PiñaColada Posted August 24, 2018 Share Posted August 24, 2018 Greetings all! Hopefully a lot of you out there are having fun with Kill Team, I sure am. However I dislike the system GW provided for us when it comes to printing out the command roster. If you're like me you're probably looking at that thing, all unnecessarily colourful and with huge areas consisting of off-white greys and thinking that "this thing is going to drain all my ink in 1 or 2 tries" Obviously you could simply write down your list on a simple piece of paper and call it a day, but this is for the people who appreciate the little touches that roster has but want them in a printer friendly way. Note: Something like this might already exist but when I quickly looked around I couldn't find anything quite like it. Either they were still using a lot of greys or the format was off. This should perfectly fit an A4 with the overall info as a header and the 20 slots. All the cells are big enough to write in either by hand or in the computer before printing it out.Praise Gork! https://drive.google.com/open?id=1E_dOUNyCbyb04k2q98NPuJjxYuyR3CK-S-lfZLxxKmc Update: I've also made a printer friendly version of the individual datasheets. These are not the prettiest you'll ever see (some boxes might be slightly misaligned) and I haven't tried to match the size to GWs. Instead I tried to make them as big as possible while still fitting 4 to an A4. The previously orange markers, signifying that the model has gained enough experience to level up, have been replaced by significantly thicker black borders.https://drive.google.com/file/d/1kByXY48h2uLNhFw2lVIA6wXoaXO_Kdgw/view?usp=sharing Link to comment https://bolterandchainsword.com/topic/349830-kill-team-command-roster-data-sheets-updated/ Share on other sites More sharing options...
Chaplain Raeven Posted August 24, 2018 Share Posted August 24, 2018 You're the man! I printed GW's version and regretted it instantly. Every inch of the paper had inkt on it, what a waste. Link to comment https://bolterandchainsword.com/topic/349830-kill-team-command-roster-data-sheets-updated/#findComment-5152583 Share on other sites More sharing options...
Orpheus108 Posted August 24, 2018 Share Posted August 24, 2018 Well done, cheers Link to comment https://bolterandchainsword.com/topic/349830-kill-team-command-roster-data-sheets-updated/#findComment-5152640 Share on other sites More sharing options...
