MajorNese Posted September 25, 2019 Share Posted September 25, 2019 (edited) Since I'm on the fence about adding this unit to my Raptors or IH, I thought a bit more input might be useful. And going for a levi sounds a bit cheap to me, the obvious-and-to-be-nerfed choice isn't exactly what I go for. Also, PopGoesTheMonkey now has ways to make them look better. In dev doctrine: -6x S7 AP-2 2D (autocannon) -2d6 S5 AP-2 (flamer) -3x S5 AP-2 -6x S4 AP-2 No penalty for moving, no degrading profile until it loses 10W, and the cost is only slightly higher than a geared-up dreadnought. But unlike the dread, this one is in charge range turn 1 if it wants to, or starts off on midfield objectives. The usual approach might be nice for a gunline, but this one could give us board control and applies pressure. Using a phobos HQ with Ironstone could create quite a resilient firebase in the midfield - or a blob of 39W of walkers that rampage through the opponent's deployment zone turn 1, while shrugging off a lot of damage. Only T6, but reducing plasma/autocannon damage to 1 each would require bigger guns or CC to take them down quickly. Which in turn takes pressure off the backfield heavies. Any thoughts on this one? Edited September 25, 2019 by MajorNese Link to comment https://bolterandchainsword.com/topic/358689-invictor-warsuit-ih-uses/ Share on other sites More sharing options...
casb1965 Posted September 25, 2019 Share Posted September 25, 2019 (edited) I like the idea of this but 1. You get either the autocannon or flamer shots not both 2. Wouldn't the Heavy Bolter be 6 x S5 AP - 2 due to being in half range? 3. Getting a 9" charge off is very difficult. Other than that :tu: Edited September 25, 2019 by casb1965 Link to comment https://bolterandchainsword.com/topic/358689-invictor-warsuit-ih-uses/#findComment-5396057 Share on other sites More sharing options...
MajorNese Posted September 25, 2019 Author Share Posted September 25, 2019 1. Sure, we either get flamer or autocannon. But since both are Heavy, the AP becomes interesting. 2. It's Heavy, not Rapid Fire. Always 3 shots. 3. A 9" charge becomes significantly easier by moving 10" first - Invictors begin the game 9" from enemy models/deployment zone, they can act regularly in the first turn. So you're guaranteed to end at least 3" inside the deployment zone (when rolling snake eyes for charge range). Link to comment https://bolterandchainsword.com/topic/358689-invictor-warsuit-ih-uses/#findComment-5396060 Share on other sites More sharing options...
casb1965 Posted September 25, 2019 Share Posted September 25, 2019 (edited) 1. AP -2 still is 5+ on SM so 6 shots = 4 hits = 2 wounds with a 5+ save. 2. Ah yes, forgot about the "heavy" part. 3. This is assuming deployment zone edge hugging by your opponent. You could be setting up 21" away from your opponent in some scenarios if they terrain hug at the back of their deployment zone and you have to set up 9" away from the edge of their deployment zone. A 10" move doesn't help much then. Edited September 25, 2019 by casb1965 Link to comment https://bolterandchainsword.com/topic/358689-invictor-warsuit-ih-uses/#findComment-5396061 Share on other sites More sharing options...
Charlo Posted September 25, 2019 Share Posted September 25, 2019 Maybe IH is the one chapter you want the AC instead of the Flamer. It's very accurate on the move and more versatile a weapon than the toaster. Goat Rider, Exilyth and Khornestar 3 Back to top Link to comment https://bolterandchainsword.com/topic/358689-invictor-warsuit-ih-uses/#findComment-5396125 Share on other sites More sharing options...
MajorNese Posted September 25, 2019 Author Share Posted September 25, 2019 (edited) Exactly. That's the issue I have with RG Invictors - it's absolutely fluffy, but just walks around with guardsmen's BS. With our doctrine bonus, we might as well infiltrate them out of LoS, then march out and still hit perfectly. Also speaking for autocannons, it is more flexible - depending on opponent we could infiltrate them either up front to charge stuff, or if facing a CC army we place them in our backfield and they are still in range with everything except for the fragstorm. Edited September 25, 2019 by MajorNese Link to comment https://bolterandchainsword.com/topic/358689-invictor-warsuit-ih-uses/#findComment-5396126 Share on other sites More sharing options...
Aothaine Posted October 11, 2019 Share Posted October 11, 2019 Indeed! I plan on using three of these in almost every game I play in the future. Link to comment https://bolterandchainsword.com/topic/358689-invictor-warsuit-ih-uses/#findComment-5405963 Share on other sites More sharing options...
