Cpt. Bannockburn Posted September 15, 2020 Share Posted September 15, 2020 First, the nifty mystery box. Very pretty. The instruction manual. The inside is mostly a parts list and build instructions, so I will only post it on request. Here's how the model looks with the full diorama base, but you all know that already. Contents, box 1 Contents, box 2 All the parts, none damaged during transport. Very clean casts. Not shown: standard bases, one to slot into the diorama base, one for the diorama base itself. These are all the parts that make up the primarch himself, with two head options and two sword options and accompanying scabbards. And finally the parts making up the diorama base. One Night Lord still fighting, the rest pretty sliced up, with an assortment of corpse parts to glue to the base. Today I've cleaned up the resin to prepare for washing and gluing in the next few days. Unfortunately, my cyanoacrylate superglue has last been used some time last year, so I need to make another trip into town before I can actually build more than the base assembly. It wil probably take me some time to paint everything after building, but I plan to do it fairly consistently over the next few weeks. A few of the parts were warped, but not dramatically so. All in all, I will say that this is a very high quality model from Forge World, with a minimum of hassle. The parts all fit together very well after the cleanup. Cleaning was a minimum of cutting and filing, there was very little flash, easily removed with a sharp knife. Next step will be washing everything thoroughly, gluing the bases with JB Weld, and then starting on the primarch himself. The diorama base will be looked at afterwards. stretch_135, Chaplain Raeven, Master Ciaphas and 12 others 15 Back to top Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/ Share on other sites More sharing options...
Cpt. Bannockburn Posted September 16, 2020 Author Share Posted September 16, 2020 Today, I scrubbed the mold release agent with dishsoap and cleaned up a few little sprue parts that I had missed initially. I almost lost a very small part in the drain, but was able to catch it in time. Then I used JB Weld to secure the baseplates to the actual bases, and while I was at it, did the same to the main body. Since it takes a good while to cure, I fixated everything with clamps. As you can see, I also found superglue, so I glued together the poor Night Lord (minus backpack) as well as arms and front tabard / belt. Tomorrow, when the epoxy glue is cured fully, I plan to look into which subassemblies I will build to make painting simpler. I might even get the primer sprayed before the weekend! Gederas, khorneslegion, Helias_Tancred and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5602587 Share on other sites More sharing options...
Gederas Posted September 16, 2020 Share Posted September 16, 2020 Today, I scrubbed the mold release agent with dishsoap and cleaned up a few little sprue parts that I had missed initially. I almost lost a very small part in the drain, but was able to catch it in time. And THAT is why I scrub the pieces while they're still on the gates :lol: Much harder to almost lose pieces that way. :yes: front tabard / belt. Oh come on man. They even correctly call it a surcoat on the instructions! :lol: Also side note: When I see your name, I can't help but hear Cpt. Bannockburn 1 Back to top Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5602632 Share on other sites More sharing options...
Cactus Posted September 16, 2020 Share Posted September 16, 2020 (edited) When working near a drain always always always put the plug in! I wash my resin in an old lasagne dish so nothing can escape. This is a great idea for a thread Captain. I haven't bought a Lion for my pile of shame yet so I'll live vicariously through yours. Edited September 16, 2020 by Cactus Cpt. Bannockburn 1 Back to top Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5602766 Share on other sites More sharing options...
Cpt. Bannockburn Posted September 16, 2020 Author Share Posted September 16, 2020 Oh, the plug was in. It just tried to slip cheekily in one of the gaps there. But yes, if I wash in that sink again, it'll be in another dish. That was a little scare :) Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5602979 Share on other sites More sharing options...
Cpt. Bannockburn Posted September 17, 2020 Author Share Posted September 17, 2020 Cleaned up and de-warped the pieces in need of that. Posed on the diorama base. Here's what I got done today. Everything is now primed black with the help of my airbrush, and a light dusting of grey primer for a very rudimentary zenithal highlight to bring out the details (which makes later painting easier for me). A bit of spattering is visible; my airbrush is not the best. I only use it for priming though, and none of that will be visible later. The parts are held in place with putty, I just posed everything so you can get an idea how they go together. And some smaller pieces. The head is pinned, so I can use both options. However, I decided not to paint the grenades and chainsword option, since I don't like the look. Tomorrow I will go into town to pick up a few pots of paint that I will need. Smoke Frog, Chaplain Raeven, G8Keeper and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5603401 Share on other sites More sharing options...
G8Keeper Posted September 17, 2020 Share Posted September 17, 2020 I must admit, this thread is keeping my hobby fire burning during my holiday. Absolutely brilliant, thank you! Cpt. Bannockburn and Helias_Tancred 2 Back to top Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5603755 Share on other sites More sharing options...
Interrogator Stobz Posted September 18, 2020 Share Posted September 18, 2020 Great work Brother!!! Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5604204 Share on other sites More sharing options...
KJB Posted September 29, 2020 Share Posted September 29, 2020 Great work so far! Quick one, how big is the Lions helm in comparison to a normal marines? Cpt. Bannockburn 1 Back to top Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5608791 Share on other sites More sharing options...
Gederas Posted September 29, 2020 Share Posted September 29, 2020 Great work so far! Quick one, how big is the Lions helm in comparison to a normal marines? Surprisingly, it's quite close in size to a normal Mark III helmet. Looks marginally bigger than the Mark III. Cpt. Bannockburn 1 Back to top Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5608819 Share on other sites More sharing options...
Cpt. Bannockburn Posted September 30, 2020 Author Share Posted September 30, 2020 Yes, I like helmeted better, but it does look pretty small and bland, so I might actually go with the bare head. I've built them so they're exchangeable, though. Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5608941 Share on other sites More sharing options...
Cpt. Bannockburn Posted February 10, 2021 Author Share Posted February 10, 2021 I had a few months of hobby burnout again, but yesterday I got back into it. Photo quality is terrible, as usual, due to lighting this evening, and me being an absolutely incapable photographer. Here's what I got done: I got the main colors blocked in now, and worked on the cloth as well as some shading with washes. The next step is to highlight the golds and silvers and work on the actual black of the armor. I'm working inside out, so main body assembly first, then the things to glue onto that, followed by the giant cloak and fur collar, backpack and finally the head. Currently, all the parts are just blu-tac'ed on. Cactus, Gederas, ValourousHeart and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5666133 Share on other sites More sharing options...
Cactus Posted April 8, 2021 Share Posted April 8, 2021 He's coming along well. What are your plans for highlighting the black armour - grey or blue? Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5687048 Share on other sites More sharing options...
Cpt. Bannockburn Posted April 9, 2021 Author Share Posted April 9, 2021 I've been experimenting with a few styles since the last post, but haven't decided on one yet, which is why I've not updated either. Currently I'm pondering this one: https://youtu.be/KN6cFr7Xt_Y G8Keeper 1 Back to top Link to comment https://bolterandchainsword.com/topic/366515-lion-eljonson-primarch-of-the-dark-angels-a-build-log/#findComment-5687150 Share on other sites More sharing options...
