Mendi Warrior Posted February 14, 2019 Author Share Posted February 14, 2019 A little bit more work on the 3 Reavers, including a start at their bases and pinning Close-up of the building, combining civitas imperialis components with the old Epic ruins Planning on filling the ground floor Next reaver, undecided as to what to put on the base, if anything And the last one (to date) A look from above Chaeron 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5256666 Share on other sites More sharing options...
Brother Dallo Posted February 14, 2019 Share Posted February 14, 2019 Those Warhounds and their bases are looking really good. I like the one who is sneaking around the buildings, as sneakily as a Titan can. Keep up the good work. Dallo Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5256696 Share on other sites More sharing options...
Chaeron Posted February 14, 2019 Share Posted February 14, 2019 Mendi, the attention to detail! Love the boarded up windows, simply wonderful. Great stuff! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5256898 Share on other sites More sharing options...
Mendi Warrior Posted February 15, 2019 Author Share Posted February 15, 2019 (edited) Thanks. I shamelessly plundered the idea from Doghouse's work, I loved it so much I couldn't resist. Slowly but surely tying up some loose ends, I added a couple more magnets here and there, glued the plasma annihilators together (except for component 117 so I can better access the back of the cables for painting them) and built the Arioch power claw, I magnetised it in the same way as the previous one with a little addition to also be able to move the wrist. This is more for the challenge than anything else as it is absolutely not needed. I figured that I could drill a 2mm diameter hole through component 120 and insert a rod to allow movement. But adding a rod means you need two holes on the inside of the power claw on the left and right of component 120. You don't want to drill through the power claw though, except on the side you'll glue component 122 as it will cover the 2mm diameter hole (more than 2mm and you'll see it). Watch out for correctly aligning the drill and keep components 118, 119 and 120 firmly in place. I drilled through 120 before drilling through the side of the power claw, it helps with the alignment. Once you have drilled, cut an appropriate size rod, insert it into component 120, dry fit and fine-tune as required. Dry-fitting the rod Watch out for avoiding leaving a gap (dry-fit and fine-tune as required) Alignement was not perfect, again fine-tune as required Before gluing the parts together I enlarged the existing hole so I could insert a 3x1mm magnet. I drilled a little over 2mm deep so the 3x2mm magnet I inserted into component 121 could fit 1mm inside component 120. I did as previously, see around the bottom of page 5 for more details http://www.bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page-5 I then glued the different parts together, paying attention not to glue component 120 so it could still be moved afterwards. I used a clamp to maintain pressure for a few minutes. I then glued component 122 in place. Edited February 15, 2019 by Mendi Warrior Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5257188 Share on other sites More sharing options...
Mendi Warrior Posted February 15, 2019 Author Share Posted February 15, 2019 The latest Warlord with some weapons - with double Arioch claws - with a plasma annihilator and an Arioch claw Parweke, Burni, Chaeron and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5257193 Share on other sites More sharing options...
Sherrypie Posted February 15, 2019 Share Posted February 15, 2019 I just wanna see that lad rip some poor souls apart :D 4" move doesn't really help it, though. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5257673 Share on other sites More sharing options...
Mendi Warrior Posted February 15, 2019 Author Share Posted February 15, 2019 Lol, there is hardly a chance to witness that I think. He does look cool but I honestly doubt he would make it to close quarter, it would probably work as a shots magnet (an expensive one) more than anything else. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5257827 Share on other sites More sharing options...
Gore Crow Posted February 15, 2019 Share Posted February 15, 2019 Yaaas double fist! Im just gonna send mine trundling along towards the enemy like a big sword of Damocles and give my other bots a chance to punch. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5257897 Share on other sites More sharing options...
Achinadav Posted February 17, 2019 Share Posted February 17, 2019 Nice posing, I like the way including walls makes the titans interact with their environment. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5258902 Share on other sites More sharing options...
Burni Posted February 18, 2019 Share Posted February 18, 2019 Top posing and magnet work as usual Mendi. I've forgotten - have you picked a Legio for these yet? Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5259283 Share on other sites More sharing options...
Mendi Warrior Posted February 18, 2019 Author Share Posted February 18, 2019 Thanks guys! Not 100% sure yet but likely going for Suturvora, I like their colour scheme. Gore Crow 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5259470 Share on other sites More sharing options...
Brother Dallo Posted February 22, 2019 Share Posted February 22, 2019 Shamelessly plundering is the sincerest form of flattery. :p Liking Mr Punchy. Keep up the good work. Dallo Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5262502 Share on other sites More sharing options...
