Dark Bjoern Posted March 11, 2019 Share Posted March 11, 2019 Like the title says. When i take a look at the GW homepage there´s only one set of terrain aviable. I know more will follow. But what alternatives do we have? What did you use for your battlefield? Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/ Share on other sites More sharing options...
Warsmith Uveron Posted March 11, 2019 Share Posted March 11, 2019 Like the title says. When i take a look at the GW homepage there´s only one set of terrain aviable. I know more will follow. But what alternatives do we have? What did you use for your battlefield? I have been using that one box, and then a mix of other 40k items that do not look out of place. Compared to most of GWs terrain line the AT stuff is affordable and easy to build some interesting and good looking buildings. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5274531 Share on other sites More sharing options...
Cpt. Bannockburn Posted March 11, 2019 Share Posted March 11, 2019 I bought the .. Dark Assembly 8mm stuff it's called I think. Pretty cheap, lasercut MDF, but looking nifty. I'm not sure yet if I want to paint it. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5274610 Share on other sites More sharing options...
Sherrypie Posted March 11, 2019 Share Posted March 11, 2019 Some use Dropzone buildings, personally going to scratchbuild a ton from household waste and Civitas bits When I Have Time . Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5274625 Share on other sites More sharing options...
schoon Posted March 11, 2019 Share Posted March 11, 2019 A quick search for 6mm, 8mm, and 10mm terrain will yield quite a few results, but here are a few: OTP Terrain — Some really inventive 3D-printed designs, including cranes, trains, and modular buildings. Kore Aeronautics — 3D-printed containers, trucks, and bits. Blotz 10mm Terrain — A very nice range that can be adapted easily. They also have a 6mm range. BP Laser 6mm Terrain — Another good range with great 40K/Gothic feel. XOLK — A small range, but with a good Gothic style. War Mage 10mm Terrain — Another good range of terrain that will easily adapt to AT. Game Craft 10mm Terrain — Smaller range, and bit more modern in feel. Dark Zone 10mm Terrain — More modern in feel, but an excellent Power Generator. Honey Bee Works 6mm Terrain — Though it might be a little small for the new scale, these sets are made for AT. Recommended Interrogator Stobz and Canadian_F_H 2 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5274683 Share on other sites More sharing options...
Mendi Warrior Posted March 12, 2019 Share Posted March 12, 2019 So far, a mix of civitas imperialis, old Epic ruins, old FW Epic buildings, old Cities of Death components, foamboard, plasticard and various other bits (incl. old milk bottles). Don't hesitate to check my project log for some examples. For those looking at the OTP Terrain in the above list, if you have a 3D printer, I can only recommend checking the source of these designs. They can be found on: https://warlayer.com/ There is also a list of the licensed printers (with a wider geographical spread). There is a FB group where many do print these designs for AT, so recommendations for sizing can be found there or simply ask the designer directly. I don't have a 3D printer yet but I nevertheless grabbed the Zone One - Late Pledge at USD50 as well as a couple others. I also came across the "Dark Gothicus" terrain made by DarkOps in the UK, the interesting element is that each building comes with both an intact and a destroyed version https://www.darkops.co.uk/collections/dark-gothicus There is also the Dark Assembly range by https://scenics.warcradle.com/ https://scenics.warcradle.com/red-beam-products/dark-assembly-8mm-city https://scenics.warcradle.com/red-beam-products/dark-assembly-8mm-factory (there are some pics on Instagram with a Cerastus knight inside of the factory, can't find the link) and the 4Ground micro-scale range https://www.4ground.co.uk/scifi-micro From Game Craft there is also a 6mm range e.g. http://gcmini.mybigcommerce.com/6mm-european-city-buildings/?sort=newest&page=1 where you can find a couple of interesting buildings (matboard ruined and intact buildings, Stalingrad factory, airship hangar, …). The matboard buildings have relatively few details but adding plasticard buttresses improves them a lot. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5274821 Share on other sites More sharing options...
Dark Bjoern Posted March 12, 2019 Author Share Posted March 12, 2019 Thanks alot. I was also looking for terrain, but all i found was WW II terrain. Okay, i searched for 15mm cause i thought AT is 15mm scale. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5274939 Share on other sites More sharing options...
