RipOffProductions Posted August 1, 2019 Share Posted August 1, 2019 They are stl files, so you can print them at any size. true, but at some point increasing their size will make the detail work look silly/out of scale, so the default/"intended" size matters. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5355999 Share on other sites More sharing options...
malika666 Posted August 2, 2019 Share Posted August 2, 2019 They are stl files, so you can print them at any size. true, but at some point increasing their size will make the detail work look silly/out of scale, so the default/"intended" size matters. The Lighter is designed as a 3mm scale model, but printing it at twice the size for true scale 6mm also works fine. Check that out here: https://www.kickstarter.com/projects/smallscaleterrain2/smallscale-plastic-terrain-kits-2/posts/2580077 Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5356460 Share on other sites More sharing options...
Mendi Warrior Posted August 2, 2019 Share Posted August 2, 2019 They are stl files, so you can print them at any size. true, but at some point increasing their size will make the detail work look silly/out of scale, so the default/"intended" size matters. The latest stl is described as: "It's mostly 28mm tall Robots, robotic tanks, robotic aircraft, and robotic gun turrets! ". So you shouldn't lose details printing at AT scale. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5356475 Share on other sites More sharing options...
Dragonlover Posted August 17, 2019 Share Posted August 17, 2019 Anyone found an AT scale Fortress of Redemption anywhere? Dragonlover Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5369295 Share on other sites More sharing options...
Interrogator Stobz Posted August 17, 2019 Share Posted August 17, 2019 Nid Infestation terrain? Not HH AT but me want. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5369334 Share on other sites More sharing options...
Exilyth Posted September 10, 2019 Share Posted September 10, 2019 Since Aeronautica Imperialis is the same scale as AT, the stuff from the 'ground targets' box/sprue should be usefull for AT too. In before "war for armaggeddon" using scratch build stompers/gargants - in proper ork player tradition. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5386011 Share on other sites More sharing options...
noigrim Posted September 11, 2019 Share Posted September 11, 2019 Aeronautica is a bit bigger tho Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5386871 Share on other sites More sharing options...
General Zodd Posted September 12, 2019 Share Posted September 12, 2019 Aeronautica is a bit bigger tho GW have stated they’re the same scale, though? Admittedly the actual gun emplacements look bigger, but then not all gun emplacements are created equal? Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5387143 Share on other sites More sharing options...
noigrim Posted September 12, 2019 Share Posted September 12, 2019 nah they are just closer to the player POV that's why they seem bigger Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5387192 Share on other sites More sharing options...
Kilofix Posted September 13, 2019 Share Posted September 13, 2019 (edited) So anyway, a little exorbitant but I just found the Arutan: http://www.blueforgeterrain.com/store/p9/Titan_Lander.html Edited September 13, 2019 by Kilofix Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5387746 Share on other sites More sharing options...
malika666 Posted September 13, 2019 Share Posted September 13, 2019 Titan Lander? But it cant carry even a single Warhound. :( Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5387846 Share on other sites More sharing options...
Rolltonotdie Posted September 13, 2019 Share Posted September 13, 2019 its also hideous! Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5387859 Share on other sites More sharing options...
blackbabyjesus Posted September 13, 2019 Share Posted September 13, 2019 Looks awful! Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5387863 Share on other sites More sharing options...
abraxus Posted September 13, 2019 Share Posted September 13, 2019 Sooo.... any idea when the troublemaker new stuff and 3d files become available fro general sale? Totally missed the kickstarter, but I've been burned 3 outta 3 kickstarters so far, so I'm not sure I would have used it anyway. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5387869 Share on other sites More sharing options...
malika666 Posted September 13, 2019 Share Posted September 13, 2019 Sooo.... any idea when the troublemaker new stuff and 3d files become available fro general sale? Totally missed the kickstarter, but I've been burned 3 outta 3 kickstarters so far, so I'm not sure I would have used it anyway. A raven has been sent out to find an answer to your question... Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5388272 Share on other sites More sharing options...
