Focslain Posted February 13, 2019 Share Posted February 13, 2019 I do agree with the sentiment that a single codex list should be as good as a soup list. The soup should just add different flavors But I don´t think it´s the CP generation that is the real problem. Changes like that won´t make for example marines better, it will only make imperial soup worse and something else (Aeldari) will be the best again. The mono-codices that struggle now will still continue to struggle. To make for example marines better I personally think they must be made stronger rules-wise. - Better saves - More firepower - Better mobility - More mortal wound generation Just tweaking points or CP wont help much, they are simply to outclassed in to many fields Well adding some grey knights will give you more MW generation, but then we hit the CP generation issue. Now the top eldar list was an allied list (Aeldari, Durkari, and Yannri), can a straight codex do the same? Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256063 Share on other sites More sharing options...
PiñaColada Posted February 13, 2019 Author Share Posted February 13, 2019 Well adding some grey knights will give you more MW generation, but then we hit the CP generation issue. Now the top eldar list was an allied list (Aeldari, Durkari, and Yannri), can a straight codex do the same? I'm sure it's possible, but it's just so much more difficult. Look at the space elf lists that placed in top 25 at the LVO. 2nd - Alex Harrison, Ynnari 5th - Sean Nayden, Ynnari 10th - Matthew Allee, Ynnari 12th - Justin Pizzoferrato, Drukhari (contains Harlequins) 14th - Trent Northington, Ynnari 25th (tied) - Brad Chester, Ynnari Not a single one is a mono-codex list amongst them. I'd wager because there's simply no point in forcing that restriction upon yourself. That's a design flaw in my book. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256079 Share on other sites More sharing options...
PeteySödes Posted February 13, 2019 Share Posted February 13, 2019 To point though, Ynarri is basically a soup anyways. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256083 Share on other sites More sharing options...
Focslain Posted February 13, 2019 Share Posted February 13, 2019 Well adding some grey knights will give you more MW generation, but then we hit the CP generation issue. Now the top eldar list was an allied list (Aeldari, Durkari, and Yannri), can a straight codex do the same? I'm sure it's possible, but it's just so much more difficult. Look at the space elf lists that placed in top 25 at the LVO. 2nd - Alex Harrison, Ynnari 5th - Sean Nayden, Ynnari 10th - Matthew Allee, Ynnari 12th - Justin Pizzoferrato, Drukhari (contains Harlequins) 14th - Trent Northington, Ynnari 25th (tied) - Brad Chester, Ynnari Not a single one is a mono-codex list amongst them. I'd wager because there's simply no point in forcing that restriction upon yourself. That's a design flaw in my book. So to just add a little more to this. What mono-dex forces actually placed high? Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256097 Share on other sites More sharing options...
PiñaColada Posted February 13, 2019 Author Share Posted February 13, 2019 We had a pure astartes list at 8th (but that placing is weird because it was eliminated in the ghost round). It was 8th before that round but essentially ends up in the 9-12 spot. I mean it was several marine chapters but basically lots of marines and repulsors backed up by Guilliman.The 11th spot was a pure IG list, with elysians, vostroyans and vulture gunships. Both of those lists are impressive seeing they placed high and had options for easily slotting in soup. Then at the 20th spot we had necrons and that guy should certainly be lauded as well. To point though, Ynarri is basically a soup anyways. I'm counting Ynnari as soup, I don't see how they're not. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256099 Share on other sites More sharing options...
Kargrym Posted February 13, 2019 Share Posted February 13, 2019 I think everyone should try a soup list game and experiment with this rule addition and see if it helps. You can only use the Stratagems of the army Warlord. It makes an amazing difference. Ynnari get reduced to the universal Strats or as a small detachment. Knights can only rotate Ion Shields if they are in an Admech army or a knight army. Relics are reduced to the ones the warlords codex can CP for. Tell me where this does not improve the game balance for soup? Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256138 Share on other sites More sharing options...
