Faith & Fury FAQ now live!
https://www.warhammer-community.com/wp-content/uploads/2020/01/b708da79.pdf
Big Question now answered:
BLACK TEMPLARS
Designer’s Note: We have received a number of questions asking if, as a successor Chapter of the Imperial Fists, the Black Templars benefit from both the Knights of Sigismund and Legacy of Dorn rules (and whether they get access to the Imperial Fists’ Warlord traits, Stratagems, psychic powers and Relics etc. in addition to the Black Templars ones presented in Faith and Fury). To be clear, although the Black Templars are an Imperial Fists successor Chapter, they deviate significantly from its tactics and doctrines, and as such we have provided a bespoke, dedicated set of rules to represent them on the tabletop in Faith & Fury. They cannot make use of any of the rules found in Codex Supplement: Imperial Fists.
https://bolterandchainsword.com/topic/361047-faith-fury-faq-now-live/
Devout Push is bonkers good now. So you can select a unit that isn't within 1" of the enemy, pile in with it. Then if you don't make contact with the enemy (cause they're like on the other side of the board), you consolidate 6"
So applications for this:
Failed that deepstrike? That's fine, get in combat for next turn anyway.
Pushing a slow unit across the board up to 12 inches with Canticle of Hate
Avoiding overwatch
Use the 3 CP strat to fight again
Also keep in mind that if you do make contact with the enemy during the pile in, you can fight that round.
I was never expecting full access to both. But the lack of a full suite of strats for us, as well as the notable omissions of mentioning either BT in the IF book, or the IF book in F&F made me think it was deliberate, made me think that it was partly planned, but just broken. However, it seems that it was just massively a negligent oversight after all? and they just didn't even consider the interaction?
At the least, I thought access to some of the strats, the relics, and SIW would have been sensible. We now have less strats than the CF, who strangely have more than the IF!
This would also be another way to get an advancing unit into close combat, so you move+advance and use devout push to get them into combat or just closer. Its a free 6" movement in the charge phase!.
It's not during the charge phase. It is used at the start of the Fight phase
Indeed, it makes the Black Templar rules incredible weak compared to the other space marine chapters.
I don't think you get to consolidate as part of DP. You just get a pile in move immediately, not a full fight sequence.
If so, the phrasing doesn't line up with any of the other stratagems that allow a unit to fight early or fight again. Counter-Offensive says 'select a unit, it fights next'. Devout Push just says 'that unit can pile in'. And that's the errata'ed sentence - if it was supposed to be a full fight sequence, they'd have clarified it as such.
Otherwise, it's easily the best "fight first" stratagem in the game, far better than Counter-Offensive, while also costing fewer CP and allowing other movement shenanigans. That seems implausible to me.
It doesn't allow you to fight first, it allows you to make contact with an enemy via piling in out of sequence.
I agree, but I'm responding to Kyliadan asserting that it allows a full fight sequence. If that is so, then since it occurs "at the start of the Fight phase", it's allowing you to fight first.
My reading is that the stratagem allows you to immediately make a Pile In move (3", must move closer to the nearest enemy), but that's it. You can also select that unit to fight during the usual Fight Phase sequence if you are within 1" of an enemy at the time of selection, because no part of the stratagem says you cannot - at which point it will pile in again, attack, and then consolidate 6".
Right, I see where you're coming from.
I read the strat as allowing you to fight  (just like a unit activation) because otherwise, I just wasn't seeing the point. If it's just a "double pile-in" and 6" consolidate, the phrasing could have been a much simpler "this unit adds 3" to its consolidate/pile-in moves until the end of that phase".
Edit : huh, since the FAQ mentions that you can use it even if not within 1" of an enemy... this means that you can use it on a BT unit that wouldn't have been able to fight otherwise (if it had charged it would be within 1"). So... if it does not imply that you can fight with the unit, it means you get to pile-in and gently stare down the enemy ? Who, on the other hand, could very well punch you ?
GW is killing me :biggrin.:
Aurellian shroud being effected by fervent acclimation is a big deal. That's a must take combo for us.
why - for 3 Repulsors you need just 3":wink:
This was always going to be errata'd, you'd have to be kidding yourself if you thought GW would let us have access to both.
Just as expected