Canadian_F_H Posted March 12, 2019 Share Posted March 12, 2019 Awesome linkage. I've seen some cool stuff on InstaG... Almost makes me want to get into AT... Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5274944 Share on other sites More sharing options...
noigrim Posted March 12, 2019 Share Posted March 12, 2019 Look around your house, you're bound to have some spare piping, cans and such which can be readily turned into terrain with a slap of paint. For buildings I print the facade in paper and stick it over cardboard structures. Insulation boards are ideal for hills, craters and the kind. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5275125 Share on other sites More sharing options...
malika666 Posted March 13, 2019 Share Posted March 13, 2019 Bunkers, trenches, etc: https://vanguardminiatures.co.uk/product-category/terrain/battlescene-designs-terrain/ Amphelion proxies and shanties: https://vanguardminiatures.co.uk/product-category/terrain/gregsters-lab-terrain/ Alternative plastic terrain: https://vanguardminiatures.co.uk/product-category/terrain/troublemaker-games-terrain/ Various grimdark buildings: https://vanguardminiatures.co.uk/product-category/terrain/wasteland-game-studio/ Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5276011 Share on other sites More sharing options...
Exilyth Posted March 14, 2019 Share Posted March 14, 2019 http://www.hirstarts.com/ - sells silicone molds: Pour some plaster, make as many blocks as you need. Molds like http://www.hirstarts.com/starfort/starfort.html would probably go good with AT and some of the more abstract molds with just shapes could be used for all kinds of structures. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5276075 Share on other sites More sharing options...
Rabenga Posted March 15, 2019 Share Posted March 15, 2019 (edited) I have been pondering the Hirst Arts stuff... I may take the plunge. Edited March 15, 2019 by Rabenga Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5277111 Share on other sites More sharing options...
malika666 Posted June 14, 2019 Share Posted June 14, 2019 So this is happening... https://www.kickstarter.com/projects/smallscaleterrain2/smallscale-plastic-terrain-kits-2 CaptainFrederickson and Mendi Warrior 2 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5331442 Share on other sites More sharing options...
Fajita Fan Posted June 14, 2019 Share Posted June 14, 2019 *drool forming* malika666 and Mendi Warrior 2 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5331491 Share on other sites More sharing options...
Mendi Warrior Posted June 15, 2019 Share Posted June 15, 2019 Drool /dru:l/ verb 1. drop saliva uncontrollably from the mouth synonymes: salivate, dribble, slaver, slobber, drivel, water at the mouth, slabber malika666 1 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5331670 Share on other sites More sharing options...
Warsmith Annüss Posted June 15, 2019 Share Posted June 15, 2019 The Troublemaker stuff looks amazing. malika666 1 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5331795 Share on other sites More sharing options...
Rabenga Posted June 15, 2019 Share Posted June 15, 2019 I concur wholeheartedly malika666 1 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5332012 Share on other sites More sharing options...
Troublemaker Games Posted June 18, 2019 Share Posted June 18, 2019 Glad you like the campaign guys! We've added a bunch more STL files in the last two campaign updates - any requests for extra sculpts you'd like to see, to convince you to jump in too? :-) Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5333600 Share on other sites More sharing options...
Fajita Fan Posted June 18, 2019 Share Posted June 18, 2019 A crane. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5333603 Share on other sites More sharing options...
malika666 Posted June 18, 2019 Share Posted June 18, 2019 A crane.How about this crane? https://vanguardminiatures.co.uk/shop/centurion-engineer-tank/ Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5333663 Share on other sites More sharing options...
Fajita Fan Posted June 18, 2019 Share Posted June 18, 2019 That’s a good wrecker but I mean a construction crane; https://www.ishn.com/ext/resources/900x550/construction-crane-900.jpg?1551183756 malika666 1 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5333683 Share on other sites More sharing options...
Troublemaker Games Posted June 19, 2019 Share Posted June 19, 2019 Today's campaign update adds a crane to the STL set, then! https://www.kickstarter.com/projects/smallscaleterrain2/smallscale-plastic-terrain-kits-2/posts/2541069 Yarp. Interrogator Stobz, Warsmith Annüss and malika666 3 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5334065 Share on other sites More sharing options...
Fajita Fan Posted June 19, 2019 Share Posted June 19, 2019 NICE Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5334067 Share on other sites More sharing options...
Troublemaker Games Posted June 19, 2019 Share Posted June 19, 2019 NICE Suggest moar th1ngz. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5334075 Share on other sites More sharing options...
Rabenga Posted June 19, 2019 Share Posted June 19, 2019 Tiny grimdark trucks and cars? Tiny grimdark garbage bins? Mabey just a bunch of windows and door parts that people can use to detail home made buildings? Satellite dishes and communications bits? Stairs? malika666 and Troublemaker Games 2 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/#findComment-5334132 Share on other sites More sharing options...