Finkmilkana Posted February 13, 2019 Share Posted February 13, 2019 The 11th spot was a pure IG list, with elysians, vostroyans and vulture gunships. Both of those lists are impressive seeing they placed high and had options for easily slotting in soup. I wouldn’t count that as a “mono-list”. Mixing different regimental/chapter etc to me already is almost as soupy as mixing different codices (and in many cases even more against the fluff). If he indeed used elysians, then that is technically a different codex (or index) as they have a completely different unit list from forgeworld. In general, once you say “restrict to a single codex” then you kinda also have to restrict FW. Marines or custodes for example effectively have two ‘codices’ (one from GW and one from FW), while other factions often have even less units overall than either of those single books. (I’m not saying restrict FW, but it kinda has to be done if you restrict to single codex or you get other imbalances) Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256144 Share on other sites More sharing options...
PiñaColada Posted February 13, 2019 Author Share Posted February 13, 2019 The 11th spot was a pure IG list, with elysians, vostroyans and vulture gunships. Both of those lists are impressive seeing they placed high and had options for easily slotting in soup. I wouldn’t count that as a “mono-list”. Mixing different regimental/chapter etc to me already is almost as soupy as mixing different codices (and in many cases even more against the fluff). If he indeed used elysians, then that is technically a different codex (or index) as they have a completely different unit list from forgeworld. In general, once you say “restrict to a single codex” then you kinda also have to restrict FW. Marines or custodes for example effectively have two ‘codices’ (one from GW and one from FW), while other factions often have even less units overall than either of those single books. (I’m not saying restrict FW, but it kinda has to be done if you restrict to single codex or you get other imbalances) Well I do agree with you in the sense that mixing in different chapters/regiments etc is still soup (not sure if I'd lump in FW there). It's just refreshing to see a Guard list being comprised of Guard and not the "mandatory" IK addition. The same thing can be said for the astartes list that had brought a group of black templars just for the deny psychic power stratagem, it is gamey, but it's also at the very least a list that tried something different. The sad part about soup is while it does give you the options to play with millions of different combinations you most often just see the same list or two over and over again, with minor variations. These lists are at the very least not some common "net-lists" and I respect that. It would've been nice to see someone run a pure Ulthwé/Blood Angels/Salamanders/Deffskullz etc army and place in the top 8, but I think we need changes to the current system before that can become a reality with some sort of consistency. I still really like 8th edition but GW dragging their feet on even implementing a symbolic fix to the issue is a bit disappointing. Edit: Oh and Kargrym, me and some of my friends have tried that solution and it does work well. However that does seem like far too strict of a fix for it to be something GW would consider, hence the "lighter touch" I've tried with my suggestion Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256151 Share on other sites More sharing options...
Happy-inquisitor Posted February 13, 2019 Share Posted February 13, 2019 We had a pure astartes list at 8th (but that placing is weird because it was eliminated in the ghost round). It was 8th before that round but essentially ends up in the 9-12 spot. I mean it was several marine chapters but basically lots of marines and repulsors backed up by Guilliman. The 11th spot was a pure IG list, with elysians, vostroyans and vulture gunships. Both of those lists are impressive seeing they placed high and had options for easily slotting in soup. Then at the 20th spot we had necrons and that guy should certainly be lauded as well. And there was a T'au list in the top 8. The game is pretty much working as intended. I am not sure that the tournament scene is quite working as everyone would like. I think the comment about lauding the Necron player gets to the heart of this - single faction players are not really getting a look-in within this tournament format. If you play pure BA you are going to get stomped by a supposed BA player who allies in stuff to cover the weakness of the faction and they will win "best BA" over the pure BA players. I actually think this is more of the cause of low diversity in lists than anything - how many supposed factions were won at LVO by a list that had a Castellan dropped in it to make it good? Cult mechanicus and Astra Militarum for sure but it could be quite a few more. There would be a lot more single codex lists out there and therefore a lot more list diversity if the faction rules were that you have to be single faction to compete for the best in faction award. The current ITC faction rules are neither simple nor are they doing much to achieve a broad diversity where everyone has something to play for; unless you play Necrons, T'au or Orcs you are basically a chump for not playing allies as a result of their faction rules. At this point in time I really have no idea what the ITC faction rules and faction prizes are even supposed to achieve, whatever it is I struggle to believe that they do so. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256201 Share on other sites More sharing options...
