IVIilitarus Posted March 23, 2019 Share Posted March 23, 2019 The Suppressor models in Shadowspear have drawn a rather mixed response instead of aesthetics. I think we need a thread for thoughts on reworking their bases for easier use and their aesthetics. The pros described for them have been that they're a nice mid-point between bulky Inceptors and the regular Tacticus marines. They provide a model for Primaris jump troops that are not heavyweight and they have finally given loyalists an autocannon variant (with an unusual role, to boot!) I don't think there's any denying that with some balance tweaks, Suppressors will be a very useful force owing to their mobility, heavy weaponry and special rules. Primaris jump troops with their own role, at fewer points than Inceptors is definitely welcome. They do however have a few things stacked against them. 1. Some players (myself included) are left wondering how those few tiny jet nozzles can lift the Astarte into the air at all, much less the long, bounding jumps promised by their unit description. 2. The models are quite busy, with a variety of extra stick-out bits to form grav-chute arrays, micro jump packs, ammunition belt feeds and a very, very long main weapon. This throws the models' proportions off and makes them appear cartoonish. This is not helped by the general soft curves and roundness of Primaris armour (in contrast to things like Iron armour). 3. Like the Inceptors models, the Suppressors seem posed without purpose. The sergeant appears to be hovering in mid-air despite their description calling for long leaps. The regular troops in the squad are posed as though they're being flung backwards due to their weapon recoil. 4. My biggest gripe with them are their bases and flying stems. They use the same base and flying stem system as Inceptors and I maintain that they are awful. My reasons are as follows: 4.1. The curved, transparent flying stems come in different lengths, making uniformity among models impossible. 4.2. The flying stems are designed to be glued onto the model (haphazardly). They do not insert into the model like flying vehicles. If you follow GW's instructions on their stands, you will end up with a bulky, double-height infantry model that does not break down into a smaller size for transportation. This is actually a step backwards from flying stems that can simply be inserted into a model and removed at will. This is especially difficult for transporting models because a stand system that breaks down consists of transporting a regular-sized infantry model, a thin stand and a flat base. An Inceptor or Suppressor built according to instructions stands twice the height of an infantry model and half of that height is a curved flight stand taking up space. 4.3. The great length of these stems makes them more prone to breaking or damage. The fact that they are curved by default introduces a slight structural weakness into the curve - the application of pressure on them will damage them more easily than shorter, straight stems. I will now follow with some suggestions and implementations of addressing the flying stand problem. 1. Some players have opted to stick their models onto scenery to give them the appearance of touching down or leaping off scenery. This helps with their posing problems and gives them a sturdier base. The models can also be magnetised to the terrain so that the implementation can be broken down for transport. 2. Some players simply stick their models to the base and skip the flying stand entirely. The main upside of this is you are now dealing with a simple, ground infantry unit for transport purposes. The downsides are that posing can still be awkward as the models were designed to have legs extended in the air. Also expect accusations of modelling for advantage, due to the shortness of this solution. Since Inceptors are Gravis based models, it is possible to do a lot of cutting and graft Inceptor bodies to Aggressor legs as well, if you can deal with the cost. 3. This creative solution for suppressors involves slicing a suppressor off at the waist and gluing it to an Aggressor body. Again, you might be accused of modelling for advantage and it's very expensive, but hey. The Photoshop mockup below also has a shortened autocannon barrel. Some people shorten the autocannon barrel to make the model appear more visually balanced and to make it easier to transport. Personally, I'm a fan of long-barrel autocannons so I'm happy to keep mine. 4. A variant of the above is chopping them off at the waist and sticking them on Phobos-pattern legs from say, a Reiver or Infiltrator kit. This would give you a leaner look than bulky Gravis and might be cheaper, since you can get away with using Easy-to-Build Reiver legs cheaply, compared to much pricier Gravis kits you'd be pretty much destroying. 5. My last solution is one I've used for my Inceptors. I don't have pictures, but it works as follows: 5.1. Very carefully drill a hole into the tip of the stem with a 0.5mm drill bit. 5.2. Fit a paperclip into the hole with super glue and leave part of it protruding as a pin. 5.3. Very carefully drill a 0.5mm hole into the model where the stem would normally attach. 5.4. Pin the model to the stem when in use. This system disassembles for transport and holds itself together without glue because gravity keeps the model impaled on the pin. If you want it to be permanent, you can simply use it as a conventional pin with superglue to strengthen the joint where the stem meets the model. Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/ Share on other sites More sharing options...
ambit Posted March 24, 2019 Share Posted March 24, 2019 Another option, if your looking for alternative bases. One of the biggest benefits is how sturdy they are.. look decent too. Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5283227 Share on other sites More sharing options...
