Zephaniah Adriyen Posted July 10, 2020 Share Posted July 10, 2020 So, here's the deal. I've gotten my hands on a 3D printer and generally figured out how to use it. I've also gotten my hands on print files for a bunch of visually coherent sci-fi bases. I want to print and paint these bases in advance of my copy of Indomitus showing up - both the Nihilakh Dynasty and the Dark Angels will be based in the same style. Do any of you know the base sizes packaged in Indomitus? Link to comment https://bolterandchainsword.com/topic/365014-indomitus-base-sizes/ Share on other sites More sharing options...
Arkhanist Posted July 10, 2020 Share Posted July 10, 2020 (edited) So, here's the deal. I've gotten my hands on a 3D printer and generally figured out how to use it. I've also gotten my hands on print files for a bunch of visually coherent sci-fi bases. I want to print and paint these bases in advance of my copy of Indomitus showing up - both the Nihilakh Dynasty and the Dark Angels will be based in the same style. Do any of you know the base sizes packaged in Indomitus? Going by this unboxing, and this video and this video (particularly the latter starting @ 17.22 where you have the entire list in the build guide, plus the sizing diagram) The total count of sizes as far I can see from a screenshot: http://i.imgur.com/4ek3OTC.png are: 1 x 28mm 34 x 32mm 18 x 40mm 3 x 50mm 2 x 65mm 3 x 90mm oval (presumably the existing 90mm x 52mm) from glimpses of the build guide or mentioned in the first link, I've seen the following models base sizes Necrons: Skorpekh Destroyer Lord and the Canoptek Reanimator - 65mm 3 Skorpekh Destroyers - 50mm Overlord - 40mm Plasmancer - 32mm Royal Warden - 32mm 6 Scarabs - 40mm 20 Warriors - 32mm Marines: Captain, Lieutenant, Chaplain, Judiciar, Ancient - 40mm 3 outrider bikes - 90mm oval 10 assault intercessors - 32mm I have yet to see the base sizes assigned to these last models, so these remaining ones are my best guess. by eyeballing the models next to them in the big pic, I reckon 3 Blade Guard veterans - 40mm 3 Eradicators - 40mm That leaves 1x28mm and 2x32mm unassigned, which by process of elimination belong to the last models in the box: 2 cryptothralls - 32mm and the canoptek plasmacyte - 28mm Edited July 10, 2020 by Arkhanist Zephaniah Adriyen 1 Back to top Link to comment https://bolterandchainsword.com/topic/365014-indomitus-base-sizes/#findComment-5559566 Share on other sites More sharing options...
Kain Mor Posted July 11, 2020 Share Posted July 11, 2020 Having assembled a preview copy I can confirm the above breakdown is accurate ^ Ahistorian, Zephaniah Adriyen and Arkhanist 3 Back to top Link to comment https://bolterandchainsword.com/topic/365014-indomitus-base-sizes/#findComment-5559699 Share on other sites More sharing options...
Venerable Jazzman Posted July 11, 2020 Share Posted July 11, 2020 Remember that those sizes are for the top of the base, the actual base footprint is a couple of mm larger as the edges slope out. I bought some 60mm mdf bases for my old metal Dreads that didn't come with bases, they're about 4-5mm too small when compared to the plastic GW Dread base. I'd add about 7% to the top size to get the footprint, but I'll let you work out the trig and angle of slope you need Link to comment https://bolterandchainsword.com/topic/365014-indomitus-base-sizes/#findComment-5560522 Share on other sites More sharing options...
Arkhanist Posted July 11, 2020 Share Posted July 11, 2020 Remember that those sizes are for the top of the base, the actual base footprint is a couple of mm larger as the edges slope out. I bought some 60mm mdf bases for my old metal Dreads that didn't come with bases, they're about 4-5mm too small when compared to the plastic GW Dread base. I'd add about 7% to the top size to get the footprint, but I'll let you work out the trig and angle of slope you need I'm not sure that's right. I've just measured a handful of GW bases I had on my desk, admittedly with just a ruler. The 32mm, 40mm, 50mm and 65mm bases are all that diameter for the bottom outer rim, the top flat part is about 3mm smaller diameter. If they're pre-made designs for standard sizes, then they should match. Link to comment https://bolterandchainsword.com/topic/365014-indomitus-base-sizes/#findComment-5560565 Share on other sites More sharing options...
Venerable Jazzman Posted July 11, 2020 Share Posted July 11, 2020 Yeah, exactly, you're saying it measures 65mm, but GW calls it 60mm. "Model is supplied with a 60mm scenic base." https://www.games-workshop.com/en-GB/Space-Marine-Dreadnought Link to comment https://bolterandchainsword.com/topic/365014-indomitus-base-sizes/#findComment-5560607 Share on other sites More sharing options...
Arkhanist Posted July 11, 2020 Share Posted July 11, 2020 Yeah, exactly, you're saying it measures 65mm, but GW calls it 60mm. "Model is supplied with a 60mm scenic base." https://www.games-workshop.com/en-GB/Space-Marine-Dreadnought Mine isn't for a dreadnought though, it's a shattered dominion base which is listed as 65mm, which is what it is. The others are plain black plastic ones. That said, it looks like you're right - but only for the dreadnought 60mm base, not the other sizes. GW replaced the flat 60mm dreadnought base with a sculpted one, that's actually closer to 64.5mm at the bottom, but kept calling in 60mm. I wouldn't be surprised if other 40k '60mm' bases are the same. The rest of the sizes though are the listed diameter at the bottom. Link to comment https://bolterandchainsword.com/topic/365014-indomitus-base-sizes/#findComment-5560624 Share on other sites More sharing options...
Venerable Jazzman Posted July 11, 2020 Share Posted July 11, 2020 Ok, that's sample bias on my part, as I only had the Dread base discrepancy to work off. :D Add 7% to Dreadnought bases, everything else is good :tu: Arkhanist 1 Back to top Link to comment https://bolterandchainsword.com/topic/365014-indomitus-base-sizes/#findComment-5560631 Share on other sites More sharing options...
Gederas Posted July 12, 2020 Share Posted July 12, 2020 Regarding the 90mm ovals:They aren't new, they're just really uncommon base size. Buuuut they are common enough that they're included in a Sector Imperialis base set Link to comment https://bolterandchainsword.com/topic/365014-indomitus-base-sizes/#findComment-5560740 Share on other sites More sharing options...
