Neat proxy idea, need a size comparison
I had the (probably not uncommon) idea to pick up some Star Wars: Legion models to run as a fun proxy for Astra Militarum. AT-STs as Sentinels, Stormtroopers as Infantry Squads, Darth Vader as a Primaris Psyker, etc. How's the size match up? 28mm? Is the AT-ST the same size as a Sentinel, bigger, smaller?
Just googled what that was
It does look like a perfect candidate for a Scout Sentinel counts as, although to be honest I really like the GW kits for the current sentinels and given the similarity I'm not sure what you would be gaining?
I used the Legion Scout Trooper models to try and make Solar Auxilia pioneers and my main take away's were this:
-The arms can be used on marine or necromunda scaled models and not look out of place on the table, but will be noticeably longer and out of proportion up close.
-The torsos are too long
-The combination of star wars helmets being very large and the bigger sizes of Legion models mean the heads are entirely incompatible
-The weapons are true to star wars scale, so will fit GW heroic scale weapons models - but the weapons are not seperate pieces and take a lot of work to remove from the Legion models.
-The bases are smaller and taller than GW Bases
-The resin itself is not a hard resin, but very gummy. A modeling saw wont work, you have to use a scalpel and scalpels cannot achieve even cuts
Overall, the Legio models are really nice - for a star wars game. They require so much work and cutting and sculpting even at the cheaper prices it would be easier to source a GW kit.
