Excessus Posted March 9, 2019 Share Posted March 9, 2019 +++TEMPUS BELLI+++ *A time of war* The bio-mechanical serpents slithered around him, consuming the armours, bodies and very souls of the fallen lying strewn around on the ground. They had once been his mechadendrites, but that was ages ago and now they acted with a daemonic intelligence and purpose both with and without his command. Back in the eye he had dabbled in abominable intelligence to rebuild them, a mystic and secretive science with an abundance in danger. He remembered well the warnings in the texts about the Men of Iron, and the danger they possessed. He had been very careful when it came to designing them, and in the end the daemonic possession to them was a boon if anything, since it meant he could construct pacts and sorcery to keep them under his control. "-Grrraaawrgggh" The mechanical beast let out a low growl as the serpents began to repair it under his guidance. It had suffered greatly under the assault but was still alive...if you could truly call what it had "life". His own mechanical mount was grazing a short distance away, like a tamed dairy beast of old but instead of grass, it consumed the very essence of the reality around it. A binary chant on his inter-vox notified him of a gathering of daemon engines that needed direction, and he called over his mount to move out and take charge of them. The Masters of Possession were very good at creating these monstrosities, but to control them they had less...authority... The damaged machine was repaired enough and would recover in due time, and it happily skittered after him when he moved toward the other machines and towards battle... At long last, reinforcement has arrived for our beleaguered chaos forces. New models are inbound and the chaos warlords are eagerly awaiting their arrival! What better time to stage a modelling contest amongst the frater? None, I'd say especially with all the goodies that are coming out. +++ This will be a modelling challenge for all you chaos-lovers out there, and even those only dabbling a bit in chaos, dipping their toes in the warp and will forever be tainted hereafter we hope... The challenge involves you, frater, pledging to complete building one of the following detachments. After you have finished one, you are free to pledge another one. For the insane of you, you are welcome to collect all of the badges... Your pledge will start with you posting in this thread with your vow to complete one of the detachments above (ie. "I, Excessus, pledge to complete a Brigade detachment before the first of may, 2019, for the glory of the chaos gods"...or something like that). You can then collect your participation badge: Then you will need to post a picture of sprues or bits, proving that you are starting your pledge. And finally, you need to post a picture of your finished detachment before the time limit. Short FAQ: Q: Can I pledge partially built models? A: Yes, if there will be improvement enough on them. If you are unsure, send me a PM. Q: Can my finished models be magnetised or purposefully not put together because of painting styles etc? A: Yes, magnets or glue doesn't matter. If you paint your marines unassembled I would suggest you prop them up with blue-tac or similar products to not just have a picture of a pile of bits. Nothing can be still on a sprue though... Q: Can I mix my detachments between the different chaos armies? R&H, Daemons, Knights and so on. A: Yes, chaos forever! Q: I have a model that has been built a little, would that be ok? A: It depends. If it is fully built or very near completition (just an arm missing or such) then no, but if there will be a lot of improvement (conversion, GS and such) then it would be fine. If you're unsure send me a PM. That should do it! Go ahead and make your vows and collect the badges! If you have any questions or are unsure about anything, just go ahead and ask. Let the building begin! Update: Excessus - Battalion Gederas - Battalion Pre Post Dragonlover - Battalion Pre Prot - Battalion Eldrick Shadowblade - Patrol Pre Post Marshal van Trapp - Vanguard Pre Post tordeck - Vanguard Post tordeck - Spearhead Post tordeck - Battalion Pre Sgt. Blank - Patrol Pre Post El_Dicko - Battalion Pre Post Lord Th Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/ Share on other sites More sharing options...
Excessus Posted March 16, 2019 Author Share Posted March 16, 2019 I, Excessus, pledge to complete a Battallion detachment before the first of may, 2019, for the glory of the chaos gods! Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277507 Share on other sites More sharing options...
Gederas Posted March 16, 2019 Share Posted March 16, 2019 Q: Can my finished models be magnetised or purposefully not put together because of painting styles etc? A: Yes, magnets or glue doesn't matter. If you paint your marines unassembled I would suggest you prop them up with blue-tac or similar products to not just have a picture of a pile of bits. Nothing can be still on a sprue though... This is good for me, because I'm vowing Shadowspear and some of those models are IMPOSSIBLE to paint without sub-assemblies (the Obliterators and Master of Possession) Speaking of which: I, Gederas, pledge to complete a Battalion detachment of Word Bearers before the first of May 2019, for the glory of the chaos gods! Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277575 Share on other sites More sharing options...
