JH.Miniatures Posted September 25, 2019 Share Posted September 25, 2019 Small little tutorial on how I do crackled bases and how to use Crackle Paint. Hope you guys like it! Mithrilforge and betrayer41 2 Back to top Link to comment https://bolterandchainsword.com/topic/358692-how-to-base-crackle-paint/ Share on other sites More sharing options...
ValourousHeart Posted October 2, 2019 Share Posted October 2, 2019 Great video. I wanted to mention a few tips that weren't covered. A thin layer of PVA glue helps to exaggerate the cracking effect, creating larger cracks. Depending upon the effect you are going for you might also want to have a more dramatic contrast between the base coat and the crackle color. A wash helps lock down the crackle paint so it won't flake off. This is the stage where the Crackle was finally dry. Notice the center to the top left, the base had a slight depression in which more of the PVA glue pooled. This is after using GW's yellow wash, all of the flakes are secured. QuarterPounder and JH.Miniatures 2 Back to top Link to comment https://bolterandchainsword.com/topic/358692-how-to-base-crackle-paint/#findComment-5400442 Share on other sites More sharing options...
JH.Miniatures Posted October 2, 2019 Author Share Posted October 2, 2019 Great video. I wanted to mention a few tips that weren't covered. A thin layer of PVA glue helps to exaggerate the cracking effect, creating larger cracks. Depending upon the effect you are going for you might also want to have a more dramatic contrast between the base coat and the crackle color. A wash helps lock down the crackle paint so it won't flake off. This is the stage where the Crackle was finally dry. Notice the center to the top left, the base had a slight depression in which more of the PVA glue pooled. This is after using GW's yellow wash, all of the flakes are secured. Those are great tips! Thanks! Link to comment https://bolterandchainsword.com/topic/358692-how-to-base-crackle-paint/#findComment-5400510 Share on other sites More sharing options...
Alcyon Posted July 10, 2020 Share Posted July 10, 2020 Thanks for the video and tips, guys. Depending upon the effect you are going for you might also want to have a more dramatic contrast between the base coat and the crackle color. A wash helps lock down the crackle paint so it won't flake off. I just used some Martian Ironearth for the first time and while the effect looks great, I used Rhinox Hide on the base and it's so dark in contrast as to be almost black. I got a really good crackle so a lot of the base shows through. I'm a bit concerned about using a wash because I really don't want it to dry glossy, and it seems like an extra step - I figure if I start with a slightly lighter base paint and then drybrush I can get a shadow and highlight without. Does this seem like an ok idea to you guys? What colour would you put underneath Martian Ironearth, a darker red, or maybe a lighter brown than Rhinox Hide? bloodhound23 1 Back to top Link to comment https://bolterandchainsword.com/topic/358692-how-to-base-crackle-paint/#findComment-5559332 Share on other sites More sharing options...
