Necromunda model scale comparison
mactire
This is a Goliath (largest of the "humans" in Necromunda) compared to a Mark IV marine (image taken by our own Noctus Cornix):
House Escher models are similar in size to Goliaths, just with far less mass. Corpse Grinder Cultists contain both normal human-sized models (Initiates) and Goliath-sized ones (Skinners, Cutters and the Butcher). All the rest of the gangs are the same scale as the AdMech Skitarii and new Sisters of Battle, with Delaque I THINK being the same height as Eschers, just without the massive hair.
In regards to terrain: All Warhammer terrain is sized to work with each other (barring the Adeptus Titanicus terrain, for obvious reasons) including AoS terrain if you want some more variety. The Zone Mortalis terrain works perfectly with the Sector Mechanicus terrain, as it's scaled to be half as tall as the Sector Mechanicus struts (so two of the Zone Mortalis wall/column pieces is the same height as a Sector Mechanicus gantry, etc)
Thanks guys, won't have too much use for the figures so.
I have a kinda longterm/crazy/expensive idea for Kill Team. I've a good bit of Terrain and the Moonbase Klassius set to play KT or maybe Skirmish on, my plan was to then homerule some scenario where by a KillTeam then went underground using the manhole thingies to carry out a mission using the Necromunda stairways and Zone Mortalis set. The combat above ground would in someway determine conditions below, such as force size for example.