Mendi Warrior Posted February 24, 2019 Author Share Posted February 24, 2019 Today I got a 30 minutes window (my wife running a quick errand so we don't starve tonight) so I quickly base coated a couple things with Leadbelcher (I killed the spray can). Next step will be to tidy up with a brush and then I can start the real work. Parweke 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5263470 Share on other sites More sharing options...
Mendi Warrior Posted March 4, 2019 Author Share Posted March 4, 2019 At last, some progress. I really need to kick myself to speed up things otherwise I'll end up lobotomized After spraying with Leadbelcher and tidying up with a brush, I started applying Abaddon Black and some Khorne Red to get the rough shape of flames for my vowed Suturvora Warlord. I'll use Nuln Oil once my base colours are done. Same approach on various armour panels A bit more progress on the head, Abaddon Black as main colour, with rough shape of flames in Khorne Red on the cheeks and Warplock Bronze for the trim, I also used Khorne Red as base for the lenses The torso, its base and the plasma annihilators. The legs of the warhounds, also going for Suturvora. The legs of the Warlord My "Titans in a box" with some in progress bits More armour panels and weapons 1ncarnadine, Chaeron, Parweke and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5269240 Share on other sites More sharing options...
Warsmith Uveron Posted March 4, 2019 Share Posted March 4, 2019 Looking great! Though that is some assembly line! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5269250 Share on other sites More sharing options...
Chaeron Posted March 4, 2019 Share Posted March 4, 2019 Superb, the forge in full flow - keep it coming Mendi! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5269479 Share on other sites More sharing options...
Gamma310 Posted March 5, 2019 Share Posted March 5, 2019 Ahh the assembly line is looking good. These will be some fine Titans once your done with them. Keep on painting. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5269582 Share on other sites More sharing options...
Mendi Warrior Posted March 5, 2019 Author Share Posted March 5, 2019 Thanks guys! I hope to give a good boost and tackle all the trim later today and this week. But don't hold your breath ... Gamma310 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5269811 Share on other sites More sharing options...
Gamma310 Posted March 5, 2019 Share Posted March 5, 2019 Thanks guys! I hope to give a good boost and tackle all the trim later today and this week. But don't hold your breath ... Painting trim sucks... I've changed my method from sprying yello than painting brass trim to spray brass and paint yellow.... That is how much I hate painting trim... Parweke 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5269848 Share on other sites More sharing options...
Gore Crow Posted March 5, 2019 Share Posted March 5, 2019 Looking good! I can't wait to see some Surturvora, traitors have the best schemes. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5269861 Share on other sites More sharing options...
Mendi Warrior Posted March 7, 2019 Author Share Posted March 7, 2019 Thanks guys! I hope to give a good boost and tackle all the trim later today and this week. But don't hold your breath ... Painting trim sucks... I've changed my method from sprying yello than painting brass trim to spray brass and paint yellow.... That is how much I hate painting trim... Yep, it is not my favourite moment when painting, it take ages. I was thinking the same for gold trim, first using the spray (I have no airbrush). Looking good! I can't wait to see some Surturvora, traitors have the best schemes. Absolutely! I added a lighter tone of red, now I'll have to fine-tune and add some yellow, time for a more precise brush. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5271575 Share on other sites More sharing options...
Mendi Warrior Posted March 8, 2019 Author Share Posted March 8, 2019 Very slow progress. I painted some trim (much less than I should have) and I added yellow to some armour panels. I think I could do better with a better brush. And also probably best to paint the trim afterwards as I can be messy sometimes. A quick pic of 2 armour panels to give an idea. I think things will look better after a wash or two with red and yellow. As usual feedback more than welcome. Chaeron 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5272503 Share on other sites More sharing options...
Mendi Warrior Posted March 8, 2019 Author Share Posted March 8, 2019 Some more pics Switching to a size 00 brush yields much better results I think. On the previous picture the two top right panels are also done with the same brush, the rest with an old "Standard" citadel brush, still in relatively good shape. General Zodd and Chaeron 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5272551 Share on other sites More sharing options...
Mendi Warrior Posted March 13, 2019 Author Share Posted March 13, 2019 A bit more progress, panels are glued to the shoulders' structures (which are not glued to the torso yet) Reyner and Chaeron 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5275509 Share on other sites More sharing options...
DuskRaider Posted March 13, 2019 Share Posted March 13, 2019 Awesome! Have you thought about adding Word Bearers iconography? Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/11/#findComment-5275522 Share on other sites More sharing options...