chapter master 454 Posted February 14, 2019 Share Posted February 14, 2019 Quick Reminder to all those who may be forgetting a few things: Imperial Soup is often targetted here but want to just real quickly and gently remind all that Ynnari is just space elf talk for "Elf Soup". Not to mention lets remember Ynnari bring far more horrible mechanics to the game like say soul burst where they can double tap and even break game sequence without any penalty. Other than that, love the commentary so far. Some nice low-blows at the castellan I see here and there but that's fine, the volcano lance is dirty enough to deserve it (and I should know, I've used it enough! Really does get rid of armour quite nicely. It's like Cillet Bang, but for armour! Bang and the tank is gone!). Some nice ideas too. Certainly the top two imo are some simple but elegant solutions: You only get +3 CP to your list (you know, for being battle-forged) if you entire army shares in only one keyword (that isn't imperium or any of the other MASSIVE faction words. Might want to slap astartes in there and make it down to the regiment and chapter too). Can only use stratagems from your warlords faction. Those two certainly ring out and would be nice SUBTLE changes to how the current top tier works. Certainly stops Eldar bringing their darker cousins along purely as counter magic and even would help make ynnari actually pay a price for their soulburst. As for Imperial lists, would mean our castellan now has an actual weakness instead of having a 3++ available to tank the hits along with consistency with their raven strat (which to be honest isn't even that needed. Seriously, the thing hits like a dump truck already). Just remember folks, don't just focus on the top dogs. You take out the top dogs too hard you might just install a new villain instead of balancing things. Gentle adjustments will always be slow to work but are far less damaging than massive overhauls in the overall. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256227 Share on other sites More sharing options...
H311fi5h Posted February 14, 2019 Share Posted February 14, 2019 I've done some thinking on this topic for a while now. Reducing the issue too CP batteries and strategem access is missing the root problem. When you add a second codex to your army you get access to things that you otherwise wouldn't be able to get. Those things can be CP, they can be strategems, but that's not the fundamental issue. Simple example: Take a mono DE army, say a coven with talos spam and some cabal stuff. That's a pretty competitive list to start with. Now you just add in an auxiliary support detachment with a Farseer to get access to Doom. Your list just got 30% stronger. No CP or strategems were gained in the example (in fact CP were lost). Yet the mixing of factions improved the previous mono-list. A codex is like a tool box with a specific set of tools. A plumber's toolbox looks different that a watchmaker's or a car mechanic's. Every set of tools is good a dealing with certain things, and lacks in some other department. And some cover a wider range than others. But when you can just pick any tool you want straight from the hardware store, all limitations are gone. That is why "souping" is almost always better than going mono. So what can a solution look like? For that you need to define a goal first. Some people here don't want mixed faction armies at all, some love it. I think a reasonable goal to make as many players as possible happy is this: Enable all styles of play to create competitive lists. Whether you collect an all Imperium mix, or pure Space Marines. Let the guy who likes pure Black Templars be competitive, but don't ruin it for guy who likes guardsmen side by side with knights. How can this be achieved? I say add a cost to choice and reward accepting limitations. The CP system is a pretty good basis, but needs some rework. My idea: Every faction detachment should get a specific benefit/cost for primary and allied use (defined by the warlord), while the default 3 CP for battle forged go away. Some examples: Astra Militarum get +2/-3 meaning if you take an Astra Militarum Warlord, every Astra Militarum detachment adds 2 CP to your army. If you have a different Warlord, every AM detachment will cost you 3 CP. Custodes would get +4/-2 since they have a much harder time fielding multiple detachments, but add fewer options. This change does two things: A primary AM battalion is now worth 7 CP, while a Custodes battalion is worth 9, balancing how hard it is for different factions to generate CP. And more importantly, it means mixing in a Custodes detachment into an AM army will cost you effectively 4 CP (over taking another AM detachment of the same type). Craftworld Eldar might get +3/-4 since they add a huge selection of options but have a harder time to get CP as a main faction compared to AM. At -5 CP total that Doomseer would be a really hard sell suddenly. This is not hard to do for all factions and could be a simple update with Chapter Approved or even an FAQ. No fundamental rules rewrite required, just two numbers per codex. That way mono-builds get buffed, especially those factions with a hard time generating CP's. But mixing factions is still possible at a cost, making it not necessarily a better choice than going pure. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256240 Share on other sites More sharing options...
