Parweke's AT plog - Mortis & Atarus
Parweke
If they are glued already then you have no choice but to dig them out. Otherwise extract them with a stronger magnet and drill a bit deeper, just buy 3x2mm magnets with your next order (unless it is a long time from now).
I bought a set of 5 drillbits (2mm to 6mm) for metal from a DIY store especially for my miniatures. No need for the powertool.
Actually I just rotate the drillbit with my fingers, that way I can't go too fast nor much too deep. I should buy a pin vice for the smaller drillbits I have (fingers hurt after drilling 6 x 1mm holes into each of my 12 knights :biggrin.: )
For larger, flatter pieces (e.g. wood frame or large plasticard) I use the very basic Bosch powertool, using drillbits with hexagonal basis.
well, I used rechargable hand drill :)
worked very well on the reaver shoulders, not so much on the arm so I sliced the top off with a hobbyknife and glued/greenstuffed 5 mm magnet in there.
so much better now than with 3mm magnets. even magnetising the power fist was a success.
did some mask taping before dinner. now a short rest after it and then some airbrushing.
I should have some progress pics later tonight.
http://i.imgur.com/lfVDD7g.jpg
http://i.imgur.com/TWjPmfa.jpg
Reavers are so much easier to build and paint than Warlords.
I might finish this one tomorrow.
Then comes the hard part.
Todays news made me think how will I go forward from here. The "new" reaver is so much better looking that I need couple of them for Mortis.
my warhounds are still a no show (5 days late) and that is maybe a good thing.
I might go back to my original idea of 3 warlords and 2 reavers for Mortis and make Atarus reaver and warhound heavy.
If I finish the reaver tomorrow and my package arrives then I just might start Atarus too.
You take a lot of Ibumax - whatever that is.
mild painkillers... :)
and not all are mine, I ask them from friends and family... the larger ones are stronger prescription painkillers those I take for my neck and back. that ibumax boosts the effect.
release the hounds!
http://i.imgur.com/YTTEO5a.jpg
some new paints too
http://i.imgur.com/l8JpVgQ.jpg
does anyone have experience with vallejo liquid metallics? I have heard good things about them.
only downside is they are alcohol based and need synthetic brushes and own cleaner, but I have all those.
wanted to try the silver on panel trims for Atarus. one layer should be enough.
it does, I have done nothing today!
well I did some throwing practise with my darts today (3 hours)
oh, but I washed the warhound sprues and maybe I'll start building them tonight... or I could paint some panels trims for the reaver....
decisions, decisions....
Warhounds are lovely minis, you’ll have a blast with them I’m sure!
Can you check the feet of the Reaver? It think they are they othe4 way around...
I think he knows.
Seeing how many people have messed this up, including myself, I kinda wish the instructions I found here (too late) were pinned somewhere.
