thewarriorhunter Posted June 30, 2020 Share Posted June 30, 2020 Assuming you run a 10 man squad, and assuming they're in a line because of a trench terrain feature, you're only going to have a problem if you try and max out that 2" coherency. If you have the bases closer together even models on the end will be close enough to two other models since a marine base is only 32mm. It's an adjustment that we'll all have to get used to. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551069 Share on other sites More sharing options...
duz_ Posted June 30, 2020 Share Posted June 30, 2020 As with all edition changes we can expect a few changes to how we run our armies I think overall these are good changes. Definitely stops the conga lines of nonsense and as TWH mentioned a few minor changes to spacing won't impact others as much either The coherency for being within 2" of 2 models only applies to units with 6+ models. So even a Marine squad maxed out isn't significantly impacted when taking casualties assuming you weren't maximising spacing to begin with. Which is the whole point of the rule. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551126 Share on other sites More sharing options...
Dracos Posted June 30, 2020 Author Share Posted June 30, 2020 1) TWH is correct don't max out the coherency and your good. 2) Back in 3rd I built 6 feet worth of trenches (looked like quasi-berms) that allowed for double rows of infantry ... because we wanted dreadnoughts and stuff to work in them also. 3) I think I'll spend some time in July with foam cutter glue and jug of flock remaking these for the flgs when it reopens to public play. Thanks for the idea guys. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551138 Share on other sites More sharing options...
W.A.Rorie Posted July 1, 2020 Share Posted July 1, 2020 Preorders Start 07/11 and release date is 07/25 for 9e Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551795 Share on other sites More sharing options...
thewarriorhunter Posted July 1, 2020 Share Posted July 1, 2020 I put a deposit down at my FLGS yesterday. I've seen rumored prices all over the place so I'm waiting to see what it ends up being. I'm okay with $200-$240, anything higher than that and I will have to really consider it. With as much as they're packing into the box I can't see it being less than $200, especially since it's got a special cover Rulebook and they've stated it's directed at 'veteran players'. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551833 Share on other sites More sharing options...
Ulrik_Ironfist Posted July 1, 2020 Share Posted July 1, 2020 So boys it looks like points leaks are out with a 17% increase. Start building your 1660pt lists to get a feel for your army size come 9th edition... Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551842 Share on other sites More sharing options...
duz_ Posted July 1, 2020 Share Posted July 1, 2020 Did they mention on the stream its for veteran players? That's very surprising for a starter set.... Especially given Starter is in the name Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551855 Share on other sites More sharing options...
thewarriorhunter Posted July 1, 2020 Share Posted July 1, 2020 They've been very clear that it's not a starter set. No dice/rulers/etc. in the box. Just models, datasheets, and rules. Those comments and the 'veteran players' were in previous war-com articles. I'll see if I can dig them up. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551892 Share on other sites More sharing options...
duz_ Posted July 1, 2020 Share Posted July 1, 2020 Wow ok then It's gonna be expensive :lol: For thing I'm wait for the multi part set Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551907 Share on other sites More sharing options...
thewarriorhunter Posted July 1, 2020 Share Posted July 1, 2020 Yeah, I want it, but if it's hitting $300 it's probably gonna be a no from me dawg. I want the rule book and I want those models, but I don't paint that fast. On the other hand usually when they release these huge boxes they are are great value, even if it is an expensive box. Like the AT Grandmaster box, it was expensive, but it was a good value. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551919 Share on other sites More sharing options...
W.A.Rorie Posted July 1, 2020 Share Posted July 1, 2020 I put a deposit down at my FLGS yesterday. I've seen rumored prices all over the place so I'm waiting to see what it ends up being. I'm okay with $200-$240, anything higher than that and I will have to really consider it. With as much as they're packing into the box I can't see it being less than $200, especially since it's got a special cover Rulebook and they've stated it's directed at 'veteran players'. Yeah I promised my Local Warhammer store I order through them......but I'm splitting it with a friend so at least I'm recouping some of it. So boys it looks like points leaks are out with a 17% increase. Start building your 1660pt lists to get a feel for your army size come 9th edition... Saw that.....freaking aggressors, whirlwinds and suppressors got expensive points wise...according to the rumored pts I saw Yeah, I want it, but if it's hitting $300 it's probably gonna be a no from me dawg. I want the rule book and I want those models, but I don't paint that fast. On the other hand usually when they release these huge boxes they are are great value, even if it is an expensive box. Like the AT Grandmaster box, it was expensive, but it was a good value. yeah $300 is hard no me too. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5551937 Share on other sites More sharing options...
Riddlesworth Posted July 1, 2020 Share Posted July 1, 2020 So having seen points leaks and data sheet leaks for a bunch of stuff, my raven guard successor army is 2216 points. Some quick trimming and indomitus additions,, back under 2k. Realise I've trimmed all the units I've painted during lockdown... Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5552296 Share on other sites More sharing options...
W.A.Rorie Posted July 1, 2020 Share Posted July 1, 2020 too much new stuff I want but i need to paint what i have first.........wont happen I'll buy stuff Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5552327 Share on other sites More sharing options...
duz_ Posted July 1, 2020 Share Posted July 1, 2020 Some quick trimming and indomitus additions,, back under 2k. Realise I've trimmed all the units I've painted during lockdown... :facepalm: Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5552365 Share on other sites More sharing options...