Cryptix Posted February 14, 2019 Share Posted February 14, 2019 I'm against any solution that prevents me from using stratagems from other codex, because it means I can't use my things like the Loci stratagems or warpsurge on possessed units in my daemonkin army, which is extremely fluffy and one of the main selling points of chaos. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256249 Share on other sites More sharing options...
CaptainMarsh Posted February 14, 2019 Share Posted February 14, 2019 The Knight Codex made filling out a Knight army in a certain fashion give extra CP. It makes mono-Knight armies not intensely CP starved, even if Soup Knights still get access to more and are thus more efficient. Point being, that little nugget makes Knight armies far more viable than they would have been otherwise. The idea I have jumps off from thereSimilarly, doing such with most other codices (choose a detachment type, filling it out gives X/Y benefit) would at least give them more individual girth. Then make it so they get the additional CP and another additional gameplay benefit, and all of this is lost if you have detachments in your army from outside of the same codex. You boost mono, don't harm soup, have more options. Perfect? By no means perfect. I can see flaws. But it would be interesting to see. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256280 Share on other sites More sharing options...
kombatwombat Posted February 14, 2019 Share Posted February 14, 2019 I've done some thinking on this topic for a while now. Reducing the issue too CP batteries and strategem access is missing the root problem. When you add a second codex to your army you get access to things that you otherwise wouldn't be able to get. Those things can be CP, they can be strategems, but that's not the fundamental issue. Simple example: Take a mono DE army, say a coven with talos spam and some cabal stuff. That's a pretty competitive list to start with. Now you just add in an auxiliary support detachment with a Farseer to get access to Doom. Your list just got 30% stronger. No CP or strategems were gained in the example (in fact CP were lost). Yet the mixing of factions improved the previous mono-list. A codex is like a tool box with a specific set of tools. A plumber's toolbox looks different that a watchmaker's or a car mechanic's. Every set of tools is good a dealing with certain things, and lacks in some other department. And some cover a wider range than others. But when you can just pick any tool you want straight from the hardware store, all limitations are gone. That is why "souping" is almost always better than going mono. So what can a solution look like? For that you need to define a goal first. Some people here don't want mixed faction armies at all, some love it. I think a reasonable goal to make as many players as possible happy is this: Enable all styles of play to create competitive lists. Whether you collect an all Imperium mix, or pure Space Marines. Let the guy who likes pure Black Templars be competitive, but don't ruin it for guy who likes guardsmen side by side with knights. How can this be achieved? I say add a cost to choice and reward accepting limitations. The CP system is a pretty good basis, but needs some rework. My idea: Every faction detachment should get a specific benefit/cost for primary and allied use (defined by the warlord), while the default 3 CP for battle forged go away. Some examples: Astra Militarum get +2/-3 meaning if you take an Astra Militarum Warlord, every Astra Militarum detachment adds 2 CP to your army. If you have a different Warlord, every AM detachment will cost you 3 CP. Custodes would get +4/-2 since they have a much harder time fielding multiple detachments, but add fewer options. This change does two things: A primary AM battalion is now worth 7 CP, while a Custodes battalion is worth 9, balancing how hard it is for different factions to generate CP. And more importantly, it means mixing in a Custodes detachment into an AM army will cost you effectively 4 CP (over taking another AM detachment of the same type). Craftworld Eldar might get +3/-4 since they add a huge selection of options but have a harder time to get CP as a main faction compared to AM. At -5 CP total that Doomseer would be a really hard sell suddenly. This is not hard to do for all factions and could be a simple update with Chapter Approved or even an FAQ. No fundamental rules rewrite required, just two numbers per codex. That way mono-builds get buffed, especially those factions with a hard time generating CP's. But mixing factions is still possible at a cost, making it not necessarily a better choice than going pure. This person talks sense. We should all try to emulate this person. Your defining of the problem and the aim of a solution are excellent. Your solution is pretty good, but it does penalise soup slightly - which GW have stated they’re conceptually against. Which is extraordinary unfortunate as it really makes solving their problem incredibly hard. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256287 Share on other sites More sharing options...
