Heroic intervention
Does your opponent have to have made a charge somewhere on the board in order for you to make a heroic intervention?
The rule says after your opponent has completed all their charge moves you can do a heroic intervention . So if your opponent doesn’t charge this phase but is within 3 of a unit have they still completed all their charge moves for the phase?
Stepping Into the new edition faq says you can intervene on units that didn’t charge .
https://bolterandchainsword.com/topic/348950-heroic-intervention/
If your opponent declared zero charges, then once zero charges have been completed, they are done! :teehee:
In all seriousness, I can't see any reason it wouldn't be allowed. The FAQ confirms that Heroic Intervention isn't conditional on enemy units charging so I don't see why an unrelated charge on the other side of the board would be required as a trigger for HI.
