Cruor Vault Posted February 4, 2020 Share Posted February 4, 2020 I needed a break from painting my millionth Ultramarine so I decided to paint up one of the knights cluttering up my cabinet. I wanted to try a new technique out so I opted to do some marble armor. http://i.imgur.com/IwxrmGW.jpg http://i.imgur.com/hcBTNTS.jpg Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/ Share on other sites More sharing options...
Grotsmasha Posted February 4, 2020 Share Posted February 4, 2020 Yeah, that's amazing..... Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472099 Share on other sites More sharing options...
Majkhel Posted February 4, 2020 Share Posted February 4, 2020 Fantastic work! Has this something to do with spraying through a torn-fibre tissue method? (not sure if name it correctly) Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472105 Share on other sites More sharing options...
StraightSilver Posted February 4, 2020 Share Posted February 4, 2020 Yes, enquiring minds would like to know how this was done. :)I'm guessing the cotton wool strands technique? Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472242 Share on other sites More sharing options...
Cruor Vault Posted February 4, 2020 Author Share Posted February 4, 2020 Fantastic work! Has this something to do with spraying through a torn-fibre tissue method? (not sure if name it correctly) Yes, enquiring minds would like to know how this was done. I'm guessing the cotton wool strands technique? Slightly stretched out dryer sheets. Total time to do the marble was maybe 90 minutes, counting the learning process as I had never tried it before. Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472277 Share on other sites More sharing options...
Kolgrim DeathHowl Posted February 4, 2020 Share Posted February 4, 2020 Man that marble looks really great!! Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472280 Share on other sites More sharing options...
Filkarion Posted February 4, 2020 Share Posted February 4, 2020 Slightly stretched out dryer sheets. Total time to do the marble was maybe 90 minutes, counting the learning process as I had never tried it before. Tutorial please! Or link to the tutorial you used! I would really like to use it on a purple base Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472307 Share on other sites More sharing options...
Cruor Vault Posted February 4, 2020 Author Share Posted February 4, 2020 The 100% finished result. Crushed glass and water effects for snow and some dead grass to break up the base a little. Slightly stretched out dryer sheets. Total time to do the marble was maybe 90 minutes, counting the learning process as I had never tried it before. Tutorial please! Or link to the tutorial you used! I would really like to use it on a purple base This is the closest I have to a tutorial. Found it trolling through Reddit I think? Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472359 Share on other sites More sharing options...
Loquille Posted February 4, 2020 Share Posted February 4, 2020 Wow, that's looking great. Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472393 Share on other sites More sharing options...
jaxom Posted February 4, 2020 Share Posted February 4, 2020 This is the closest I have to a tutorial. Found it trolling through Reddit I think? Was it the marble drop pod? There's also a good one using steel wool. Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472412 Share on other sites More sharing options...
Cruor Vault Posted February 4, 2020 Author Share Posted February 4, 2020 This is the closest I have to a tutorial. Found it trolling through Reddit I think? Was it the marble drop pod? There's also a good one using steel wool. Actually I hadn't seen either of those. The Drop Pod is pretty close to what I was originally imagining when I set out on this project. Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472422 Share on other sites More sharing options...
Debauchery101 Posted February 5, 2020 Share Posted February 5, 2020 https://youtu.be/eLVE1q0fGDA This guys tutorial is pretty good. I really think you should use some pigment dust instead of washes/inks. The ultra flat dust will really bring out the polished marble. I think the silver trim next to the green is taking away from the great effect of your nice marble/granite look. Maybe an aged gold/polished bronze would bring it out more. Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472836 Share on other sites More sharing options...
Cruor Vault Posted February 5, 2020 Author Share Posted February 5, 2020 https://youtu.be/eLVE1q0fGDA This guys tutorial is pretty good. I really think you should use some pigment dust instead of washes/inks. The ultra flat dust will really bring out the polished marble. I think the silver trim next to the green is taking away from the great effect of your nice marble/granite look. Maybe an aged gold/polished bronze would bring it out more. Theres no pigment dust needed. just a little black wash for outlining the silver. Silver is better because then I am not adding any warm tones to the model, keeping with the limited pallet cool tones I chose. Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5472994 Share on other sites More sharing options...
Debauchery101 Posted February 6, 2020 Share Posted February 6, 2020 This guys tutorial is pretty good. I really think you should use some pigment dust instead of washes/inks. The ultra flat dust will really bring out the polished marble. I think the silver trim next to the green is taking away from the great effect of your nice marble/granite look. Maybe an aged gold/polished bronze would bring it out more. Theres no pigment dust needed. just a little black wash for outlining the silver. Silver is better because then I am not adding any warm tones to the model, keeping with the limited pallet cool tones I chose. Well always go with your plan. Things may look different in person. From pictures I think the silver is too bright and similar to tones in the marble. That and the seemingly gloss black lining from wash steal away the detail from the green. Which looks really awesome in that close up. For real try a light brown pigment dust. .if you dont like it, it literally wipes away with spit and napkin. I recently started using all these tools and techniques scale modelers use and I'm surprised how easy and effective they are Link to comment https://bolterandchainsword.com/topic/361702-marble-armor-castellan/#findComment-5473006 Share on other sites More sharing options...