Ulrik_Ironfist Posted July 2, 2020 Share Posted July 2, 2020 too much new stuff I want but i need to paint what i have first.........wont happen I'll buy stuff That's why I got all my stuff painted now before the new stuff released... Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5552480 Share on other sites More sharing options...
Dracos Posted July 2, 2020 Author Share Posted July 2, 2020 So having seen points leaks and data sheet leaks for a bunch of stuff, my raven guard successor army is 2216 points. Some quick trimming and indomitus additions,, back under 2k. Realise I've trimmed all the units I've painted during lockdown... Well I'm trading/selling my Dakka Aggressors and replacing them with Flamer Aggressors. That and the second team of Inceptors will but the Warhawks at about 2k. Then I'm starting a new DIY with a more dynamic color scheme focused on melee instead of shooting. If I get lucky I might be able to figure a way to blend the two color patterns into one army for the future. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5552597 Share on other sites More sharing options...
Alcyon Posted July 2, 2020 Share Posted July 2, 2020 Well I'm trading/selling my Dakka Aggressors and replacing them with Flamer Aggressors. Because of a points hike? They still seem much worse than the Bolter ones, no? Looks like Centurions have taken a big jump so they might not be nearly as competitive now. Seems like good targets for SftS and MoA shift towards Gravis-armoured marines, both Aggressors and the new Eradicators. Then again remains to be seen how useful those abilities will be now that it's much more common to be able to come on as reserves. I was all fired up to paint some Grav-Centurions, now I'm leaning back towards Aggressors and even Hellblasters to deal with MEQ and TEQ. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5552658 Share on other sites More sharing options...
Dracos Posted July 2, 2020 Author Share Posted July 2, 2020 Changing my play style I want to force myself to use them as a melee unit. Points are positive side effect. Something had to go with the point increases and I want two Infiltrator units instead of Incursors. The two Inceptors units can handle the heavy Dakka. I’ll use the old army until I can get the melee focus Primaris up and running. Liking these Assault Intercessors more if the leak about 18” range heavy bolt pistols is true. Edit: dang I actually named wrong unit. Wishlisting Assault Inceptors I guess Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5552684 Share on other sites More sharing options...
duz_ Posted July 2, 2020 Share Posted July 2, 2020 Yes I noticed the 18" on the pistol... That's interesting RIP my 20 Reivers :cry: Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5552929 Share on other sites More sharing options...
thewarriorhunter Posted July 2, 2020 Share Posted July 2, 2020 Unless it's a really well done fake datasheet that is an 18" range bolt pistol. I've only skimmed the leaks and haven't really dived into them because I hate reading pictures. With each mention of something I find myself going back and looking up stuff. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5552993 Share on other sites More sharing options...
MajorNese Posted July 2, 2020 Share Posted July 2, 2020 Skimmed the leaked box unit rules - there are several updates to wargear stats/rules, that I rather expect to get updated into the codex. That, and maybe more that isn't in the box itself. Heavy bolt pistol - changed to 18" Astartes chainsword - changed to AP-1 (bonus attack still there) Plasma pistol - now overheats on unmodified 1 (which has been intended for years) Storm shield - 4++, improves save of the model by 1 (so 2+ armour on PA dudes, but no longer 3++) MC power sword - S+1, otherwise same Absolvor bolt pistol - 2D Astartes banner - now every unit except for vehicle/beast/wulfen (previously only infantry/biker, no idea what units now benefit from it too) Considering there will be other changes, I'll just wait and see. No need to prep for 9th based on leaks and speculation, I have enough model choice for a while... Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5553094 Share on other sites More sharing options...
duz_ Posted July 2, 2020 Share Posted July 2, 2020 GW released the core rules today Also confirmed the 18" pistol range too https://www.warhammer-community.com/2020/07/02/free-core-rules-new-models-sighted/ Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5553179 Share on other sites More sharing options...
thewarriorhunter Posted July 2, 2020 Share Posted July 2, 2020 I feel bad for them with leakgate, but at least they're trying to get back in front of it. Their stream was hilarious this morning, they were ripping on all the leakers, about how disordered they were and they couldn't even upload leaked photos in the correct order. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5553183 Share on other sites More sharing options...
Ulrik_Ironfist Posted July 2, 2020 Share Posted July 2, 2020 I'm gradually settling into my list. I want my army to be primarily focused on shooting and staying outside of 12" and dominating the midfield early with a secondary emphasis on assault, to mop up. I'm trying to take units that are better at shooting and decent in the assault rather than taking assault focused units. That means I'm looking at boltstorm aggressors and Incursors. Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5553279 Share on other sites More sharing options...
thewarriorhunter Posted July 2, 2020 Share Posted July 2, 2020 I'm overall excited because the points increase means I'm closer to having 2k painted :P Link to comment https://bolterandchainsword.com/topic/364433-thoughts-on-prepping-for-9e/page/5/#findComment-5553294 Share on other sites More sharing options...
