brother Vorn_GarDos Posted May 20, 2019 Share Posted May 20, 2019 I was reviewing the book and I wanted some feedback from the community. the point difference between a astrates tactical terminator & an occult terminator is 2 points. Q. Is the point difference fair after you compare the rules between the two elites? Link to comment https://bolterandchainsword.com/topic/356077-elites-point-values/ Share on other sites More sharing options...
Panzer Posted May 20, 2019 Share Posted May 20, 2019 It's the same as in regular 40k. For some reason Heretic Astartes Terminators are more expensive than Adeptus Astartes Terminators. Link to comment https://bolterandchainsword.com/topic/356077-elites-point-values/#findComment-5317242 Share on other sites More sharing options...
MegaVolt87 Posted May 20, 2019 Share Posted May 20, 2019 Don't get me started on the pts difference between CSM termi's and Wolfguard indomni termi's. Its basically the same unit but SW are cheaper pts still I believe. Link to comment https://bolterandchainsword.com/topic/356077-elites-point-values/#findComment-5317266 Share on other sites More sharing options...
MasterDeath Posted May 20, 2019 Share Posted May 20, 2019 I assume DttfE is more powerful on termies the atsknf. That would explain the point difference in my opinion. Link to comment https://bolterandchainsword.com/topic/356077-elites-point-values/#findComment-5317322 Share on other sites More sharing options...
brother Vorn_GarDos Posted May 21, 2019 Author Share Posted May 21, 2019 so the list (terminator comparison) goes from expensive to least csm terminators > adeptus terminators > sw terminators > occult terminators ... so as the codexes are released the newer terminator models are generally cheaper in point values? Link to comment https://bolterandchainsword.com/topic/356077-elites-point-values/#findComment-5317853 Share on other sites More sharing options...
Panzer Posted May 21, 2019 Share Posted May 21, 2019 Codex release order has literally zero impact considering their points got changed in Chapter Approved. Plus it's Kill Team, not 40k. Link to comment https://bolterandchainsword.com/topic/356077-elites-point-values/#findComment-5317891 Share on other sites More sharing options...
Sherrypie Posted May 21, 2019 Share Posted May 21, 2019 Welcome to Death Guard, where we pay 10 points more for semirelevant upgrades (except when your main opponent plays stormtroopers) :D But yeah, the difference is probably due to copypaste problems from 40k and DttFE. Which sucks, as that isn't a universal power. Do Scarabs have All Is Dust, still? That's also worth something against many guns like bolt rifles, hellguns etc. My main gripe with termies is that they usually are geared for both good shooting and melee, but cannot benefit from both in Kill Team as much because charges happem before shooting. Should this be reflected in points or preferably other mechanics, up to debate, but annoying nonetheless on such expensive troopers. Link to comment https://bolterandchainsword.com/topic/356077-elites-point-values/#findComment-5318061 Share on other sites More sharing options...
Stoic Raptor Posted May 22, 2019 Share Posted May 22, 2019 Do Scarabs have All Is Dust, still? That's also worth something against many guns like bolt rifles, hellguns etc. They do - and against the units that have been in KT to date, it's very powerful. However, this expansion compensates by letting in a lot of units with heavier weaponry. From a thematic standpoint, that might be better - a Terminator will withstand a lot of small arms fire like they should, and the best way to take one down will be with some form of BFG. Link to comment https://bolterandchainsword.com/topic/356077-elites-point-values/#findComment-5318446 Share on other sites More sharing options...
