Zephaniah Adriyen Posted October 21, 2019 Share Posted October 21, 2019 So, I'm picking up a Primaris Shrike within the next month or two. I want to convert him to wear his helmet. Has anyone done this? Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/ Share on other sites More sharing options...
Fajita Fan Posted October 21, 2019 Share Posted October 21, 2019 I'm looking at the sprue breakdown and it looks like a piece of cake if you have another beaky helment. Saving his beaky helmet looks hard because of the contact point but you just cut that off and glue a grenade or auspex bit to his belt to cover it up. Swapping molded on shoulders is much more difficult than swapping heads. Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/#findComment-5411956 Share on other sites More sharing options...
Jukkiz Posted October 22, 2019 Share Posted October 22, 2019 It´s not that hard conversion to do, BUT, if you want him looking other ways, you might need to resculpt the back of the helmet where it was connected to the belt. Also you need the collar/neck piece form somewhere to get helmet seated. Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/#findComment-5412125 Share on other sites More sharing options...
Tyberos the Red Wake Posted October 22, 2019 Share Posted October 22, 2019 The helmet is very easy to cut off, especially if you don't mind hacking up the grenades or pouches or whatever they're attached to. The problem is the helmet is flat on the bottom, and transplanting a rounded neck nub onto it is a huge pain in the ass. I think if you could reliably sand the needed additional neck length flat and used plastic glue or green stuff to join the two together, it'll be fine, but I personally was too lazy/didn't have the tools to add a proper neck to the helmet. After hacking off a random helmet and being left with just the neck, it was extremely hard to both grip in my fingers and sand perfectly flat, as well as seamlessly attach it to the bottom of Shrike's helmet. You can get around this by diligently sanding the neck level on a table, and holding it with pliers or a drilled wire. I just used my fingers and started sawing away on a flat sanding stick and file, which wasn't the greatest. Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/#findComment-5412152 Share on other sites More sharing options...
Gederas Posted October 22, 2019 Share Posted October 22, 2019 duz_ did it, using Shrike's helmet: So it doesn't seem too hard. The most difficult part would be building a new neck for the helmet. Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/#findComment-5412312 Share on other sites More sharing options...
Zephaniah Adriyen Posted October 22, 2019 Author Share Posted October 22, 2019 I've done necks before, so... thank you, this is exactly what I needed. Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/#findComment-5412323 Share on other sites More sharing options...
Wakkomaster Posted October 25, 2019 Share Posted October 25, 2019 Niiiiiiiice I'd put helmets on every model if I could Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/#findComment-5414099 Share on other sites More sharing options...
Jolemai Posted October 25, 2019 Share Posted October 25, 2019 Don't be like Duz and trim the base though :lol: Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/#findComment-5414102 Share on other sites More sharing options...
duz_ Posted October 25, 2019 Share Posted October 25, 2019 Plenty of Frater in the Ravenspire have gone this route It's fairly straight forward just need a sharp hobby knife blade and steady hand you can even save the pouches and use them after. As for the neck I just trimmed the section from the regular head and glued that in the socket and placed the helmet on top :tu: Ignore Jol he's being a tease although I have had some TOs claim that having modified his base is modelling for advantage :facepalm: Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/#findComment-5414198 Share on other sites More sharing options...
Tyberos the Red Wake Posted October 25, 2019 Share Posted October 25, 2019 Don't be like Duz and trim the base though Ignore Jol he's being a tease although I have had some TOs claim that having modified his base is modelling for advantage It's still on the supplied base! Totally kosher! Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/#findComment-5414603 Share on other sites More sharing options...
Wakkomaster Posted October 28, 2019 Share Posted October 28, 2019 I was thinking, I know it's not really Raven Guard-ish, but what about using one of the new Phobos helmets? They should fit just right with no need to trim anything, no? It could be an even easier solution, if you like the look. Link to comment https://bolterandchainsword.com/topic/359350-kayvaan-shrike-helmet-conversion-with-no-kitbash/#findComment-5415814 Share on other sites More sharing options...