kombatwombat Posted February 14, 2019 Share Posted February 14, 2019 CaptainMarsh has just given me an idea on how to kill - or at least injure - two birds with one stone. The second bird being a common complaint that armies that ‘look like the ones in the stories’ just suck competitively. It’s kind of similar vein to Vigilus Formations: - Release a set of army-specific Detachments, one or two for each Codex, where every unit in the Detachment has to share a specified keyword, such as <Chapter>/<Regiment> - Make every one give +3CP for up to a 1000pt game, +6CP for up to 1500pts or +9CP for up to 2000pts - If you choose to use this Detachment, you may only use one Detachment total - Make this an option only; still allow players to use normal Detachments if they prefer - Since they’re Codex-specific, you can tailor the Detachment to each army; for instance, Custodes might have 2-6 Troops, 1-4 Elites and 1-2 HQs and 0-3 of the rest, while Guard might have 6-12 Troops, 2-5 HQs, 3-6 Heavy and 0-3 of the rest, and Eldar might have 1-3 HQs, 3-6 Fast Attack, etc etc - down the track, you’ve got the option of adding more themed ones - like Deathwing or Haemonculus Covens You end up with an army that looks like the stories, from a mono-Codex, has 12CP and can compete on a closer-to-fair footing with Soup armies. You can also sell players a book of these things, and you don’t stop people playing their current armies or penalising Soup, you just add options. Another idea that isn’t perfect, but I reckon this one has merit. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256298 Share on other sites More sharing options...
Huggtand Posted February 14, 2019 Share Posted February 14, 2019 GW already have one rule that would make mixing factions less attractive. In Kill Team Rogue Trader the CP generated by the Elucidian starstrider warlord trait can only be used by that faction. If CP only could be used by the faction that generated it I actually think it would be a more balanced game. Now you cant boost your talos with the CP from your allied guardians or bost a castellan with CP from a guard brigade. It would mean a little more bookkeeping but not much more then to have markers in different colors to keep track on what CP belongs to witch detachment. This would of course just make allies less attractive. To make mono-codex more viable is a different kettle One big reason why people takes allies is to fill a shortcoming in their own codex, be it to ad a cheap screen for knights or close combat hammer for guards. So long as there is a big weakness in a codex an allied list that removes that weakness will always be better than the mono-codex list. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256337 Share on other sites More sharing options...
Panzer Posted February 14, 2019 Share Posted February 14, 2019 I'd be fine with that but it would be quite a bit more bookkeeping I guess. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256353 Share on other sites More sharing options...
PiñaColada Posted February 14, 2019 Author Share Posted February 14, 2019 I think separate CP pools require too much bookkeeping, if you have 3 different detachments then you'd have three different pools. Would you be able to spend a CP for a generic command re-roll on a unit from detachment B with CPs from detachment A? I find that some players already has trouble keeping up with a singular pool, even at higher levels of play. You'll see it a tournaments because of the time crunch. It's also a chore to explain to newer players.Not to mention that if the opponent you're facing is someone you don't know/don't really trust for whatever reason you have to keep track of potentially 6 CP pools and the regeneration that comes along with them.I feel like any solution needs to be really simple to understand both from a rules perspective and when you're actually playing and seeing your own and your opponents CP. That's one of the reasons I really like the structured approach to new CP generation. Everyone goes through the same steps to calculate their starting CPs, so it's super easy.I don't understand how any balance can be achieved if GW truly does not want to "punish" allies at all. The benefits you can potentially get from allies are too many to count, so whatever bonus you'd give mono-dex armies would have to be crazy good. Would you still give that bonus to armies that can't ally, like tau? Or do you only give it if someone brings lets say, a pure Borkan list? Stabilising CP generation makes even a small CP cost significant because you can no longer go into a game with a brigade and a battalion netting you 20CPs to start with. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256359 Share on other sites More sharing options...
