Mendi Warrior Posted December 23, 2018 Author Share Posted December 23, 2018 Adding the staircase Chaeron, Cpt. Bannockburn and Parweke 3 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5221627 Share on other sites More sharing options...
Fajita Fan Posted December 23, 2018 Share Posted December 23, 2018 That’s really neat and those ruins really sell the scale. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5221631 Share on other sites More sharing options...
Mendi Warrior Posted December 23, 2018 Author Share Posted December 23, 2018 They do indeed. Mock-up for the 4th warhound's base, full ahead crashing through ruins. Brother Dallo, Chaeron, Cpt. Bannockburn and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5221666 Share on other sites More sharing options...
Captain Semper Posted December 23, 2018 Share Posted December 23, 2018 The staircase looks like it was a lot of work... well done mate! :tu: Also kudos on the work on the base, it really conveys the sense of scale. Maybe you want to consider repositioning the head though? It seems like he's looking at the sky instead of lower targets of lock on to. Unless of course it's intentional in which case ignore me! :) Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5221856 Share on other sites More sharing options...
Mendi Warrior Posted December 23, 2018 Author Share Posted December 23, 2018 (edited) The staircase looks like it was a lot of work... well done mate! Also kudos on the work on the base, it really conveys the sense of scale. Maybe you want to consider repositioning the head though? It seems like he's looking at the sky instead of lower targets of lock on to. Unless of course it's intentional in which case ignore me! Thanks! Actually, the staircase took about 5 minutes to cut into shape and position. It is about 30x30x20mm (20mm is the thickness of the insulation foam I have), so basically cutting that, then slicing to obtain a triangle when viewed laterally, then simply cutting each level. I added two sustaining walls which are about 35x5x20mm on each side. I actually started with the sustaining walls, they are glued, the staircase not yet (easier for painting, no spraying there). The head is magnetised, I have 2 looking down, 2 looking at the horizon (depends if the steel ball is a bit more up or down). It can be seen as looking at the warlord about to get his full attention, ignoring the poor guys crushed under the rubbles (maybe I'll add some ). Edited December 23, 2018 by Mendi Warrior Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5221881 Share on other sites More sharing options...
Captain Semper Posted December 23, 2018 Share Posted December 23, 2018 Even better, if you can achieve that result with little effort. Although I think that it's your experience that makes it look easy - it would probably take me waaaay longer to achieve that result. :P Good to hear about the head pose-ability. I have to tell you, that to me the Warhound looking down is a great pose, as if it's searching for the next lowly victim. But given that this is a game of Titans and the Warhound is (currently) the smallest, it makes sense to have him looking up too. :D Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5221900 Share on other sites More sharing options...
Chaeron Posted December 23, 2018 Share Posted December 23, 2018 Loving the interaction with the terrain Mendi - top notch! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5221937 Share on other sites More sharing options...
Mendi Warrior Posted December 23, 2018 Author Share Posted December 23, 2018 Thanks Chaeron I started with the bases for my Reavers, here is the first (work-in-progress). With the Reaver (well, only the legs for now) I like doing this Dr_Ruminahui and Cpt. Bannockburn 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5222094 Share on other sites More sharing options...
Red_Shift Posted December 24, 2018 Share Posted December 24, 2018 That staircase is very impressive. Good skills! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5222251 Share on other sites More sharing options...
Mendi Warrior Posted December 24, 2018 Author Share Posted December 24, 2018 (edited) Thanks! Continuing with the bases for the Reavers, work-in-progress still. After checking where the Reaver's feet would be I drew a line to ensure the ruins were aligned. The next one, again drawing a line to ensure the bits are aligned I liked it but I thought it could still be improved with some minimal efforts, so I added smaller ruins next to the left leg, think of them as surrounding an inner garden or courtyard, I made sure the added ruins were parallel / perpendicular to the ones I first put on the base Epic ruins are really perfect for this. In advance, a Merry Christmas to everyone, have a great evening, have fun and stay safe! Edited December 24, 2018 by Mendi Warrior Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5222344 Share on other sites More sharing options...
Captain Semper Posted December 24, 2018 Share Posted December 24, 2018 Yes they are! They convey the sense of scale perfectly! Keep going mate! :tu: Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5222542 Share on other sites More sharing options...
