Valerian Posted May 4, 2020 Share Posted May 4, 2020 Gang, The Cheat Sheets that I shared earlier for Space Wolves here, and for the Grey Knights over on the subforum for Titan had too much information on them. So, instead of providing the actual rules, here is a link to a mostly blank Example Cheat Sheet Format that you can fill in on your own to use. All you need to do is go through your Codex and Saga of the Beast (as well as the Rulebook and Vigilus Defiant, if you wish to get all of the them) and add in the relevant information from any Stratagems that you want to have at your fingertips during a game. You'll see in the Example Cheat Sheet how I have the rows sorted by Timing, so you can quickly access the information about the Stratagems as you flow through the game; I found this to be the most useful technique. So, this will take just a few minutes of work on your part to make a copy of the format and fill in with whatever information you wish.For my purposes, I printed off the Cheat Sheet (once filled in) and slipped into the back laminate area on the outside cover of a 3-ring binder. Inside the binder is my army list, special rules, psychic powers, and all of my unit data sheets, inside document protectors. I don't have to carry the actual codex, but have all of the rules that I need readily at hand. Enjoy, Val Link to comment https://bolterandchainsword.com/topic/363648-example-blank-stratagem-cheat-sheet/ Share on other sites More sharing options...
Kassill Posted May 7, 2020 Share Posted May 7, 2020 I was wondering what happened there. Thanks again Val Link to comment https://bolterandchainsword.com/topic/363648-example-blank-stratagem-cheat-sheet/#findComment-5518128 Share on other sites More sharing options...
