Gamiel Posted December 7, 2020 Share Posted December 7, 2020 (edited) I assume that the Imperial Merchant Fleets have a more-or-less standard uniform. Do we know if this is correct and if yes, have we been given a description of how they look? Edited December 8, 2020 by Gamiel Link to comment https://bolterandchainsword.com/topic/368071-the-merchant-fleets-uniforms/ Share on other sites More sharing options...
Ryltar Thamior Posted December 8, 2020 Share Posted December 8, 2020 I'd doubt that - I mean, various Imperial Navy formations don't *necessarily* have standard uniforms [although it's fair to presume that the old Jes Goodwin naval concept art in various colours is a good baseline standard and guide] , dependent upon rank and role onboard, let alone ones that absolutely prevail right the way across the Imperial Navy unchanging from sector to sector. Now, as applies Merchant Navy ... the question becomes just what you're thinking of when you say that. Is it a Rogue Trader and crew? Is it a trading house and its interstellar conveyancers? Chartist Captains? The specific sort of Chartist Captains that are running pre-determined routes set down generations in advance? I suspect it rather strongly depends upon the personality, culture, and preferences of the master of whichever vessel happens to be under discussion at the time. Some will presumably prefer a more overtly formal and 'naval' looking attire in direct imitation of the 'conventional' Imperial Navy uniforms. Others may have more exotic customs . Gamiel 1 Back to top Link to comment https://bolterandchainsword.com/topic/368071-the-merchant-fleets-uniforms/#findComment-5641661 Share on other sites More sharing options...
Gamiel Posted December 8, 2020 Author Share Posted December 8, 2020 Now, as applies Merchant Navy ... the question becomes just what you're thinking of when you say that. Is it a Rogue Trader and crew? Is it a trading house and its interstellar conveyancers? Chartist Captains? The specific sort of Chartist Captains that are running pre-determined routes set down generations in advance? Ops, should have linked to the merchant fleets I meant - Merchant Fleet - Warhammer 40k - Lexicanum - will edit it in. Ryltar Thamior 1 Back to top Link to comment https://bolterandchainsword.com/topic/368071-the-merchant-fleets-uniforms/#findComment-5641763 Share on other sites More sharing options...
Brother Tyler Posted December 9, 2020 Share Posted December 9, 2020 The bottom line is that we don't know. It seems likely that there are uniforms of sorts, but whether or not these are homogenous to all members of the Merchant Fleet or if they are controlled at some lower level (potentially down to the ship level) is anyone's guess. If GW's normal treatment of things is anything to go by, there is considerable freedom for creativity here. Gamiel and Ryltar Thamior 2 Back to top Link to comment https://bolterandchainsword.com/topic/368071-the-merchant-fleets-uniforms/#findComment-5642509 Share on other sites More sharing options...
RolandTHTG Posted December 10, 2020 Share Posted December 10, 2020 The one time I remember reading of a charterist vessel, I believe they had a ship uniform that was distinct from an imperial navy uniform. Gamiel 1 Back to top Link to comment https://bolterandchainsword.com/topic/368071-the-merchant-fleets-uniforms/#findComment-5642985 Share on other sites More sharing options...
