RolandTHTG Posted July 15, 2019 Share Posted July 15, 2019 I recently picked up some contrast primer (wraithbone) and paints to try on a squad. I had previously primed over half the squad with a conventional grey primer before it ran out. Would repriming the wraithbone over the existing grey primer obscure or otherwise mess up the wraithbone layer? Or is it ok to spray the contrast primer over the old primer? Link to comment https://bolterandchainsword.com/topic/357159-contrast-primer-safe-over-conventional-primer/ Share on other sites More sharing options...
Inquisitor Eisenhorn Posted July 17, 2019 Share Posted July 17, 2019 Yeah it's fine. The only difference I've noticed is that the contrast paint is more "absorbed" by conventional primer (although I was using white, not grey conventional primer). The absorption means there is maybe a little less ability to move the paint around the surface before it stains into the primer. This is a little different, but absolutely not worse. I'm going to try doing a little wraith bone over conventional primer later today and I'll report back with the results. Link to comment https://bolterandchainsword.com/topic/357159-contrast-primer-safe-over-conventional-primer/#findComment-5348728 Share on other sites More sharing options...
Guiltysparc Posted July 17, 2019 Share Posted July 17, 2019 I sprayed some of the drop terrain from Urban Conquest with wraithbone after I had already hit it with chaos black, covered great and the contrast paint (white in this case) looks awesome over top. Link to comment https://bolterandchainsword.com/topic/357159-contrast-primer-safe-over-conventional-primer/#findComment-5348821 Share on other sites More sharing options...
Inquisitor Eisenhorn Posted July 24, 2019 Share Posted July 24, 2019 I did some seer grey spray over black GW primer and it was totally fine. Excellent coverage from contrast and normal GW paints. Link to comment https://bolterandchainsword.com/topic/357159-contrast-primer-safe-over-conventional-primer/#findComment-5351873 Share on other sites More sharing options...
RolandTHTG Posted July 24, 2019 Author Share Posted July 24, 2019 Thanks for the replies. Now that the heat has broken, I should be able to get my stuff primed. Link to comment https://bolterandchainsword.com/topic/357159-contrast-primer-safe-over-conventional-primer/#findComment-5351885 Share on other sites More sharing options...
