:46 PM, lash144 said: So basically the 18" is to short for setting up a firebase with good coverage first turn and start to double tap second turn? Maybe? I'd be more concerned with them dying than the enemy moving out of the 18". And if they did, that may open the space you want for the deep-striking. Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5188103 Share on other sites More sharing options...
Panzer Posted November 8, 2018 Share Posted November 8, 2018 On 11/8/2018 at 4:46 PM, lash144 said: @Panzer Yeah, but you are much more mobile with tau, so you aren't really that hindered by short range. So basically the 18" is to short for setting up a firebase with good coverage first turn and start to double tap second turn? Barely tho. Due deep strike or infiltration they have it easier to position themselves however from turn 2 on you shouldn't have any problems finding targets with an 18" weapon unless you were hiding out way in the back or already killed everything in range. ^^ Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5188111 Share on other sites More sharing options...
lash144 Posted November 8, 2018 Share Posted November 8, 2018 On 11/8/2018 at 8:50 PM, toaae said: On 11/8/2018 at 4:46 PM, lash144 said: So basically the 18" is to short for setting up a firebase with good coverage first turn and start to double tap second turn? Maybe? I'd be more concerned with them dying than the enemy moving out of the 18". And if they did, that may open the space you want for the deep-striking. 3x3 units with 2W T5 2+ if in cover and a 5+ FnP seem. Especially since I have another threat with a quite similar profil on a table. (AdMech Dragoons, T6 with 3+) Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5188124 Share on other sites More sharing options...
Arkhanist Posted November 8, 2018 Share Posted November 8, 2018 I think aggressors need to stomp up the table and plan on keeping moving to prevent easy charges while remaining in range; their weapons are 'assault', after all, and CC against chaff is not where they mainly want to be. It forces your opponent to make choices; kill them, move out of range, charge them (and suffer overwatch) or let you get off the doubled shooting. 'Kill them' is the most likely choice, but that also means they're not putting those shots onto our more glass cannon units. So basically a classic distraction carnifex. The more choices you force onto your opponent, the more likely they are to make mistakes you can exploit. SanguiniusJr 1 Back to top Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5188209 Share on other sites More sharing options...
Panzer Posted November 9, 2018 Share Posted November 9, 2018 Why are you so afraid of charges? Unless your opponent uses multiple horde units, a super durable unit like Terminators (against S4 AP0 D1 shooting at least) or Dreadnoughts it shouldn't be much of a problem. Any horde unit in threat range gets decimated by your Aggressors shooting (3 Bolter Aggressors kill about 20 T3 Sv6+ models when they double tap and then ~5 more in overwatch) and tough units that don't kill them the turn they charge have to be afraid of their powerfists. And it gets better if you take even more models in your Aggressor unit. I'd be much more concerned about them getting shot off the table than any potential charges against them. ^^ Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5188297 Share on other sites More sharing options...
Arkhanist Posted November 9, 2018 Share Posted November 9, 2018 It's not so much being afraid of combat as that it limits their effectiveness if your opponent can bog them down. You position the aggressors for a double tap next turn but too close, so they throw a cheap chaff unit into combat with the aggressors - yes, you get overwatch, but now you're tarpitted. They can't kill you very quickly, but neither can you because of your number of A and small squad size - powerfists are not horde killers. So your turn rolls around, you're still stuck in combat and can either fall back and not shoot, or stay put and grind it out - either way, you're not getting to use your firepower or threaten a double tap. Anyone taking cheap chaff will likely have multiple to bubble wrap better quality units, that's what they're for. The plus side of all that though is if you've positioned them right, it may open a hole for deep strikers to hit whatever was being bubble wrapped by the chaff. If you're facing a more elite army, then your tactics change and yes, being shot off the board is the bigger problem and being in combat could well be to your advantage to prevent that. But then, aggressor shooting is mainly for anti-horde - they're hardly useless against vehicles or tough units due to volume of fire, but it's not their most effective use. Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5188333 Share on other sites More sharing options...
Panzer Posted November 9, 2018 Share Posted November 9, 2018 (edited) I'm not denying that they can get locked into combat with some efford from your opponent. However if he actually uses so many ressources in form of multiple horde units to lock 3 Aggressors into combat then that's a win for you as well since those units won't be able to sit on objectives or screen his other units anymore. Again, a single horde unit is unlikely to lock them in combat. One shooting phase with double tap + overwatch already kills ~25 T3 Sv6+ models plus you have turn 1 where you hopefully advanced to where you want to be in which you would have killed ~10 models already. Aggressors are THE anti-horde units. Hordes aren't a threat to them, they are a threat to horde units. It requires some more thinking that the usual no-brain move, point&kill most other units require. You have to advance far enough to threaten things with your double tap turn 2 but not so far that you'll get charged by such units before you were able to be one round stationary. Sounds harder than it is tho, really. Edited November 9, 2018 by sfPanzer Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5188336 Share on other sites More sharing options...
BluejayJunior Posted November 9, 2018 Share Posted November 9, 2018 You can also keep a squad or two of Intercessors (or something similar) with them to screen them from charges. I usually at least start 1 or 2 squads with them anyway because they are the core of my firebase along with a captain, lieutenant, and ancient. Arkhanist and Panzer 2 Back to top Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5188469 Share on other sites More sharing options...