MARK0SIAN Posted February 14, 2019 Share Posted February 14, 2019 Whilst I have no problem with the principle that each faction can only use their own CP I would only support it myself if it came with some adjustments to how easy it is for some factions to generate CP whilst others really struggle. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256364 Share on other sites More sharing options...
Slasher956 Posted February 14, 2019 Share Posted February 14, 2019 I'd be fine with that but it would be quite a bit more bookkeeping I guess. Sure I've said this before.... but that would hurt the game... lets have a look at what a sisters of battle player would have to track: Victory points Objective cards CP - primary CP - secondary Strategems (differing costs & timings) Faith points Acts of faith (they have different values and timings) unit stats weapon stats Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256411 Share on other sites More sharing options...
Panzer Posted February 14, 2019 Share Posted February 14, 2019 I'd be fine with that but it would be quite a bit more bookkeeping I guess. Sure I've said this before.... but that would hurt the game... lets have a look at what a sisters of battle player would have to track: Victory points Objective cards CP - primary CP - secondary Strategems (differing costs & timings) Faith points Acts of faith (they have different values and timings) unit stats weapon stats Literally just one more thing than others. I don't count Faith points and Acts of faith as two separate points. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256417 Share on other sites More sharing options...
killersquid Posted February 14, 2019 Share Posted February 14, 2019 The new genestealer cult codex I think has a good way of mitigating soup. Allied detachments earn half cp, and cannot get a warlord trait or artifacts. That alone would fix a lot of problems. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256481 Share on other sites More sharing options...
Khulu Posted February 14, 2019 Share Posted February 14, 2019 The new genestealer cult codex I think has a good way of mitigating soup. Allied detachments earn half cp, and cannot get a warlord trait or artifacts. That alone would fix a lot of problems. Is there a picture of that rule? Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256542 Share on other sites More sharing options...
Panzer Posted February 14, 2019 Share Posted February 14, 2019 The new genestealer cult codex I think has a good way of mitigating soup. Allied detachments earn half cp, and cannot get a warlord trait or artifacts. That alone would fix a lot of problems. Is there a picture of that rule? It's not like the Codex isn't already released or something. We are past the rumours phase. :D If your army is Battle-forged, you can onlyinclude one ASTRA MILITARUM Detachment (one in which every unit has the ASTRA MILITARUM keyword) in your army for each GENESTEALER CULTS Detachment in that army. You cannot include ASTRA MILITARUM named characters in these Detachments, and these Detachments cannot be Specialist Detachments. These ASTRA MILITARUM Detachments are then known as BROOD BROTHERS Detachments, and every unit in them that has the <REGIMENT> or MILITARUM TEMPESTUS keyword must replace it in every instance on its datasheet with BROOD BROTHERS (if a unit does not have either of these keywords, it simply gains the BROOD BROTHERS keyword). BROOD BROTHERS Detachments do not gain any of the Detachment abilities listed in Codex: Astra Militarum, such as Regimental Doctrines, nor can they use any regiment-specific Stratagems, Orders etc. Furthermore, INFANTRY models in BROOD BROTHERS Detachments increase their Leadership characteristic by 1 and they gain the Unquestioning Loyalty ability (pg 78). Units in BROOD BROTHERS Detachments do not gain the Cult Ambush ability. Your Warlord cannot be from a BROOD BROTHERS Detachment, and you cannot give any Relics to BROOD BROTHERS CHARACTERS. In addition, the Command Benefits of all BROOD BROTHERS Detachments included in your army in this way are halved (rounding up). This reflects that such Detachments are not a Genestealer Cult’s primary fighting force, and the acquisition of such military assets is costly in terms of resource. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256544 Share on other sites More sharing options...
NatBrannigan Posted February 14, 2019 Share Posted February 14, 2019 Can't we just scrap command points...? Please? They're painful :( I end up dozens of the damn things for my Guard (Actual Guard, Mono Guard, not 3 Knights and a smattering of Guardsmen) and the Strategems are pretty meh for the most part. I guess I could take a Knight to use the Command points on, thus completing the hideous circle of command points. Link to comment https://bolterandchainsword.com/topic/353847-lvo-is-in-the-bag-soup-is-still-on-the-menu/page/3/#findComment-5256574 Share on other sites More sharing options...