Kilofix Posted September 13, 2019 Share Posted September 13, 2019 Titan Lander? But it cant carry even a single Warhound. :( An AT Warhound it can! And yes, it’s hideous. But I fail to see the issue with that.... Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5388392 Share on other sites More sharing options...
malika666 Posted November 3, 2019 Share Posted November 3, 2019 Lots of new terrain out! Heavy Ordinance Defence Bunker (6mm) - £14.00 The Novan heavy ordinance defence bunker can be found all across Tusculum Nova space typically guarding the approaches to cities, starports and military installations. Variably armed and often found in mutually supporting positions alongside other defensive measures, and garrisoned by a least a platoons worth of infantry these bunkers have proven there worth during countless conflicts and are not to be underestimated. Set contains: 1 x Resin Bunker 1 x Resin heavy laser turret 1 x Resin heavy rotary cannon turret 1 x Metal radar dish Bunker dimensions: 125mm wide, 65mm depth, 15mm high, not including turrets or radar dish. Various models show for scale purposes only and are not included in the set. Note also that the resin colour may vary. https://vanguardminiatures.co.uk/shop/heavy-ordinance-defence-bunker-6mm/ Medium Landing Pad (6mm) - £7.50 A common hard landing pad design found throughout Novan territory. Set contains one resin medium landing pad in two parts. Pad dimensions: 90mm wide, 5mm in height. Various models show for scale purposes only and are not included in this set. Note also that the resin colour may vary. https://vanguardminiatures.co.uk/shop/medium-landing-pad-6mm/ Large Landing Pad (6mm) - £10.00 A common hard landing pad design found throughout Novan territory. Set contains one resin large landing pad in three parts. Pad dimensions: 185mm long, 95mm wide, 5mm high. Various models shown for scale purposes only and are not included in this set. Note also that the resin colour may vary. https://vanguardminiatures.co.uk/shop/large-landing-pad-6mm/ Single Bridge Span (6mm) - £8.00 https://vanguardminiatures.co.uk/shop/single-bridge-span-6mm/ Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5419336 Share on other sites More sharing options...
Fajita Fan Posted November 3, 2019 Share Posted November 3, 2019 This would probably work better for Titanicus terrain now that AI is a hex based tile game. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5419475 Share on other sites More sharing options...
malika666 Posted November 3, 2019 Share Posted November 3, 2019 Which is also why I posted it here rather than in the AI section. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5419482 Share on other sites More sharing options...
Fajita Fan Posted November 3, 2019 Share Posted November 3, 2019 Oh I’m on mobile, I thought this was the AI thread. malika666 1 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5419522 Share on other sites More sharing options...
Fajita Fan Posted November 11, 2019 Share Posted November 11, 2019 (edited) Those of you who've played a bunch of games - what do you think of the horizontal footprint of AT terrain? I'm using my actual AT sprues to make some nicer buildings while I've got Styrofoam and soda cans for industrial or apartment buildings, that means I want to put the nicer terrain on hardboard (clipboard) material. Would a 9"x12" be too large for most 4'x4' AT tables in terms of game flow? Old pics of the old planned cathedral I never glued together and I've 3d printed a bunch of squares for support between levels so I don't use up the roof tiles I have. Too wide? Edited November 11, 2019 by Fajita Fan Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5423820 Share on other sites More sharing options...
Emicus Posted November 25, 2019 Share Posted November 25, 2019 Terrain is destructible so just build it in sections? If it's too big: blow a wing off! Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5433787 Share on other sites More sharing options...
Fajita Fan Posted November 25, 2019 Share Posted November 25, 2019 Actually I’d given thought to making the middle of it a ruin and even taking a chunk out like a Reaver strode though with its fist...but I want to finish this within the decade. I’m a bit slow. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5433808 Share on other sites More sharing options...
Sherrypie Posted November 25, 2019 Share Posted November 25, 2019 I wouldn't say it's too wide per se, especially if you can blow parts of it up, see over it here and there or even walk over some of its bits with bigger engines. Sometimes a huge chunk is just fine in forcing the commanders to decide where they want to go early on. Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5433828 Share on other sites More sharing options...
General Zodd Posted January 25, 2020 Share Posted January 25, 2020 Just received these from eBay. They’re a UK based seller, but they credit a US based designer for the 3D printing files. Detail isn’t great, especially on the inside of the buildings, but with a bit of TLC I think they’ll work well. Marius Perdo, Bat33.1 and Captain Idaho 3 Back to top Link to comment https://bolterandchainsword.com/topic/354473-at-terrain-what-to-use/page/3/#findComment-5467439 Share on other sites More sharing options...