IVIilitarus Posted March 24, 2019 Author Share Posted March 24, 2019 Another option, if your looking for alternative bases. One of the biggest benefits is how sturdy they are.. look decent too. https://www.irresistibleforce.com.au/products/primaris-inceptor-smoke-trails?variant=19058678759478 Apparently these are the item. They're quite expensive, but they're a purpose-built solution. The site also has assault marine jump pack versions. Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5283341 Share on other sites More sharing options...
Guest Triszin Posted March 24, 2019 Share Posted March 24, 2019 Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5283480 Share on other sites More sharing options...
IVIilitarus Posted March 24, 2019 Author Share Posted March 24, 2019 Looks good, Triszin - how did you accomplish it and was it difficult? Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5283540 Share on other sites More sharing options...
Guest Triszin Posted March 24, 2019 Share Posted March 24, 2019 I cut the butt of the cannon off and used the secondary armor overlay as the guide. then turned that into the shoulder bump. attached the hand to underneath the canister on the gun, then the left arm to wherever looked good. I have new ammo feeds coming in tomorrow I also used putty to reposition the legs, at the waist Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5283703 Share on other sites More sharing options...
IVIilitarus Posted June 6, 2019 Author Share Posted June 6, 2019 I've done up a set of 3 Shadowspear Suppressors using 3 easy-to-build Reiver legs and they've turned out fairly well. In my opinion, they look a tiny bit top-heavy and would have come out a little better with easy-to-build Intercessor legs but I'm quite satisfied with them already. Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5326976 Share on other sites More sharing options...
Chaplain Raeven Posted June 6, 2019 Share Posted June 6, 2019 I went the easy route and glued them on some barrels/crates. I reposed the head of the sergeant to make it seem like he's looking down to where he'll land instead of hovering like a daydreaming fool. The two other dudes are easy to mount as is. Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5327053 Share on other sites More sharing options...
dice4thedicegod Posted June 8, 2019 Share Posted June 8, 2019 I got some plastic rocks for my inceptors to stand on, gets them to the same height as the original stands and both seems more secure and looks better Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5328451 Share on other sites More sharing options...
dice4thedicegod Posted June 8, 2019 Share Posted June 8, 2019 Also, I reposed the majority of my figures. I think it’s necessary to at least do the legs - otherwise they look extremely awkward. (I mainly just chopped at the knees and made the legs more bent/springy looking. Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5328457 Share on other sites More sharing options...
Grotsmasha Posted June 12, 2019 Share Posted June 12, 2019 With a little precision, pinning into the skid plates up through the front strut is passable :tu: Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5330110 Share on other sites More sharing options...
TrawlingCleaner Posted June 12, 2019 Share Posted June 12, 2019 I used the dark imperium intercessors with a little bit of work to get my supressors to work (they need some greenstuff work at the back and some joints IMG_20190515_215134 Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5330225 Share on other sites More sharing options...
Gederas Posted June 12, 2019 Share Posted June 12, 2019 Not so much a "repose" on mine, but I made some casts of spare bits of ruined pillars from the Kill Team starter box I got to base my flying Primaris Marines. Renders them the same height as the actual flying stands too. Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5330453 Share on other sites More sharing options...
ImperialTuba Posted November 8, 2019 Share Posted November 8, 2019 I used Das modeling clay for these guys. They've held up pretty well so far. Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5422344 Share on other sites More sharing options...
Kolgrim DeathHowl Posted November 9, 2019 Share Posted November 9, 2019 Really cool bases so far guys! Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5422475 Share on other sites More sharing options...
Tichinde Posted November 11, 2019 Share Posted November 11, 2019 I used some Dragonforge bases for mine, they worked quite well: My Suppressors I have a plan/idea to mount them on discs, but haven't started them yet.... Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5423815 Share on other sites More sharing options...
FelipeFlops Posted November 12, 2019 Share Posted November 12, 2019 Another option, if your looking for alternative bases. One of the biggest benefits is how sturdy they are.. look decent too. Can confirm, really like these bases. Link to comment https://bolterandchainsword.com/topic/354752-suppressorinceptor-rebasingreposing-thread/#findComment-5424502 Share on other sites More sharing options...