Panzer Posted November 9, 2018 Share Posted November 9, 2018 Yeah that as well. No unit has to lift all the weight on their own. ^^ Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5188483 Share on other sites More sharing options...
lash144 Posted November 9, 2018 Share Posted November 9, 2018 Okay, so I think I will try them out next week or so and report my findings back :) Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5188511 Share on other sites More sharing options...
tychobi Posted November 12, 2018 Share Posted November 12, 2018 From the other side. . . I play against an Ultramarine player who uses Agressors most games and have learned not to fear them. Heathy respect is required, they erase light units that get close, but that's about it. I now either kill them first or play around them. By forcing them to move I can mitigate damage. I charge from out of sight if I can but often can kill them early or give them enough space to avoid damage. Really dangerous are the Ravenguard version that pop up 9 inches in front of your line. All in all the lack of mobility coupled with short range give Agressors a weakness that can be exploited easily by savvy opponents. New and forgetful players may wander into the storm of lead that they dish out (where do they keep the ammo I wonder??? lash144 1 Back to top Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5189901 Share on other sites More sharing options...
Silas7 Posted November 12, 2018 Share Posted November 12, 2018 (edited) Also in regards to the tarpit, if you've set up a second unit of aggressors, you can withdraw the first one from CC and blast away with the double tap backup. Edited out stupidity. Edited November 13, 2018 by Silas7 Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5189910 Share on other sites More sharing options...
Panzer Posted November 12, 2018 Share Posted November 12, 2018 On 11/12/2018 at 5:08 AM, tychobi said: Side note, I fear Agressors may limit design space by making mobility options for Primaris too good. What else would you put un a primaris drop pod? Probably rather Hellblaster since arriving from reserves counts as moving so you wouldn't be able to double tap with the Aggressors anyway. ;) On 11/12/2018 at 5:48 AM, Silas7 said: Also in regards to the tarpit, if you've set up a second unit of aggressors, you can withdraw the first one from CC and blast away with the double tap backup. This doesn't synergize with Red thirst but in most cases you'll want to shoot as soon as you can rather than stick it out. Yeah, especially since Red Thirst only works in the turn they got charged and the turn you'd be able to fall back it wouldn't be active anymore anyway. Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5189917 Share on other sites More sharing options...
dread05 Posted February 21, 2019 Share Posted February 21, 2019 My aggressor box arrived today and I realised aggressors are elite option? I thought they were heavy support. Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5261693 Share on other sites More sharing options...
Panzer Posted February 21, 2019 Share Posted February 21, 2019 On 2/21/2019 at 3:39 PM, dread05 said: My aggressor box arrived today and I realised aggressors are elite option? I thought they were heavy support. Yeah they are Elite. One of the few weird decisions of GW where the FOC of the Codex doesn't fit the company organisation of the fluff. Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5261708 Share on other sites More sharing options...
dread05 Posted February 21, 2019 Share Posted February 21, 2019 Hmm maybe cause the initial wave of primaris had to be able to support primaris only armies and that means they couldnt go by the fluff? In that case maybe in later editions they will be changed back to heavy support. Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5261717 Share on other sites More sharing options...
Panzer Posted February 21, 2019 Share Posted February 21, 2019 On 2/21/2019 at 4:09 PM, dread05 said: Hmm maybe cause the initial wave of primaris had to be able to support primaris only armies and that means they couldnt go by the fluff? In that case maybe in later editions they will be changed back to heavy support. That makes only little sense. The elite section is already ohercrowded as is. Even without Aggressors a pure Primaris army got Reiver, Redemptor Dreads, Ancients and Apothecaries there. Silas7 1 Back to top Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5261725 Share on other sites More sharing options...
dread05 Posted February 21, 2019 Share Posted February 21, 2019 Reivers should be fast attack respectivly :P but I get your point. Either way, its weird. Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5261731 Share on other sites More sharing options...
Remtek Posted October 29, 2019 Share Posted October 29, 2019 Recently tried them in a game. Two six man aggressors units with an ancient for 5+ fnp. Having 3 wounds now makes them really survivable. They also received an additional attack + shock assault, giving them 4 attacks each on the charge, 5 on sarge. If you were on the fence on these i suggest giving them another go! Xenith and Panzer 2 Back to top Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5416360 Share on other sites More sharing options...
Xenith Posted October 29, 2019 Share Posted October 29, 2019 Indeed, +1A and W is really good, especially for no point rise. 5A on the charge for the serge is also great. Did you use flamers or bolters? I assume bolters are still the best option? Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5416538 Share on other sites More sharing options...
Panzer Posted October 29, 2019 Share Posted October 29, 2019 Bolters are definitely still better imo as none of the buffs made flamers any better unless you are Salamanders. Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5416542 Share on other sites More sharing options...
Remtek Posted October 29, 2019 Share Posted October 29, 2019 On 10/29/2019 at 3:07 PM, Xenith said: Indeed, +1A and W is really good, especially for no point rise. 5A on the charge for the serge is also great. Did you use flamers or bolters? I assume bolters are still the best option? Bolters :) Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5416546 Share on other sites More sharing options...
Xenith Posted October 30, 2019 Share Posted October 30, 2019 On 10/29/2019 at 3:15 PM, Remtek said: On 10/29/2019 at 3:07 PM, Xenith said: Indeed, +1A and W is really good, especially for no point rise. 5A on the charge for the serge is also great. Did you use flamers or bolters? I assume bolters are still the best option? Bolters Looks like I need some more then! I seem to already have 14 heavy support Primaris from various sources. Link to comment https://bolterandchainsword.com/topic/347032-unit-of-the-week-aggressor-squad/page/3/#findComment-5416954 Share on other sites More sharing options...