Dragonlover Posted March 16, 2019 Share Posted March 16, 2019 I, Dragonlover, pledge to complete a Battalion before May 1st for the glory of the Gods! Current plan is finish a Daemon Prince and a Deredeo, build at least one lot of Shadowspear and 20 Cultists. I may follow up with the Gellerpox Infected and some of a second lot of Shadowspear, we'll see how things pan out. For reference, here's pics of the started stuff so it's all above board. The legs aren't even glued in that pic of the Deredeo, it's just balancing precariously. Sprues of Cultists: Dragonlover Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277576 Share on other sites More sharing options...
Excessus Posted March 16, 2019 Author Share Posted March 16, 2019 Since I know you're gonna fill him up with scales all over and other GS details from the PM, it's approved...as long as there is enough improvement. :) You really do love dragons, don't you Dragonlover...lol Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277590 Share on other sites More sharing options...
Dragonlover Posted March 16, 2019 Share Posted March 16, 2019 Yup. I'm a surprisingly literal bloke at times. I will say though, if only I'd waited a decade, I could have used Morathi as a base instead! Dragonlover Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277593 Share on other sites More sharing options...
Gederas Posted March 16, 2019 Share Posted March 16, 2019 Okay, here's the 'before' picture. It's basically three of the Chaos half of Shadowspear: Dunno what the other HQs will be after the Master of Possession :lol: Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277741 Share on other sites More sharing options...
Con_Arti7t Posted March 16, 2019 Share Posted March 16, 2019 How do you guys upload images? I am on iPhone and having tried a bunch of image compression solutions but nothing has worked. I would love to add my shadowspear box to this challenge so any advice is appreciated! Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277782 Share on other sites More sharing options...
Dragonlover Posted March 16, 2019 Share Posted March 16, 2019 I tend to send my pics to someone via Facebook messenger from my phone then download them from there, that tends to compress them enough for the gallery. Welcome aboard by the way! Dragonlover P.S: Remember folks, don't put any paint on these guys just yet. There's honour to regain in a few months... Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277794 Share on other sites More sharing options...
Tordeck Posted March 17, 2019 Share Posted March 17, 2019 /in for a Patrol to start. MoP and 10 CSM Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277810 Share on other sites More sharing options...
Prot Posted March 17, 2019 Share Posted March 17, 2019 I’m in for the Battalion but to be honest I’ll keep going with paint. I have to or I’ll lose momentum! Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277839 Share on other sites More sharing options...
Eldrick Shadowblade Posted March 17, 2019 Share Posted March 17, 2019 I, Eldrick Shadowblade, pledge to build a Nurgle Patrol before the first of may, 2019, for the glory of the Brotherhood of the 7th Circle and Plaguefather. Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277853 Share on other sites More sharing options...
Marshal van Trapp Posted March 17, 2019 Share Posted March 17, 2019 I, Marshal Van Trapp, having lost my mind, do hereby pledge to build one vanguard detachment before the first of May, 2019, for the glory of the dark gods! Going to pick up 2 shadowspeers later today and when I do I'll post a pick of the chaos sprues Edit: as promised two shadowspear chaos sides, for this first detachment I'm building the chaos marines as possessed, the 4 greater possessed, and master of possession Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5277990 Share on other sites More sharing options...
Gederas Posted March 17, 2019 Share Posted March 17, 2019 30 Chaos Marines, 4 Greater Possessed, 2 Obliterators and a Master of Possession all assembled. Sadly, I don't have that much poster-tac :lol: I'll try and get a picture with them all together, but no promises of all of them with their bolters across their chests :lol: Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5278226 Share on other sites More sharing options...
Excessus Posted March 17, 2019 Author Share Posted March 17, 2019 30 Chaos Marines, 4 Greater Possessed, 2 Obliterators and a Master of Possession all assembled. Sadly, I don't have that much poster-tac I'll try and get a picture with them all together, but no promises of all of them with their bolters across their chests And the office supply retailers in your area suddenly sensed a disturbance in the force... ...it'll probably be fine, once you got some "assembled" send me a pic in a PM. Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5278231 Share on other sites More sharing options...
