eternal_warrior12 Posted July 20, 2020 Share Posted July 20, 2020 Greeting fellow battle brothers of the XVIII. My question is simple, is there a good contrast color to paint your green and if not what do people use to get their unique color? Also, how do I paint their skin without getting cancelled later? Thank you all. Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/ Share on other sites More sharing options...
Galron Posted July 23, 2020 Share Posted July 23, 2020 I prefer the older olive green to the neon green you see now. I use two coats of Astra-militarum green contrast and it works for for me. Two coats are needed because one coat is too light and contrast on marines looks blotchy without the second coat. As for the skin I don't do anything special and paint them in normal colors. Since they have black skin, not dark brown, they tend to look grey with any kinds of highlights and I am not a fan of that look. Black as in the color itself looks goofy so on the few unhelmed guys I have I go with G-Man flesh and call it a day. Now if you wanted to go with a black color as in African ancestry black(as opposed to salamander ash black(trying to be as PC as possible here)) one of the dark brown contrasts might be worth trying, I might go that route on a few as well for variety. Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5568808 Share on other sites More sharing options...
Bung Posted July 23, 2020 Share Posted July 23, 2020 I dont use contrast paints. If i would paint them again i would use an airbrush. There are some great tutorials for them. Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5568860 Share on other sites More sharing options...
templargdt Posted July 24, 2020 Share Posted July 24, 2020 Pretty sure the official GW contrast method is Warp Lightning over grey seer base. highlight moot green.Good luck on not getting cancelled. I recommend all your marines have helmets on. Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5569332 Share on other sites More sharing options...
eternal_warrior12 Posted July 24, 2020 Author Share Posted July 24, 2020 Hehe very true. My local GW manager came through really well. Got Adrax and a Librarian painted up and had a blast. Unfortunately I’m having my Indomitus Marines wear the black. I’m really wavering on that though. I could make the Captain a Templar but make everyone else the 18th. Time will tell. I have 48 hrs to meditate on them Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5569393 Share on other sites More sharing options...
templargdt Posted July 24, 2020 Share Posted July 24, 2020 I'm actually in the same boat. My thread on the paucity of salamnders has me thinking to build some but I love the Templars. Also, how many Marine chapters do i need? Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5569635 Share on other sites More sharing options...
eternal_warrior12 Posted July 24, 2020 Author Share Posted July 24, 2020 I already have a unit of assault intercessors that I built a year ago thinking we were going to get them in our PA book. So that unit will be salamanders as will the captain as I already am flush with HQs. I might have to split the box in twain. Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5569698 Share on other sites More sharing options...
Debauchery101 Posted July 27, 2020 Share Posted July 27, 2020 I use an airbrush to prime neutral grey. I zenithal with a high opacity white ink. I then use a 50/50 mix of white/yellow ink to the highest points and select areas to pop with color. You can do this with a brush and do some edge highlights. After that I apply thinned out gloss varnish. Now its ready for contrast and I use WARP LIGHTNING GREEN. Brush or airbrush. I suggest using a good amount of flow improver for either type of application because spraying contrast gums up quick and flow improver with a brush helps pooling on flat areas. Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5571950 Share on other sites More sharing options...
SirVulkan Posted July 30, 2020 Share Posted July 30, 2020 I prefer the older olive green to the neon green you see now. I use two coats of Astra-militarum green contrast and it works for for me. Two coats are needed because one coat is too light and contrast on marines looks blotchy without the second coat. As for the skin I don't do anything special and paint them in normal colors. Since they have black skin, not dark brown, they tend to look grey with any kinds of highlights and I am not a fan of that look. Black as in the color itself looks goofy so on the few unhelmed guys I have I go with G-Man flesh and call it a day. Now if you wanted to go with a black color as in African ancestry black(as opposed to salamander ash black(trying to be as PC as possible here)) one of the dark brown contrasts might be worth trying, I might go that route on a few as well for variety. Funny about that. I started my Salamanders using the olive green and enjoy the more electric green now. Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5574900 Share on other sites More sharing options...
Silvs Posted August 3, 2020 Share Posted August 3, 2020 There is a quite decent tutorial on how to paint Salamanders with contrasts: https://youtu.be/b5UyWTHyDks Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5577005 Share on other sites More sharing options...
Galron Posted August 4, 2020 Share Posted August 4, 2020 Bit too bright for my tastes but very well done, not sure its practical for anything but characters although it would be easy to cut a few steps to get close to the results Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5578031 Share on other sites More sharing options...
Debauchery101 Posted August 9, 2020 Share Posted August 9, 2020 Bit too bright for my tastes but very well done, not sure its practical for anything but characters although it would be easy to cut a few steps to get close to the results My club member who plays a succesor chapter has a pretty easy and nice looking scheme where he primes black, does a minimal light grey dry brush top down followed by a few high point edge highlights and finishes it off with a green contrast/glaze. It's mostly black with a hint of green. Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5580924 Share on other sites More sharing options...
Firedrake Cordova Posted August 9, 2020 Share Posted August 9, 2020 If you're using Contrast paints, then Juan Hidalgo's video is about as good as you're going to get ;) Warhammer TV did a video on how to do the current paint scheme (and another one). For the skin, Warhammer TV did a video on the current "daemonic" skin tone. Link to comment https://bolterandchainsword.com/topic/365280-salamanders-by-contrast/#findComment-5581139 Share on other sites More sharing options...