Mendi Warrior Posted December 25, 2018 Author Share Posted December 25, 2018 Hope you are all having a Merry Christmas Slow day today thanks to too much eating and drinking yesterday evening So I am continuing with bases, still works-in-progress of course. Here is the one for my last Reaver until I buy more when the new one is released of course I wanted something a bit more complex, not too tall, not obscuring the legs too much. The right leg about one floor above ground was a constraint as I needed something to support it. I started with the staircase, then the door, then some support to gauge the right angle for positioning a floor under the foot, then the floor and finally the various other bits. Then I turned to my warlords' bases. I had already started on some but they had remained untouched since a long time already. I started with this one, basically adding a bit to the rubble around the sunken structure, I used the Epic ruins leftovers from the previous bases. As this structure looks a bit industrial I thought it could be a good idea to add some industrial type flooring, this added 1mm in height to this half of the base and as a result my warlord's feet are now more stable. DuskRaider 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5222947 Share on other sites More sharing options...
RipOffProductions Posted December 25, 2018 Share Posted December 25, 2018 Hmm, that one really tall pillar on that last Reaver base seems a bit out of place(it rases questions about how the Reaver steped up there with it in the way), and the flooring on the Warlord Titan looks way to big for this scale, and thus makes the Warlord and the surrounding rubble look smaller then it should. Besides that it's all amazing work. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5223017 Share on other sites More sharing options...
Mendi Warrior Posted December 25, 2018 Author Share Posted December 25, 2018 Thanks for the feedback. I agree, the pillar should be more destroyed, or more toppled, it is indeed in the way and the Reaver would logically not raise its leg and foot very high. For the flooring, I envisioned it as a rusted metallic floor, rather than concrete. I am planning to add debris over it, otherwise it is too "plain". I'll see how to improve that. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5223024 Share on other sites More sharing options...
Fajita Fan Posted December 25, 2018 Share Posted December 25, 2018 That staircase is nuts... Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5223067 Share on other sites More sharing options...
Mendi Warrior Posted December 25, 2018 Author Share Posted December 25, 2018 Thanks Fajita Fan I reworked the last Reaver's base, still work-in-progress of course. Chaeron 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5223115 Share on other sites More sharing options...
Fajita Fan Posted December 25, 2018 Share Posted December 25, 2018 Is that arch also from old Epic terrain? Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5223137 Share on other sites More sharing options...
Chaeron Posted December 25, 2018 Share Posted December 25, 2018 Continue to look excellent Mendi - love the introduction of more of those arches, totally gothic and really looks good to have the odd few intact. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5223145 Share on other sites More sharing options...
Captain Semper Posted December 27, 2018 Share Posted December 27, 2018 Man, I missed quite a few episodes! :o Those bases are really amazing mate - the convey the size, movement and brutality of those engines! Well done sir! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5223969 Share on other sites More sharing options...
Mendi Warrior Posted December 28, 2018 Author Share Posted December 28, 2018 Thanks guys! Is that arch also from old Epic terrain? Yes, it is. It is part of a larger one, which I cut / broke / tore apart. I have quite a few and even a couple of untouched sprues somewhere, I'll try to find them and post a picture later. I also continued basing my warlords. Except for the latest one I bought where I have no work done on the base yet, I had already started the other ones, so it is basically adding and improving. They are still work-in-progress, I need to add more debris and rubbles. Here is the second one, with a plaza and a ruined building Chaeron and DuskRaider 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5224179 Share on other sites More sharing options...
noigrim Posted December 28, 2018 Share Posted December 28, 2018 This base conveys a sense of scale nicely Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5224205 Share on other sites More sharing options...
Chaeron Posted December 29, 2018 Share Posted December 29, 2018 Love that Mendi - superb pose! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5224697 Share on other sites More sharing options...
Mendi Warrior Posted December 29, 2018 Author Share Posted December 29, 2018 Thanks guys! I have added a little bit of details on the base with the green textured plastic, it was too plain to my taste. Hopefully, this should also help alleviate the concern RipOffProductions raised regarding the size balance between the flooring and the rubble and warlord. The underlying thinking for the flooring is to aim at having something similar to PSP or Pierced Steel Planking which was used to quickly build airfields during WWII. The pipe elbow and the pipes come from GreenStuffWorld http://www.greenstuffworld.com/en/149-pipe-elbows where I get my plasticard supplies. The supports are simply the leftover sprues from the transparent round bases. I also made an open "container" holding pipes. The pipes are from Q-Tips, the rest are from old plastic bases (the plastic parts joining the warmaster bases and old 40K round bases). Dimensions are a bit less than 40x20x20mm. I toyed with ideas for a crane too, nothing concrete yet. Battybattybats, Chaeron, Cpt. Bannockburn and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5224832 Share on other sites More sharing options...
Fajita Fan Posted December 29, 2018 Share Posted December 29, 2018 Your use of sprue is pretty fantastic. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5224838 Share on other sites More sharing options...
DuskRaider Posted December 30, 2018 Share Posted December 30, 2018 Wonderful basing ideas, Mendi! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/7/#findComment-5224904 Share on other sites More sharing options...