Gederas Posted March 17, 2019 Share Posted March 17, 2019 30 Chaos Marines, 4 Greater Possessed, 2 Obliterators and a Master of Possession all assembled. Sadly, I don't have that much poster-tac I'll try and get a picture with them all together, but no promises of all of them with their bolters across their chests And the office supply retailers in your area suddenly sensed a disturbance in the force... ...it'll probably be fine, once you got some "assembled" send me a pic in a PM. I'll take a picture once I come down from Saturn thanks to all that plastic glue :lol: Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5278235 Share on other sites More sharing options...
Gederas Posted March 18, 2019 Share Posted March 18, 2019 Update: Here's the other HQ so the Battalion is legal, a Word Bearers Sorcerer (Mark of Nurgle): Man, that guy was fun to kitbash Edit:Had an idea, might use a different head. Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5278328 Share on other sites More sharing options...
Darnok Posted March 18, 2019 Share Posted March 18, 2019 Be gentle, this is my first time. A few questions: This is purely about building, right? So base decoration is not mandatory, same as any form of painting or even priming? What do you do for a Superheavy detachment with Thousand Sons or Death Guard? They only have their respctive (unique) primarch - what would the other two choices be? I assume the new Khorne altar and "Stargate" each count as a Fortification, and do not forget the Nurgle tree available for Daemons. So will you add a pledge/badge for that detachment as well? Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5278487 Share on other sites More sharing options...
Excessus Posted March 18, 2019 Author Share Posted March 18, 2019 Be gentle, this is my first time. A few questions: This is purely about building, right? So base decoration is not mandatory, same as any form of painting or even priming? What do you do for a Superheavy detachment with Thousand Sons or Death Guard? They only have their respctive (unique) primarch - what would the other two choices be? I assume the new Khorne altar and "Stargate" each count as a Fortification, and do not forget the Nurgle tree available for Daemons. So will you add a pledge/badge for that detachment as well? No worries, we all start somewhere. :D 1. Yes, pure building. No base decorations are needed, and neither priming or painting. 2. Hmm, can't they take from the FW index? 3. Initially I made a decision not to go for fortifications, but I might have to think a bit more on that now that we'll be getting a stargate and such. Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5278521 Share on other sites More sharing options...
Dragonlover Posted March 18, 2019 Share Posted March 18, 2019 Doesn't the Supreme Command detachment have a Lord of War slot? Could use that for Magnus/Mortarion if you've got normal HQ to build? Dragonlover Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5278590 Share on other sites More sharing options...
Darnok Posted March 18, 2019 Share Posted March 18, 2019 2. Hmm, can't they take from the FW index? I had not thought about them at the time, but you are of course correct. There will be no FW stuff in my Chaos armies though, at least for now. Doesn't the Supreme Command detachment have a Lord of War slot? Could use that for Magnus/Mortarion if you've got normal HQ to build? It has them as an optional choice, aye. There is also the Super Heavy Auxiliary Detachment. I was just asking out of curiosity anyway: my Magnus is built already, and I have no intentions of getting Mortarion anytime soon. Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5278751 Share on other sites More sharing options...
Dragonlover Posted March 18, 2019 Share Posted March 18, 2019 Well, I've got all the Cultists built, taking me to 66 in my Alpha Legion. Gives me a nice solid base for the Call of Chaos later in the year. Dragonlover Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5278755 Share on other sites More sharing options...
Gederas Posted March 18, 2019 Share Posted March 18, 2019 And done. That's 30 Chaos Marines, 2 Obliterators, a Master of Possession, a Chaos Sorcerer and 4 Greater Possessed. Battalion: Complete Good GOD getting all the backpacks to stay on with the poster-tac was an exercise in frustration :lol: Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5278812 Share on other sites More sharing options...
Marshal van Trapp Posted March 20, 2019 Share Posted March 20, 2019 And My Vow to the Dark God Slaanesh is complete. One Vanguard Detachment, the Chords of Oblivion: Featuring, Solo Performances by Alpharius Jackson and Dr. Rockso, the Rock and Roll clown (2 Greater Possessed): A group Performace by KILL (Possessed Chaos Space Marines): And our headliner, The Master of Puppets! (Master of Possession): Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5280023 Share on other sites More sharing options...
Tordeck Posted March 20, 2019 Share Posted March 20, 2019 Changing my vow. Not a Patrol anymore. Going to do a Vanguard, a Spearhead, and an Outrider MoP GP GP 10 Noise Marines Abby or Disco Oblit Oblit VC LoC FBD FBD FBD Link to comment https://bolterandchainsword.com/topic/354417-tempus-belli-is-live/#findComment-5280060 Share on other sites More sharing options...
